Author Topic: Tips on Installing SP Caps for Costar Stabilizer Boards?  (Read 10841 times)
Offline missalaire
  • Great Finder of Great Finds
« on: Thu, 28 February 2013, 12:43:48 »
So this is my first time installing key caps on a Costar stabilizer board and apparently SP has loose holes for the white stabilizer inserts and that's causing me a bit of trouble... help!
Offline The_Beast
  • I like wood ಠ_๏
Re: Tips on Installing SP Caps for Costar Stabilizer Boards?
« Reply #1 on: Thu, 28 February 2013, 12:44:33 »
Cut a plastic bag and use them as shims for the white inserts
Offline missalaire
« Reply #2 on: Thu, 28 February 2013, 12:47:02 »
Shims? Like slipping them into the hole and using it to hold them up into the key cap?
Offline SmallFry
« Reply #3 on: Thu, 28 February 2013, 12:47:56 »
Take the plastic, lay it over the stem hole, insert white insert. Bam!  :D
Offline gigibecali
« Reply #4 on: Thu, 28 February 2013, 12:58:47 »
don't forget the longer part of your inserts must be oriented north
IBM M - UK  |  QFR reds  |  QFR blacks  |  HPE 87 browns  |  HPE 87 blues
Offline missalaire
« Reply #5 on: Thu, 28 February 2013, 13:01:57 »
Did this with some saran wrap, worked. Thanks :)
Learned this the hard way earlier lol. Thanks.
Got everything sorted out and installed, thanks guys!
« Last Edit: Thu, 28 February 2013, 13:14:24 by missalaire »
Offline badcop
  • thorpe thocking master race
« Reply #6 on: Thu, 28 February 2013, 15:00:25 »
If anyone is interested I made a quick video lap last week.
Offline gigibecali
« Reply #7 on: Fri, 01 March 2013, 09:04:29 »
@OP:
have you managed to do the spacebar right?
What was the problem?
Offline missalaire
« Reply #8 on: Fri, 01 March 2013, 11:03:51 »
@OP:
Yes I managed to get everything done right a few minutes after I posted this up. Well, at first I didn't realize that both stabilizer inserts had to be facing north and then I couldn't get it to sit right over the switch, but everything is good now. Thanks for checking up :)
