Author Topic: Ctrl+V, then hit post  (Read 242196 times)
Offline trenzafeeds
  • **** off
Re: Ctrl+V, then hit post
« Reply #600 on: Mon, 30 November 2015, 03:48:03 »
Green 45-50
Orange 55-60
Blue 65
Brown Linear 60-65
Amber 80
****ing classic E3E
demik will never leave.
Unless he gets banned.
Offline E3E
« Reply #601 on: Tue, 01 December 2015, 05:54:30 »
Green 45-50
Orange 55-60
Blue 65
Brown Linear 60-65
Amber 80
****ing classic E3E
Hahahaha... You know me!
Offline Fiery
  • Click Clack Clock and a nice Thock
TP4 fanboy
Offline 27
  • The Maple Man
« Reply #603 on: Tue, 01 December 2015, 13:10:22 »
726.3
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline Siegx
« Reply #604 on: Thu, 03 December 2015, 03:44:19 »
14,747.71   -   85,252.29
Offline swimmingbird
  • keyset hoarder
« Reply #605 on: Thu, 03 December 2015, 06:32:55 »
feature=youtu.be&t=1m32s
« Reply #606 on: Thu, 03 December 2015, 19:49:33 »
airyplanner laos sole co
Offline ANightOnCloudNine
« Reply #607 on: Fri, 04 December 2015, 23:17:37 »
holy **** that's hilarious.
Offline Gaspar
« Reply #608 on: Fri, 04 December 2015, 23:41:39 »
White God 2014 HUNGARI 1080p BRRip x264 DTS-JYK
Offline Lokomotivet
  • (⌐■_■)
« Reply #609 on: Thu, 10 December 2015, 09:14:04 »
o
| ISO |
Offline xondat
  • i'm not a star
« Reply #610 on: Thu, 10 December 2015, 15:48:49 »
85.236.101.5:10657
ts3 i chill in
  • Live long and prosper
« Reply #611 on: Thu, 10 December 2015, 15:55:55 »
at 3:45, at first glance it looked like he threw a cat in there
tp thread is tp thread
« Reply #613 on: Fri, 11 December 2015, 09:14:23 »
Offline FLFisherman
  • I'd rather be fishing.
« Reply #614 on: Fri, 11 December 2015, 09:16:30 »
mg279q
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #615 on: Fri, 11 December 2015, 10:01:48 »
 public int compareTo(Fraction f)
      if
      ((f.asDecimal()-asDecimal())>0)
        return 1;
        else if
        ((f.asDecimal()-asDecimal())<0)
           return -1;
        else
           return 0;
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #616 on: Fri, 11 December 2015, 12:41:45 »
Code: [Select]
url := r.FormValue("url")
opts := r.FormValue("opts")
res, err := http.Get(url)
if err != nil {
handleError(w, r, 500, err.Error())
return
defer res.Body.Close()
cmd := exec.Command("lpr", opts)
cmd.Stdin = res.Body
err = cmd.Run()
if err != nil {
return
Golang code that sends a file from a URL directly to a local printer buffer.
« Reply #617 on: Fri, 11 December 2015, 12:49:25 »
359721056263773
Offline Lurch
« Reply #618 on: Fri, 11 December 2015, 13:13:58 »
The system should have automatically cleared your flag by now. Please reply to this message to reopen the ticket if there is still an issue. Thanks!
Quote from: Flyersfan1
Offline trees
  • I like bagels.
« Reply #620 on: Fri, 11 December 2015, 14:28:52 »
Code: [Select]
Select Case sValue
                    Case 5    'Older SDK
                        labStatus.Text = "Getting data from old clock " + vIP + "  System Options = " + sValue + "  Platform = " + sPlatform
                        labStatus.Refresh()
                        'Pause clock
                        CZKEM1.Beep(150)
                        CZKEM1.ClearLCD()
                        CZKEM1.EnableClock(0)
                        CZKEM1.WriteLCD(0, 0, "   One moment")
                        CZKEM1.WriteLCD(1, 0, "    please")
                        CZKEM1.WriteLCD(2, 0, "  Punches are")
                        CZKEM1.WriteLCD(3, 0, " being uploaded")
                        While CZKEM1.GetGeneralExtLogData(vMachineNumber, dwEnrollNumber, dwVerifyMode, dwInOutMode, YYYY, MM, DD, HH, MN, SS, dwWorkCode, dwReserved)
                            i += 1
                            PunchDate = Strings.Right("0" & Trim(Str(MM)), 2) & "/" & Strings.Right("0" & Trim(Str(DD)), 2) & "/" & Trim(Str(YYYY))
                            PunchTime = Strings.Right("0" & Trim(Str(HH)), 2) & ":" & Strings.Right("0" & Trim(Str(MN)), 2)
                            timeStr = PunchDate & " " & PunchTime
                            dwWorkCode = dwWorkCode / 100
                            'dwWorkCode = 99999   '<============== debugging code
                            strSQL = "insert into CLOCKPUNCHES (BadgeID, ClockID, dwInOutMode, dwWorkCode, ClockPunchesDate, ClockPunchesTime, ClockPunchesIP, ClockPunchesUploadTime, ClockPunchesSession, ClockPunchesClientBatch, RunitID) " _
                                    & "values('" & dwEnrollNumber & "'," & CLng(vMachineNumber) & "," _
                                    & dwInOutMode & "," & dwWorkCode & ",'" & PunchDate & "','" & PunchTime & "','" & vIP & "','" & Now & "'," & vSessionBatch & "," & vClientBatch & "," & vRunit & ")"
                            'MsgBox(strSQL)   '<============== debugging code
                            Dim sqlPunch As New System.Data.SqlClient.SqlCommand(strSQL, conPunch)
                            sqlPunch.ExecuteNonQuery()
                        End While
                        CZKEM1.EnableClock(1)    'Unpause clock
                    Case 9    'Newer SDK
                        'MsgBox("New clock")
                        labStatus.Text = "Getting data from NEW clock " + vIP + "  System Options = " + sValue + "  Platform = " + sPlatform
                        labStatus.Refresh()
                        'CZKEM1.PlayVoiceByIndex(6)
                        CZKEM1.EnableDevice(vMachineNumber, False) 'disable the device
                        If CZKEM1.ReadGeneralLogData(vMachineNumber) Then 'read all the attendance records to the memory
                            'get records from the memory
                            While CZKEM1.SSR_GetGeneralLogData(vMachineNumber, dwEnrollNumber, dwVerifyMode, dwInOutMode, YYYY, MM, DD, HH, MN, SS, dwWorkCode)
                                i += 1
                                'If i = 3 Then Exit While '<============== debugging code
                            End While
                        End If
                        CZKEM1.EnableDevice(vMachineNumber, True) 'enable the device
                End Select
Slice of VB to download internet based timeclocks.
B.Face HHKB - B.mini - Black/Purple Custom
« Reply #621 on: Fri, 11 December 2015, 22:42:16 »
3.385 per day
Offline thatsmrdoctortoyou
  • Dingo babies
    • IG
« Reply #622 on: Fri, 11 December 2015, 23:00:34 »
LA004158171FR
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #623 on: Fri, 24 June 2016, 15:02:16 »
Pepé Le Pew
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #624 on: Fri, 24 June 2016, 17:09:11 »
BMO
« Reply #625 on: Fri, 24 June 2016, 17:21:29 »
,"Home","End","Insert"
Offline xondat
  • i'm not a star
« Reply #626 on: Fri, 24 June 2016, 17:30:27 »
Offline Waateva
« Reply #627 on: Fri, 24 June 2016, 21:11:26 »
Offline sncbraxsc2
« Reply #628 on: Fri, 24 June 2016, 21:50:21 »
perfect for when you love to party but also love Jesus
Offline Waateva
« Reply #629 on: Fri, 24 June 2016, 23:10:21 »
It's so incredibly terrible
Offline SBJ
  • Tactile pls
« Reply #630 on: Sat, 25 June 2016, 01:19:42 »
travCLINK
Offline clankgy1
  • Formerly digifiend
« Reply #631 on: Sat, 25 June 2016, 02:01:47 »
(11.6 x 4.3 x 1.6in)
RF87U 55g (damaged)  |  AV3 w/POM Plate  |  Thermal (to be built)  |  ID80v1 (to be rebuilt)  |  Tokyo60
« Reply #632 on: Sat, 25 June 2016, 21:59:30 »
Warning: TotalTerminal is no longer under active development
Offline morkha
  • Dingo babies
    • IG
« Reply #634 on: Sun, 26 June 2016, 04:12:23 »
vagal
« Reply #635 on: Sun, 26 June 2016, 04:56:14 »
"It's the old, old story; droid meets droid, droid becomes chameleon, droid loses chameleon, chameleon turns into blob, droid gets blob back again, blob meets blob, blob goes off with blob and droid loses blob, chameleon and droid. How many times have we seen that story?"
Offline dgneo
  • Supervillain
Offline Waateva
Offline funderburker
« Reply #639 on: Sun, 26 June 2016, 14:02:19 »
Keyboard design by Skepur
« Reply #640 on: Sun, 26 June 2016, 21:48:18 »
(nothing - my clipboard seems to be empty)
Offline SBJ
  • Tactile pls
« Reply #641 on: Mon, 27 June 2016, 01:43:25 »
LZS98245905U5  :cool:
Offline clankgy1
« Reply #642 on: Tue, 28 June 2016, 19:37:17 »
The PS/2 bus natively handles NKRO. USB natively only supports 6KRO.
(still confused as hell about this)
Offline zcmy
  • I really should be working... not "working"
« Reply #644 on: Tue, 28 June 2016, 19:53:53 »
URM
(talking about college admissions)
« Reply #645 on: Tue, 28 June 2016, 21:50:34 »
"java.lang:type=ClassLoading",UnloadedClassCount
Offline Dongulator
« Reply #646 on: Tue, 28 June 2016, 21:56:08 »
Offline SBJ
  • Tactile pls
Offline Fiery
« Reply #648 on: Fri, 02 September 2016, 03:33:43 »
atnoheutnahoeu
TP4 fanboy
« Reply #649 on: Fri, 02 September 2016, 03:47:59 »
