Author Topic: Ctrl+V, then hit post  (Read 244107 times)
Re: Ctrl+V, then hit post
« Reply #250 on: Wed, 19 March 2014, 22:43:13 »
Offline daerid
    • Rossipedia
« Reply #251 on: Wed, 19 March 2014, 23:35:02 »
^^ A good one
Offline Smasher816
  • HHKB Master
« Reply #253 on: Wed, 19 March 2014, 23:52:30 »
Code: [Select]
--- Entry #0 ---
Binary Type: 0 (AP)
Device Type: 2 (MMC)
Identifier: 1
Attributes: 5 (Read/Write)
Update Attributes: 1 (FOTA)
Partition Block Size/Offset: 8192
Partition Block Count: 122880
File Offset (Obsolete): 0
File Size (Obsolete): 0
Partition Name: MODEM
Flash Filename: NON-HLOS.bin
FOTA Filename:
--- Entry #1 ---
Binary Type: 0 (AP)
Identifier: 2
Partition Block Size/Offset: 131072
Partition Block Count: 256
Partition Name: SBL1
Flash Filename: sbl1.mbn
FOTA Filename:
--- Entry #2 ---
Binary Type: 0 (AP)
Identifier: 3
Partition Block Size/Offset: 131328
Partition Block Count: 512
Partition Name: SBL2
Flash Filename: sbl2.mbn
FOTA Filename:
--- Entry #3 ---
Binary Type: 0 (AP)
Identifier: 4
Partition Block Size/Offset: 131840
Partition Block Count: 1024
Partition Name: SBL3
Flash Filename: sbl3.mbn
FOTA Filename:
--- Entry #4 ---
Binary Type: 0 (AP)
Identifier: 5
Partition Block Size/Offset: 132864
Partition Block Count: 4096
Partition Name: ABOOT
Flash Filename: aboot.mbn
FOTA Filename:
--- Entry #5 ---
Binary Type: 0 (AP)
Identifier: 6
Partition Block Size/Offset: 136960
Partition Name: RPM
Flash Filename: rpm.mbn
FOTA Filename:
--- Entry #6 ---
Binary Type: 0 (AP)
Identifier: 7
Partition Block Size/Offset: 137984
Partition Block Count: 20480
Partition Name: BOOT
Flash Filename: boot.img
FOTA Filename:
--- Entry #7 ---
Binary Type: 0 (AP)
Identifier: 8
Partition Block Size/Offset: 158464
Partition Name: TZ
Flash Filename: tz.mbn
FOTA Filename:
--- Entry #8 ---
Binary Type: 0 (AP)
Identifier: 9
Partition Block Size/Offset: 159488
Partition Name: PAD
Flash Filename:
FOTA Filename:
--- Entry #9 ---
Binary Type: 0 (AP)
Identifier: 10
Partition Block Size/Offset: 160512
Partition Name: PARAM
Flash Filename:
FOTA Filename:
--- Entry #10 ---
Binary Type: 0 (AP)
Identifier: 11
Update Attributes: 5 (FOTA)
Partition Block Size/Offset: 180992
Partition Block Count: 27904
Partition Name: EFS
Flash Filename: efs.img.ext4
FOTA Filename:
--- Entry #11 ---
Binary Type: 0 (AP)
Identifier: 12
Partition Block Size/Offset: 208896
Partition Block Count: 6144
Partition Name: MODEMST1
Flash Filename: nvrebuild1.bin
FOTA Filename:
--- Entry #12 ---
Binary Type: 0 (AP)
Identifier: 13
Partition Block Size/Offset: 215040
Partition Name: MODEMST2
Flash Filename: nvrebuild2.bin
FOTA Filename:
--- Entry #13 ---
Binary Type: 0 (AP)
Identifier: 14
Partition Block Size/Offset: 221184
Partition Block Count: 3072000
Partition Name: SYSTEM
Flash Filename: system.img.ext4
FOTA Filename:
--- Entry #14 ---
Binary Type: 0 (AP)
Identifier: 15
Partition Block Size/Offset: 3293184
Partition Block Count: 25665536
Partition Name: USERDATA
Flash Filename: userdata.img.ext4
FOTA Filename:
--- Entry #15 ---
Binary Type: 0 (AP)
Identifier: 16
Partition Block Size/Offset: 28958720
Partition Block Count: 16384
Partition Name: PERSIST
Flash Filename: persist.img.ext4
FOTA Filename:
--- Entry #16 ---
Binary Type: 0 (AP)
Identifier: 17
Partition Block Size/Offset: 28975104
Partition Block Count: 1720320
Partition Name: CACHE
Flash Filename: cache.img.ext4
FOTA Filename:
--- Entry #17 ---
Binary Type: 0 (AP)
Identifier: 18
Partition Block Size/Offset: 30695424
Partition Name: RECOVERY
Flash Filename: recovery.img
FOTA Filename:
--- Entry #18 ---
Binary Type: 0 (AP)
Identifier: 19
Partition Block Size/Offset: 30715904
Partition Name: FOTA
Flash Filename:
FOTA Filename:
--- Entry #19 ---
Binary Type: 0 (AP)
Identifier: 20
Partition Block Size/Offset: 30736384
Partition Name: BACKUP
Flash Filename:
FOTA Filename:
--- Entry #20 ---
Binary Type: 0 (AP)
Identifier: 21
Partition Block Size/Offset: 30748672
Partition Name: FSG
Flash Filename:
FOTA Filename:
--- Entry #21 ---
Binary Type: 0 (AP)
Identifier: 22
Partition Block Size/Offset: 30754816
Partition Name: SSD
Flash Filename:
FOTA Filename:
--- Entry #22 ---
Binary Type: 0 (AP)
Identifier: 23
Partition Block Size/Offset: 30754832
Partition Block Count: 10240
Partition Name: GROW
Flash Filename:
FOTA Filename:
--- Entry #23 ---
Binary Type: 0 (AP)
Identifier: 70
Partition Block Size/Offset: 0
Partition Block Count: 34
Partition Name: PGPT
Flash Filename: pgpt.img
FOTA Filename:
--- Entry #24 ---
Binary Type: 0 (AP)
Identifier: 71
Partition Block Size/Offset: 34
Partition Name: PIT
Flash Filename: MSM8960.pit
FOTA Filename:
--- Entry #25 ---
Binary Type: 0 (AP)
Identifier: 72
Partition Block Size/Offset: 50
Partition Block Count: 32
Partition Name: MD5
Flash Filename: md5.img
FOTA Filename:
--- Entry #26 ---
Binary Type: 0 (AP)
Identifier: 73
Partition Block Size/Offset: 30777311
Partition Block Count: 33
Partition Name: SGPT
Flash Filename: sgpt.img
FOTA Filename:F
Offline blackbox
« Reply #254 on: Thu, 20 March 2014, 07:29:20 »
Canon Ir Advanced Color 5135i
The LAN table!
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #255 on: Thu, 20 March 2014, 14:22:14 »
Code: [Select]
javascript:(function(){function c(){var e=document.createElement("link");e.setAttribute("type","text/css");e.setAttribute("rel","stylesheet");e.setAttribute("href",f);e.setAttribute("class",l);document.body.appendChild(e)}function h(){var e=document.getElementsByClassName(l);for(var t=0;t<e.length;t++){document.body.removeChild(e[t])}}function p(){var e=document.createElement("div");e.setAttribute("class",a);document.body.appendChild(e);setTimeout(function(){document.body.removeChild(e)},100)}function d(e){return{height:e.offsetHeight,width:e.offsetWidth}}function v(i){var s=d(i);return s.height>e&&s.height<n&&s.width>t&&s.width<r}function m(e){var t=e;var n=0;while(!!t){n+=t.offsetTop;t=t.offsetParent}return n}function g(){var e=document.documentElement;if(!!window.innerWidth){return window.innerHeight}else if(e&&!isNaN(e.clientHeight)){return e.clientHeight}return 0}function y(){if(window.pageYOffset){return window.pageYOffset}return Math.max(document.documentElement.scrollTop,document.body.scrollTop)}function E(e){var t=m(e);return t>=w&&t<=b+w}function S(){var e=document.createElement("audio");e.setAttribute("class",l);e.src=i;e.loop=false;e.addEventListener("canplay",function(){setTimeout(function(){x(k)},500);setTimeout(function(){N();p();for(var e=0;e<O.length;e++){T(O[e])}},15500)},true);e.addEventListener("ended",function(){N();h()},true);e.innerHTML=" <p>If you are reading this, it is because your browser does not support the audio element. We recommend that you get a new browser.</p> <p>";document.body.appendChild(e);e.play()}function x(e){e.className+=" "+s+" "+o}function T(e){e.className+=" "+s+" "+u[Math.floor(Math.random()*u.length)]}function N(){var e=document.getElementsByClassName(s);var t=new RegExp("\\b"+s+"\\b");for(var n=0;n<e.length;){e[n].className=e[n].className.replace(t,"")}}var e=30;var t=30;var n=350;var r=350;var i="//s3.amazonaws.com/moovweb-marketing/playground/harlem-shake.mp3";var s="mw-harlem_shake_me";var o="im_first";var u=["im_drunk","im_baked","im_trippin","im_blown"];var a="mw-strobe_light";var f="//s3.amazonaws.com/moovweb-marketing/playground/harlem-shake-style.css";var l="mw_added_css";var b=g();var w=y();var C=document.getElementsByTagName("*");var k=null;for(var L=0;L<C.length;L++){var A=C[L];if(v(A)){if(E(A)){k=A;break}}}if(A===null){console.warn("Could not find a node of the right size. Please try a different page.");return}c();S();var O=[];for(var L=0;L<C.length;L++){var A=C[L];if(v(A)){O.push(A)}}})()
Type this into console on chrome...  :p
In case no one did...
Offline regack
« Reply #256 on: Thu, 20 March 2014, 14:25:22 »
part # H1K92A3
  • Live long and prosper
« Reply #257 on: Thu, 20 March 2014, 14:26:44 »
Code: [Select]
:eek:
Trippy **** man...
Code: [Select]
<style type="text/css">
/* style used for preview page only */
/* html {
height:100%;
background:#FFF;
    body {
width:100%;
height:100%;
margin:0;
h1 {
font-size:15px;
font-weight:normal;
color:#B5FF00;
margin:0;
*/ .container{
width:734px;
height:483px;
top:50%;
left:50%;
border-style:none;
margin-bottom:5;
margin-left:4;
    </style>
<link rel="stylesheet" type="text/css" href="http://www.value-bp.com/slider/wt-rotator.css">
<script type="text/javascript" src="http://www.value-bp.com/slider/js/jquery-1.7.1.min.js"></script>
    <script type="text/javascript" src="http://www.value-bp.com/slider/js/jquery.easing.1.3.min.js"></script>
    <script type="text/javascript" src="http://www.value-bp.com/slider/js/jquery.wt-rotator.min.js"></script>
<script type="text/javascript">
    $(document).ready(
function() {
$(".container").wtRotator({
width:734,
height:483,
thumb_width:24,
            thumb_height:24,
button_width:24,
button_height:24,
button_margin:5,
auto_start:true,
delay:5000,
play_once:false,
transition:"fade",
transition_speed:800,
auto_center:true,
easing:"",
cpanel_position:"inside",
cpanel_align:"BR",
timer_align:"top",
display_thumbs:false,
display_dbuttons:false,
display_playbutton:false,
display_thumbimg:false,
            display_side_buttons:false,
display_numbers:false,
display_timer:false,
mouseover_select:false,
mouseover_pause:false,
cpanel_mouseover:false,
text_mouseover:false,
text_effect:"none",
text_sync:true,
tooltip_type:"text",
shuffle:false,
block_size:75,
vert_size:55,
horz_size:50,
block_delay:25,
vstripe_delay:75,
hstripe_delay:180
    </script>
<div class="container">
<div class="wt-rotator" style="width: 734px; height: 483px;">
    <div class="screen" style="width: 734px; height: 483px;">
            <noscript>
            &amp;lt;!-- placeholder 1st image when javascript is off --&amp;gt;
                &amp;lt;img src="http://www.u-save-more.com/universal-slider/images/slide-cleaning2014.jpg"/&amp;gt;
            </noscript>
      <div class="desc" style="visibility: visible; display: none;"><div class="inner-bg"></div><div class="inner-text" style="width: auto; height: auto;"></div></div> <div class="preloader" style="display: none;"></div> <div class="timer" style="display: none; overflow: hidden; width: 102.606px;"></div><a href="http://www.shopcrystalrock.com/P479/portal/alias__UniversalBusiness/tabID__51994/DesktopDefault.aspx" target="_parent" style="cursor: pointer;"><img class="main-img" src="http://www.u-save-more.com/universal-slider/images/slide-cleaning2014.jpg" id="" style="top: 0px; left: 0px; z-index: 0; display: none;"><img class="main-img" src="http://www.u-save-more.com/universal-slider/images/slide-cleaning2014.jpg" id="curr-img" style="top: 0px; left: 0px; z-index: 1; opacity: 1; display: inline;"><img class="main-img" src="http://www.u-save-more.com/universal-slider/images/slide-crystal-rock.jpg" style="top: 0px; left: 0px; display: none;"><img class="main-img" src="http://www.u-save-more.com/universal-slider/images/slide-HP.jpg" style="top: 0px; left: 0px; display: none;"></a></div>
        <div class="c-panel">
      <div class="thumbnails">
                <ul>
                    <li class="curr-thumb" style="display: none;">
                    <a href="http://www.u-save-more.com/universal-slider/images/slide-cleaning2014.jpg" title="Cleaning Supplies"></a>
                        <a href="http://www.shopcrystalrock.com/P479/portal/alias__UniversalBusiness/tabID__51994/DesktopDefault.aspx" target="_parent"></a>
                        </li>
                        <li style="display: none;">
                    <a href="http://www.u-save-more.com/universal-slider/images/slide-crystal-rock.jpg" title="Crystal Rock"></a>
                        <a href="http://www.shopcrystalrock.com/P479/portal/alias__UniversalBusiness/tabID__58523/DesktopDefault.aspx" target="_parent"></a>
                        </li>
                    <a href="http://www.u-save-more.com/universal-slider/images/slide-HP.jpg" title="Ink and Toner"></a>
                        <a href="http://www.shopcrystalrock.com/P479/DesktopDefault.aspx?Alias=UniversalBusiness&amp;TabID=18798&amp;Search=hp%20ink%20toner" target="_parent"></a>
                        </li>
              </ul>
          </div>
  <div class="buttons" style="height: 26px;">
            <div class="prev-btn" style="display: none; width: 24px; height: 24px; margin-right: 5px;"></div>
                <div class="play-btn" style="display: none; width: 24px; height: 24px; margin-right: 5px;"></div>
            <div class="next-btn" style="display: none; width: 24px; height: 24px; margin-right: 5px;"></div>
            </div>
        </div>
    </div>
</div>
<div align="center"></div>
tp thread is tp thread
Offline Smasher816
  • HHKB Master
« Reply #259 on: Thu, 20 March 2014, 15:05:32 »
Code: [Select]
It's the Harlem Shake
Offline compgeke
« Reply #260 on: Thu, 20 March 2014, 15:41:12 »
Driving Question
Often, the stories of WWII tell of the great sacrifice and courage of American men. What was the nature of women and minorities' contributions and experiences during this complex time?
Rationale
WWII is an extremely important period in the history of the United States. Countless films and works of literature refer to this period as unifying the many different strands that make up this great nation. However, many contributions made by women and minorities to the war went unnoticed or were taken for granted. In addition, this was one of America's darkest periods, when U.S. citizens were imprisoned out of mistrust and the lives of countless Japanese Americans were devastated. While men were fighting the war effort on countless campaigns abroad, thousands of American women and minorities also worked and sacrificed so that victory in WW II could be ours.
Groups
You will work in a group of 4-6 people.
Project Overview
Your group will be pitching a television series, focusing on women and minorities during WWII. Your group will give an outline of each episode, including the subject, topics, and why each should be included. You will decide on the number of episodes in the series, the length of each episode and even the cover design for each episode.  As a group, you will focus on one the following topics in your series and read a relevant memoir:
MINORITY GROUP TOPICS
•   Japanese American Internment
•   Tuskegee Airmen
•   Navajo Code Talkers
•   Women on the Homefront
•   Japanese American 442nd Regimental Combat Team & 100th Battalion
In addition, each group member will choose one of the following approaches for research and a report. Each person will be the designated "expert" on this approach and will be responsible for creatively incorporating it into the television series proposal. You may choose to work individually or to pair with one group member to research and write a report related to:
RESEARCH REPORT APPROACHES
•   The discrimination limitations imposed upon the minority group/women
•   The experience of an individual (other than the main character in the book)
•   The legacy/lasting impacts made by the minority group/women over time
•   The contributions of the minority group/women to the war effort
•   The public’s perception and interactions with the minority group/women
GROUP TASKS
1. Submit an extensive written outline of each episode (2-3 pages per episode), complete with explanations and definitions (keep in mind that you will be pitching to people who might not know about your topic), cover designs and Works Cited in MLA format. Note: No outline will be accepted without a properly completed Works Cited page. Projects will be considered late until the Works Cited is submitted.
2. Make a 10-minute persuasive pitch for the television series that you have outlined. Each member of the group must participate in the pitch. It will be your group's choice on how each member will be contributing. Remember, your pitch must include a brief synopsis of each episode, including the topic, historical material covered and why it should be included in your series. More detailed presentation guidelines to come.
INDIVIDUAL (or PARTNER) TASKS
1. Each group member will choose one of the five approaches to the research report. You will need to do extensive research on this topic and read a corresponding book, as you will be the expert when it comes to creating the pitch, and the written episode outline. You may work individually or with one partner.
3. Compile a final report (2-3 pages) on your topic (individually or with one partner). This should later be used to help your group create the written outline of each episode.
EXTRA CREDIT
If your group would like extra credit, you can create a movie trailer of 1-2 minutes to go along with your pitch. This is to be completed outside of class time, and you will be responsible for the resources necessary to create and complete it. If you are thinking about doing this, be sure to clear it with the teachers first, and no later than one week before your pitch is due. No exceptions.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #261 on: Thu, 17 April 2014, 18:58:24 »
Offline paicrai
  • mindblank
« Reply #262 on: Thu, 17 April 2014, 19:02:55 »
Amon Amarth
Alestorm
Eluveitie
Ensiferum
Feuerschwanz
HammerFall
Omnia
Rabenschrey
Saltatio Mortis
Schandmaul
Skyclad
Tenacious D
Turisas
Týr
Vroudenspil
Vogelfrey
THE FEMINIST ILLUMINATI
Offline Pacifist
  • on hiatus
« Reply #263 on: Thu, 17 April 2014, 19:03:45 »
19
Offline katushkin
  • Just the guy
« Reply #264 on: Thu, 17 April 2014, 20:12:31 »
Amon Amarth
Alestorm
Eluveitie
Ensiferum
Feuerschwanz
HammerFall
Omnia
Rabenschrey
Saltatio Mortis
Schandmaul
Skyclad
Tenacious D
Turisas
Týr
Vroudenspil
Vogelfrey
All I recognise there is Tenacious D
Offline paicrai
  • mindblank
« Reply #265 on: Thu, 17 April 2014, 20:14:24 »
Amon Amarth
Alestorm
Eluveitie
Ensiferum
Feuerschwanz
HammerFall
Omnia
Rabenschrey
Saltatio Mortis
Schandmaul
Skyclad
Tenacious D
Turisas
Týr
Vroudenspil
Vogelfrey
Hella rad.
Offline thesentinel
« Reply #266 on: Thu, 17 April 2014, 21:12:11 »
Keyboards are the only thing keeping me from consuming human flesh.
Offline paicrai
  • mindblank
« Reply #267 on: Sun, 27 April 2014, 18:40:29 »
I can do that
(i **** you not and i have no idea why that was on my clipboard)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #269 on: Sun, 27 April 2014, 19:40:54 »
Offline avtar
« Reply #270 on: Mon, 28 April 2014, 01:21:20 »
x240
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #271 on: Mon, 28 April 2014, 05:04:17 »
/home/greymon/pkglist.txt
(I'm installing Manjaro Linux on an SSD tomorrow, so I gotta have my packages in order)
If today had been a hippo, then you'd really have to worry about tomorrow.
« Reply #272 on: Mon, 28 April 2014, 05:06:20 »
ª
Offline feizor
« Reply #273 on: Wed, 30 April 2014, 06:28:27 »
Offline Frenir
  • HHKB Viking
« Reply #274 on: Wed, 30 April 2014, 07:35:30 »
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #275 on: Wed, 30 April 2014, 07:56:44 »
« Last Edit: Mon, 12 May 2014, 12:05:12 by Signature »
Offline hwood34
  • underwater squad
  • #1 CL stan
Offline zippox
« Reply #277 on: Wed, 30 April 2014, 20:41:11 »
             _,     _   _    ,_
           o888P     Y8o8Y     Y888o.
         d88888      88888      88888b
       ,8888888b_  _d88888b_  _d8888888,
       888888888888888888888888888888888
        Y8888P"Y888P"Y888P-Y888P"Y88888'
         Y888   '8'   Y8P   '8'   888Y
          '8o          V          o8'
Offline lightsout714
« Reply #278 on: Wed, 30 April 2014, 20:43:47 »
Full set? We will never hit the MOQ.
Sure we will.  Or are you just crapping the thread because you want your more expensive set to be successful.  I'd rather buy a marginally more expensive full set and would definitely be down.  Hell, if we had a $100 full set, I'd be down for two or three, even if I just resold one or two later.
What happened to last Ivan's fullset GB?
Offline Vibex
  • Love y'all
« Reply #279 on: Wed, 30 April 2014, 20:49:03 »
HTC Shift X9500
Offline n0rvig
« Reply #280 on: Wed, 30 April 2014, 21:37:53 »
[4:25] Decoding of G3 Movement.mp3 fin
« Reply #281 on: Wed, 30 April 2014, 21:43:40 »
Ultrasonic reactor for biodiesel production: http://www.hielscher.com/biodiesel_transesterification_01.htm
Winter grade palm oil biodiesel: http://www.carotino.com/enffue/
Market for Palm Biodiesel image: http://news.mongabay.com/2007/0403-oil_palm.html
Westfalia Separater, Cross-Flow Filtration – Ceramic Membrane Elements and Membrane Filtration Systems, GEA Westfalia, 2013, http://www.westfalia-separator.com/no_cache/products/cross-flow-filtration.html
National Biodiesel Accreditation Program, http://www.bq-9000.org/
SmartFlow Technologies, Phoenix-M Tangential-Flow Filtration System, 2013, http://www.smartflow-tech.com/index.php?main_page=page&id=21&chapter=1
Wonder what I'm doing here...   :rolleyes:
« Reply #283 on: Wed, 30 April 2014, 22:31:26 »
Offline Coreda
« Reply #284 on: Fri, 09 May 2014, 03:39:47 »
they used the medical equivalent of a deli slicer to shave Molaison’s brain into 2,401 slices, each of which they mounted on a glass plate and photographed at 20x magnification, to form a digital, zoomable map down to the level of individual neurons. The slicing process was broadcast live online, and 400,000 people tuned in to say goodbye to H.M.
« Reply #285 on: Fri, 09 May 2014, 05:15:54 »
Offline James35
« Reply #286 on: Fri, 09 May 2014, 05:42:51 »
Salsa Rio Doritos
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #287 on: Fri, 09 May 2014, 06:36:19 »
Offline feizor
« Reply #288 on: Sun, 11 May 2014, 04:26:06 »
KRYTOX GPL-105
Offline epzy
  • HHKB Fiend
  • ded
« Reply #289 on: Sun, 11 May 2014, 04:29:10 »
Niggas already know, Q low key
Niggas already know, Q OG
Niggas already know, Q get high
Niggas already know, Q stay fly
Niggas already know, I sips that lean
Niggas already know, I gets that cream
Niggas already know, TDE the team
Niggas already know, the champs got a ring
Niggas already know, I run this ****
Niggas already know, I ****ed your *****
Niggas already know, I am that nigga
One more time boy, I am that nigga
Niggas already know, the set got high
Niggas already know, who wig got popped
Niggas already know, I sold that Ox'
Niggas already know, I am that block
Niggas already know, the cops got on us
Niggas already know, stash those burners
Niggas already know, run if you're cornered
Niggas already know, high to the morning
Niggas already know, Q gotta chill
Niggas already know, Q off a pill
Niggas already know, Q keep it real
Niggas already know, Q on a mill
Offline Pinder
65g zealios ergodox infinity
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #291 on: Sun, 11 May 2014, 16:08:14 »
|||My other keyboards :
x
« Reply #292 on: Sun, 11 May 2014, 16:33:15 »
Offline slickmamba
« Reply #293 on: Sun, 11 May 2014, 17:11:37 »
for(int x = 0; x < this.getWidth()-1; x+=2)
Hi :)
Offline thesentinel
« Reply #294 on: Sun, 11 May 2014, 17:26:29 »
Offline ComradeSniper
  • HHKB Pro
« Reply #295 on: Sun, 11 May 2014, 17:47:47 »
Did you know. The African Tree Whale is a special breed of whale. It is usually found within the deep safari and will mostly likely be found feeding on Nigerian Tree Leopards. Only 3 have been reported seen and they weigh up to One- Quadrillion Tons. If you're lucky you will find one in the deep heart of the african Safari where snakes thrive and Whales prosper.
Offline eddie
« Reply #296 on: Sun, 11 May 2014, 21:36:42 »
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #297 on: Mon, 12 May 2014, 07:32:31 »
Wyeast 1187
Offline epzy
  • HHKB Fiend
  • ded
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #299 on: Tue, 13 May 2014, 00:45:58 »
