Author Topic: Hellocodes's Custom Poker  (Read 11806 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Sat, 02 March 2013, 07:01:47 »
Just a quick and dirty picture after a long night of modding:
Info:
Switches: Modded Clears
Mods: Stainless Steel Plate, Pink Stickers, Lubed with SuperLube (springs, sliders and stem)
Other: PCB Mount Cherry Stabilizers
Some time stats:
Adding Switches to plate: 20 minutes
Removing switch tops: 15 minutes
Stickering: 45 minutes
Lubing: 1 hour 45 minutes
Installing stabilizers + plate w/ switches: 30 minutes
Total Time: 3 hours 35 minutes
I guessed about 4 hours, so I wasn't too far off. Now it just needs to be soldered, stuck in a case and shipped to hellocodes :D
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Hellocodes's Custom Poker
« Reply #1 on: Sat, 02 March 2013, 07:47:39 »
That looks like an awesome Poker.  Hellocode is hella fortunate to have such a nice board.
Nice job Beast! Thank you for sharing your build summary. I'm sure my build will take twice as long, but it's nice to know what I'm in for.  ;D
Offline Turbo Slaab
« Reply #2 on: Sat, 02 March 2013, 07:53:22 »
Nice!
Looking for CC's!
« Reply #3 on: Sat, 02 March 2013, 08:12:05 »
Oooo, I like numbers ^_^
Offline codyeatworld
« Reply #4 on: Sat, 02 March 2013, 09:08:13 »
You are fast sir! :cool: Looks great, I can't wait to hammer down on it.
Thanks for sharing this!
Offline singaporean123
  • I like keycaps and I cannot lie
« Reply #5 on: Sat, 02 March 2013, 09:16:03 »
Splendid work!
Offline dimamantra
  • | (• ◡•)| (❍ᴥ❍ʋ)
« Reply #6 on: Sat, 02 March 2013, 15:03:39 »
Just noticed that the Poker board have the suits cut out above the space bar.
Love that detail!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Sat, 02 March 2013, 15:23:33 »
Thanks guys!
Offline Jocelyn
  • 조셀린
« Reply #8 on: Sat, 02 March 2013, 15:26:23 »
Looks great! Aren't those plate mount cherry stabilizers?  :)
Yup, those are PCB mount stabilizers
lol what? I asked if they were Plate mount, and you said yup, they're PCB mount. I thought both PCB and Plate mount existed  :confused:
« Last Edit: Sat, 02 March 2013, 15:35:51 by Jocelyn »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #9 on: Sat, 02 March 2013, 15:27:31 »
« Reply #10 on: Sat, 02 March 2013, 15:32:45 »
Nice! Looks like a great board to type on, good work Beast. Enjoy Hellocode.
« Reply #11 on: Sat, 02 March 2013, 16:47:14 »
They are a soft face plate mount. I didn't know the difference until now. Guessing these are a bit more secure?
http://www.mouser.com/Search/ProductDetail.aspx?R=MX1A-C1NNvirtualkey54010000virtualkey540-MX1A-C1NN
Offline Michael
  • Formerly Bro Caps
« Reply #12 on: Sat, 02 March 2013, 16:54:52 »
Looking good, BeastBro
Offline The_Beast
  • I like wood ಠ_๏
« Reply #13 on: Sat, 02 March 2013, 18:52:08 »
^^^ Thanks :P
The switches you sent are plate mount, Jocelyn was asking about the stabilizers which are PCB mount.
The difference between a plate and PCB mount switch is that that PCB mount switches have two little legs on the bottom that make sure the switch is aligned with the PCB. Plate mounts don't have/need the legs since the plate should be doing the aligning.
« Reply #14 on: Sun, 03 March 2013, 02:20:38 »
Thanks for clearing that up.
Offline fydo
  • Meow!
« Reply #15 on: Sun, 03 March 2013, 02:27:18 »
Looks great!
What case is that bad boy going to be sitting in? :D
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #16 on: Sun, 03 March 2013, 02:30:45 »
Looks great!
Just a plastic OEM case. It's all I really had on hand
Offline Jocelyn
  • 조셀린
« Reply #17 on: Sun, 03 March 2013, 02:41:04 »
LIES! :)
It's going in one of these - http://geekhack.org/index.php?topic=40814.0
Offline Batmann
« Reply #18 on: Sun, 03 March 2013, 02:59:10 »
3h35 to turn a poker into an awesome poker, that's totally worth it.
This in an alu case will feel just great, nothing like a stock poker
Enjoy hellocodes :)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #19 on: Sun, 03 March 2013, 02:59:39 »
LIES! :)
2nd one, maybe but hellocodes want's a OEM case for now
« Reply #20 on: Sun, 03 March 2013, 03:04:43 »
It will be in a aluminum case. :)
I may use the oem poker case for something else...
Offline The_Beast
  • I like wood ಠ_๏
« Reply #21 on: Sun, 03 March 2013, 03:27:59 »
Nice!
Be sure you sell the old case, I KNOW people want one bad
Offline Batmann
« Reply #22 on: Sun, 03 March 2013, 04:12:33 »
A fancy ashtray?
« Reply #23 on: Thu, 14 March 2013, 19:02:59 »
15737-0
« Last Edit: Tue, 19 March 2013, 13:53:47 by hellocodes »
