Author Topic: Looking for Gaming Keyboard  (Read 1431 times)
Offline Billy Badluck
« on: Wed, 27 February 2013, 18:43:49 »
Hey folks,
I've spent the last days looking for gaming keyboards, and was kinda successful, though almost each keyboard I found fitting had a US-Layout, e.g. Ducky and Leopold.
Those who didn't have a US-Layout weren't availabe [No delivery dates/Not in stock] like the Steelseries 6gv2 [New Version with MX Reds] or the CM Storm Rapid Red [Alternate delivery date: 06.05.2013] or were quite expensive [Das Keyboard].
Long story short, living in Germany makes the keyboard search somewhat frustrating. That's why I'm turning towards you now, perhaps someone knows the droids keyboard I am looking for.
Preferably:
- German Layout
- MX Reds/Browns [Reds > Browns]
- PS2 or USB KRO 6+
- Not too pricey [Max. 120€ or less]
- Plate Mounting
Less important:
- Laser etched Keys
- Tenkeyless
- No shiny case [Fingerprints etc]
    Thx for reading/replying!
Offline whiteduck
Re: Looking for Gaming Keyboard
« Reply #1 on: Wed, 27 February 2013, 18:50:19 »
I got a slightly used (like one month of gaming sc2) Leopold ten keyless otaku white version I am looking to part with.  If interested lemme kno.
-wd
-wd
Offline jabar
« Reply #2 on: Wed, 27 February 2013, 19:55:21 »
If you are OK with going used, Deskthority also has a classified section which has more Euro users posting used ads.
Most boards coming out of Asia are ANSI, so a QWERTZ ISO board out of the box is more difficult to find. Also, what form factor interests you most?
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Wed, 27 February 2013, 20:06:29 »
Yes it is harder to find maybe, but I suggest you change your thread title to "Looking for DE/ISO Gaming Keyboard" or similar to attract DE/EU people that are more likely to help point you towards relevant shops. If DE can be cut from options if you are having trouble finding stock, maybe expand your search to include other ISO layouts like Nordic, GB or FR?
Offline missalaire
  • Great Finder of Great Finds
« Reply #4 on: Thu, 28 February 2013, 11:15:56 »
http://www.keyboardco.com/ has some German layout Filco keyboards. Not sure how much shipping would end up being for you, but they range from £95-105 and they have them in both MX Reds and Browns.
« Reply #5 on: Thu, 28 February 2013, 12:37:36 »
Thanks for your replies! I finally found a shop that has QWERTZ-ISO Coolermaster Keyboards with MX Reds, and since Filco and CM are almost the same (many parts made by the same fabricator) but CM isn't as far as costly, I chose to buy one. I found the shop via heise.de (changed my searching terms a bit). Hopefully this is helpful for future requests, especially for german gamers!
Shoutout to csv-direct.de, the shop that finally ended my epic keyboard quest!
