Author Topic: Dolch - ebay BIN  (Read 4279 times)
Offline precarious
  • LOOK MOM, I'M A DRAGONZORD! DOOOO DODOODODODOODOO
Dolch - ebay BIN
« on: Tue, 26 February 2013, 04:48:04 »
Offline Acetrak
  • ssk.ℜ
  • gnawm_
Dolch - ebay BIN
« Reply #1 on: Tue, 26 February 2013, 06:17:23 »
Whoever is getting this should also ask if the seller can just ship the keyboard to reduce the price or at least reduce shipping rates
Offline Mugen
  • O-Rings are the murderers of keyboard souls
Re: Dolch - ebay BIN
« Reply #2 on: Tue, 26 February 2013, 08:05:12 »
This needs a moogle kit to fit a filco or something right?
Offline Sai
« Reply #3 on: Tue, 26 February 2013, 08:08:43 »
you. you are correct.
Offline Mugen
« Reply #4 on: Tue, 26 February 2013, 08:15:47 »
Offline precarious
« Reply #5 on: Tue, 26 February 2013, 09:45:02 »
the keyboard itself is really nice though, just get a teensy and make a quick converter. :)
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Tue, 26 February 2013, 10:00:00 »
It is a PS/2 keyboard, just change the cable no need to make a controller replacement.
Offline precarious
« Reply #7 on: Tue, 26 February 2013, 10:55:10 »
true, i guess i forgot about this while using it with a laptop with no ps/2 =(
Offline Mugen
« Reply #8 on: Tue, 26 February 2013, 12:19:26 »
What switches does it have?
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #9 on: Tue, 26 February 2013, 12:21:19 »
PCB mounted MX Blue
Offline Mugen
« Reply #10 on: Tue, 26 February 2013, 12:23:09 »
oooo nice, i wanted to maybe pick up a blue switch board, if it werent for the scratches on the shift and space bar i would have snatched it in a second >_<
Offline SmallFry
« Reply #11 on: Tue, 26 February 2013, 12:25:11 »
Dat right shift. Ouch.
Offline precarious
« Reply #12 on: Tue, 26 February 2013, 13:35:09 »
short bus right shift is drooling
« Reply #13 on: Tue, 26 February 2013, 14:35:17 »
This is seriously revoltingly tempting and pay day is on Thursday >.<  FUUUUUUUUUUUU rent!
Offline precarious
« Reply #14 on: Tue, 26 February 2013, 17:06:26 »
if it really is scratched up and not dirty, or whatever, don't sweat it too much, probably better to wait for one in better condition :)
Offline Mugen
« Reply #15 on: Tue, 26 February 2013, 20:22:38 »
I contacted the seller to ask for additional pictures but he responded that somebody is already in the process of buying it. :\
Offline Mugen
« Reply #16 on: Fri, 01 March 2013, 17:23:55 »
Does anybody know i can find a guide on how to change the cable?
Cheers,
« Reply #17 on: Fri, 01 March 2013, 19:20:32 »
Easiest way, just cut the end of a PS/2 cable and crimp a 4p4c connector on the end, then you have a detachable PS/2 cable and don't really have to modify the keyboard at all. Otherwise, just open the casebody up take out the pcb desolder the wires that lead to the 4p4c connector and solder on PS/2 cable. There is really not much complexity there.
« Last Edit: Fri, 01 March 2013, 19:22:32 by IvanIvanovich »
Offline leesofi
  • super lurking
« Reply #18 on: Fri, 01 March 2013, 19:24:16 »
i know but cant explan  :p
Offline precarious
« Reply #19 on: Fri, 01 March 2013, 20:15:20 »
like that, i picked up the line splitter at k-mart for a few bucks.  those are some thick coiled cherry ps/2 cables, but you can use whatever
