Author Topic: Source for rubber feet (sold by the foot/inch/meter)  (Read 4395 times)
Offline gnubag
« on: Wed, 27 February 2013, 22:18:05 »
Does anybody know where to buy rubber feet by the foot/inch/meter in the US (also affordable)?
something like this : http://www.ebay.com/itm/Rubber-Feet-Set-14mm-L-x-3mm-W-x-2-2mm-H-10pcs-RB185-/160721134582?pt=LH_DefaultDomain_0&hash=item256bb9e3f6
around these dimensions, 3mm wide, 2mm high
Offline khaangaaroo
Re: Source for rubber feet (sold by the foot/inch/meter)
« Reply #1 on: Wed, 27 February 2013, 22:40:43 »
Not sure if these will work for what you need them for: http://www.allelectronics.com/make-a-store/category/545/Rubber-Feet/Bumpers/1.html
$7 shipping, or free local pickup if you're in L.A.
or I can send you some of the ones I have if you only need a few.
« Reply #2 on: Wed, 27 February 2013, 23:36:45 »
Yeah... I would also like some circular rubber feet, but I'm in Canada. Something to put on my LZ-S since it seems like one of them got warped and now it's wobbly.
Offline sleepy916
« Reply #3 on: Thu, 28 February 2013, 00:09:02 »
I'm about to get this one for my model f, but not sure if I wanted to get the black or clear ones.
http://www.ebay.com/itm/270874267068?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
« Reply #4 on: Thu, 28 February 2013, 00:11:40 »
I got some black circular ones from China.. just to check them out.
Offline calavera
« Reply #5 on: Thu, 28 February 2013, 00:18:45 »
If you're looking for those dimensions I would just go ahead and buy that. $4.50 is cheap. Other widely available options are the round ones. Just google self-adhesive rubber feet/pads. I'm looking for square ones that come stock on filco keyboards myself. So far no luck.
Offline gnubag
« Reply #6 on: Thu, 28 February 2013, 00:20:01 »
well I am thinking about buying a large sheet and cutting them out, but i would like to have round edges...
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Thu, 28 February 2013, 00:20:03 »
Check out your local hardware stores cabinet department. I use cabinet door bumpers as feet for the wrist rests that I make
Offline rootwyrm
  • The Hands of Steel
    • My Website!
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline gnubag
« Reply #9 on: Fri, 01 March 2013, 01:02:10 »
ok i just bought 2 sets of those feet from ebay.
btw. has anybody ever thought of getting suction cups as a replacement for feet? o.0 (crazy but maybe legit idea)
Offline calavera
« Reply #10 on: Mon, 11 March 2013, 20:17:21 »
I just got these 1/4" gripper pads in the mail and tried them out. These were meant for furniture so its thicker than I expected.
I wanted something that would fit in here so those round ones wouldn't work well.
I cut them to the size I want and they hold very well. Keyboard wont budge. Behold the levitating keyboard!
To be fair the keyboard weighs 4.5 lbs to begin with but I didn't want to scratch up my desk. So.....
I have clear round ones coming in the mail so gonna give those a try too. lol
Offline MJ45
  • HHKB Pro
« Reply #11 on: Fri, 15 March 2013, 14:11:45 »
  I found some 3M self stick rubber pads at Michael's craft store they are 1/2" dia. & 9/64" thick they are clear and very grippy 18 in a pack for $4.49 +tax. I put one on each corner of my keyboard it stays put.
