Author Topic: Ctrl+V, then hit post  (Read 242225 times)
Re: Ctrl+V, then hit post
« Reply #150 on: Mon, 02 December 2013, 22:03:46 »
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #151 on: Mon, 02 December 2013, 22:04:52 »
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #152 on: Mon, 02 December 2013, 22:05:50 »
error: expected primary-expression before 'char'
Tree.c:173: error: expected ';' before
Offline MKULTRA
  • telling it how it is
« Reply #153 on: Mon, 02 December 2013, 22:14:22 »
    Alcohol-induced blackouts are the result of alcohol’s effect on which part of the brain
« Reply #154 on: Tue, 03 December 2013, 02:16:45 »
Offline dragonxx21
« Reply #155 on: Tue, 03 December 2013, 02:18:13 »
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline deSheol
  • Thorpe
« Reply #156 on: Tue, 03 December 2013, 02:18:51 »
Offline Jack
« Reply #157 on: Tue, 03 December 2013, 06:39:28 »
// kill messages
// set frag and kills messages that appear in server logs
fragmessage 1 fragged           // pistol
fragmessage 2 fragged     // carbine
fragmessage 3 fragged         // shotgun
fragmessage 4 fragged          // smg
fragmessage 5 fragged        // sniper
fragmessage 6 fragged         // assault rifle
fragmessage 7 fragged           // cpistol
fragmessage 9 fragged           // akimbo
gibmessage 0 slashed           // knife
gibmessage 3 splattered        // shotgun gib
gibmessage 5 headshot          // sniper gib
gibmessage 8 gibbed            // nade gib
Offline regack
« Reply #158 on: Tue, 03 December 2013, 07:19:49 »
'''fciv -r -add [SCANPATH] [FILETYPELIST] -sha1 -xml [XMLDBNAME].xml
Return = WshShell.Run("fciv " & FCIVArgs, 1, true)
Offline paicrai
  • mindblank
« Reply #159 on: Tue, 03 December 2013, 10:14:28 »
( ͡° ͜ʖ ͡°)
« Last Edit: Tue, 03 December 2013, 10:22:19 by paicrai »
THE FEMINIST ILLUMINATI
« Reply #160 on: Tue, 03 December 2013, 14:47:08 »
(this post was deliberately left empty)
« Reply #161 on: Tue, 03 December 2013, 15:08:54 »
Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa Kappa
I was watching D2L playoffs
« Reply #162 on: Tue, 03 December 2013, 16:55:54 »
Offline simz
« Reply #163 on: Tue, 03 December 2013, 19:07:33 »
Offline Morwrath
« Reply #164 on: Tue, 03 December 2013, 20:09:27 »
http://3.bp.blogspot.com/-GVjCTDuKslk/T0OW5S6sPUI/AAAAAAAAAMs/ujCdOEg3R1Y/s1600/skull%2Bbird%2Btree%2Bleg%2Btattoo%2Bwebsite%2Bsmall.jpg
Been looking for a tattoo for some time, not decided yet but beginning to get an idea of what I want :)
Ducky Mini w/ white LEDs [Browns]
WTB SLUSHY RED CC/BROBOT!!
Got 3D and Hack Orange for trade, both MX.
Offline Sai
Offline Fullcream
« Reply #166 on: Tue, 03 December 2013, 20:34:26 »
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #167 on: Tue, 03 December 2013, 20:34:52 »
Offline kmiller8
Offline bazh
HHKB Pro2 white
Newbie again
« Reply #170 on: Tue, 03 December 2013, 23:13:05 »
Purple
« Reply #171 on: Tue, 03 December 2013, 23:21:56 »
Purple
I can't imagine needing to copy the word purple.  :p  can't you remember it?
« Reply #172 on: Tue, 03 December 2013, 23:26:39 »
Purple
Hahah :p I only copied part of the sentence
Offline Nojo
« Reply #173 on: Tue, 03 December 2013, 23:52:54 »
Low Light Combat
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #174 on: Wed, 04 December 2013, 02:19:36 »
Even if you solved the biggest problem in your life, you would still have a biggest problem. :P
|||My other keyboards :
x
« Reply #175 on: Thu, 05 December 2013, 04:49:29 »
Happy Holiday Event
Offline belac
« Reply #176 on: Thu, 05 December 2013, 07:03:49 »
Bam tonight?
« Reply #177 on: Thu, 05 December 2013, 07:45:53 »
Offline MrexD
  • aka mrwoodyxd
« Reply #178 on: Thu, 05 December 2013, 07:48:40 »
***SPARES*** engineer on site replacing keyboard on node 2 as several keys are not responding
Pok3r MX CLears
Offline Dude
  • Thwock!
« Reply #179 on: Thu, 05 December 2013, 19:47:17 »
Wake Up, Ron Burgundy
Realforce 87U Tenkeyless
« Reply #180 on: Thu, 05 December 2013, 19:48:26 »
The GeekHack 60% Nostalgia Keyset
Offline Dude
  • Thwock!
« Reply #181 on: Thu, 05 December 2013, 19:48:55 »
« Reply #182 on: Thu, 05 December 2013, 19:49:30 »
Offline daerid
    • Rossipedia
« Reply #183 on: Thu, 05 December 2013, 20:19:01 »
// SQL Pukes if this is more than 2100. Cap at 1000 for now (probably too high)
Offline Latin00032
« Reply #184 on: Thu, 05 December 2013, 20:25:08 »
>Good ~~luck finding a 40 hour a week minimum wage~~ job ~~nowadays~~
Offline JoeC
« Reply #185 on: Thu, 05 December 2013, 21:33:06 »
cxhzf-4230649602@serv.craigslist.org
Lurk Moar!!!!!
« Reply #187 on: Fri, 06 December 2013, 07:41:44 »
MIT Researchers devise the toughest tongue twister: pad kid poured curd pulled cod
Offline kmiller8
« Reply #188 on: Fri, 06 December 2013, 13:22:35 »
A milling machine is often called a mill by machinists. The archaic term miller was commonly used in the 19th and early 20th centuries.
« Reply #189 on: Fri, 06 December 2013, 13:37:05 »
Offline C5Allroad
  • Formerly HUNTERANGEL121
Offline Jack
« Reply #192 on: Sat, 07 December 2013, 10:05:16 »
Offline MKULTRA
Offline kmiller8
« Reply #194 on: Sat, 07 December 2013, 15:05:02 »
༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ༼ つ ◕_◕ ༽つ
« Reply #195 on: Sat, 07 December 2013, 17:59:30 »
zerg rush
Heh - type that into Google search.
Offline Jack
« Reply #196 on: Sat, 07 December 2013, 23:03:09 »
𝑥
« Reply #197 on: Sun, 08 December 2013, 21:33:47 »
man that thing is nuts!!!!!!
« Reply #198 on: Sun, 08 December 2013, 21:34:45 »
$1,861,593.60
$872,509.29
$278,949.63
« Reply #199 on: Sun, 08 December 2013, 21:35:04 »
