Author Topic: LF Switch Change Tutorial  (Read 4841 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« on: Fri, 08 March 2013, 16:58:10 »
I would like to change my Red switch on my space bar to a Cherry MX Black switch. Are there any detailed tutorials out there that can walk me through the process? Also, is it difficult for a beginner?
Offline The_Beast
  • I like wood ಠ_๏
Re: LF Switch Change Tutorial
« Reply #1 on: Fri, 08 March 2013, 17:00:41 »
Is the keyboard plate mount or PCB mount?
Offline OnTheBrink
    • Wired In Store
« Reply #2 on: Fri, 08 March 2013, 17:11:07 »
I am not sure. It's a Ducky Shine II and I think it is double PCB mounted.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Fri, 08 March 2013, 17:21:11 »
Plate mount looks like this:
http://images1.chiefvalue.com/productimage/ce00158448010060-9.jpg
PCB mount looks like this:
http://i89.photobucket.com/albums/k221/undarken/G80-3494/CherryField.jpg
Another picture:
http://www.cherrycorp.com/english/switches/key/images/mx_mntop.gif
If the keyboard is PCB mount, you should be able to remove the switch top with a couple of screw drivers. If it's plate mount, then it will require desoldering
Offline WhiteFireDragon
    • youtube
« Reply #4 on: Fri, 08 March 2013, 17:26:02 »
Your ducky is plate-mounted. It has all SMD components on one side, but the soldering pads for switches are double sided and goes through holes, unlike some cheaper PCBs. This is my tutorial, it's pretty detailed but there is an index that you can jump around in the description:
http://www.youtube.com/watch?v=VQ_2GxeR4Es
Offline badcop
  • thorpe thocking master race
« Reply #5 on: Tue, 12 March 2013, 08:31:19 »
WFD is the man.  i watched this at like 4am one morning and it gave me all the information i needed.  TY
Offline OnTheBrink
    • Wired In Store
« Reply #6 on: Tue, 12 March 2013, 12:30:21 »
Ya WFD is clutch. His video was the nail in the coffin for my Ducky Shine 2 purchase and I couldn't be happier.
Offline OnTheBrink
    • Wired In Store
« Reply #7 on: Thu, 21 March 2013, 10:35:43 »
Quick question about this, couldn't I just pop out the switch itself and swap the spring and switch?
I am not sure if this will make it as stiff as changing out the entire switch, but I just want to make the spacebar more stiff and voiding the warranty of the item and doing all that soldering work is something I'd like to avoid.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Thu, 21 March 2013, 10:36:50 »
Nope, you have to desolder. The OEM plate does not have the cutouts to allow you to take the top of the switch off
