Author Topic: Which realforce?  (Read 10932 times)
Offline hasu
  • @tmk
Re: Which realforce?
« Reply #50 on: Mon, 04 March 2013, 07:06:27 »
I must say Realforce(in particular variable one) feels a tad better than HHKB(pro and pro2) from my experience, though I have only two Realforce 101(variable) and 106s(30g? 35g?). Unlike most of Topre lovers around here I like variable force definitely :)
Unfortunately I deeply love HHKB for its small footprint and layout and can't survive with hulking Realforce in this hard world :D
Offline daerid
    • Rossipedia
« Reply #51 on: Mon, 04 March 2013, 10:31:52 »
Well then I'll just replace it when it does decide to crap out. But I don't see myself ever willingly selling any HHKB. I love this thing way too much
Offline lazerpointer
  • ya gotta stay phresh
« Reply #52 on: Mon, 04 March 2013, 14:25:02 »
5 years? That's a bit pessimistic. Maybe the actuation force will go up a bit because the rubber gets old.
This stuff is called Rubber Renue. Also you can lube the switches.
http://www.amazon.com/MG-Chemicals-Rubber-Liquid-Bottle/dp/B008O9X3KS/ref=sr_1_1?ie=UTF8&qid=1362428377&sr=8-1&keywords=rubber+renew
The point of the capacitive switch is that there's little friction or parts bumping together - the spring goes down enough to actuate (I STILL don't know exactly how this works, but it seems like it would be more long-lasting than say a complicated switch like Cherry blues, browns or clears.)
i type, therefore i geekhack
Offline daerid
    • Rossipedia
« Reply #53 on: Mon, 04 March 2013, 16:44:23 »
AFAIK, Topre switches are rated for something like 30M keypresses, whereas Cherries are rated at 50M. I haven't been keeping count though :-X
Offline iri
« Reply #54 on: Tue, 05 March 2013, 04:26:04 »
you are right, the switch itself (the spring) could live looooooooong, it's all about aging of domes.
-Ray Bradbury
