Author Topic: #%$*  (Read 15049 times)
Offline Lunartuna
  • Good bye money!
« on: Sun, 17 March 2013, 17:00:12 »
Shine 2 TKL - Choc Mini
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
Re: #%$*
« Reply #1 on: Sun, 17 March 2013, 17:00:52 »
Well uh... that sucks. The wire pullers are much better.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
Re: #%$*
« Reply #2 on: Sun, 17 March 2013, 17:02:17 »
i have 4 of these silly plastic pullers, 3 of them are broke like this
wire puller for the win
Offline lazerpointer
  • ya gotta stay phresh
Re: #%$*
« Reply #3 on: Sun, 17 March 2013, 17:02:23 »
If you have to, you can use one of those little wire twisties they use to seal the loaf of bread. I've done it... frustrating, yet effective.
i type, therefore i geekhack
Offline Glissant
Re: #%$*
« Reply #4 on: Sun, 17 March 2013, 17:03:12 »
<3 1500
15982-0
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: #%$*
« Reply #5 on: Sun, 17 March 2013, 17:03:36 »
http://www.harborfreight.com/5-piece-auto-trim-and-molding-tool-set-67021.html
The second on the left is so much better for trying to swap an entire board's worth of caps.
Offline mistakemistake
  • Global Loveinator
Re: #%$*
« Reply #6 on: Sun, 17 March 2013, 17:04:47 »
Techkeys sells a pretty cool one:
http://www.techkeys.us/accessories.php
Offline Lunartuna
  • Good bye money!
Re: #%$*
« Reply #7 on: Sun, 17 March 2013, 17:10:30 »
Guess I have to buy a wire one now!
At least I didn't get far.
Esc, pull, F1, snap.
 :rolleyes:
« Last Edit: Sun, 17 March 2013, 19:39:03 by Lunartuna »
Offline The_Beast
  • I like wood ಠ_๏
Re: #%$*
« Reply #8 on: Sun, 17 March 2013, 17:13:29 »
Those tend to scratch your caps as well. You should be glad that you broke it :P
Offline GeorgeK
Re: #%$*
« Reply #9 on: Sun, 17 March 2013, 17:15:16 »
Wire all the way for me - feng's stainless steel puller is my favourite :D
Offline Grim Fandango
Re: #%$*
« Reply #10 on: Sun, 17 March 2013, 17:45:32 »
Yeah, not everyone agrees on this. Or at least I have seen people say they do not agree. But I like the wire pullers much more. I have a filco one.
« Reply #11 on: Sun, 17 March 2013, 18:06:44 »
My favorite tool is from Harbor Freight. They are called "dental picks" and sold in a pack of 5 for like $3. The curved one that actually looks like a dental pick is the only one of any use, but it's worth the $3.
I wouldn't use them for cleaning my teeth, but for pulling keycaps, they are super fast and reliable.
Offline WhiteFireDragon
    • youtube
Re: #%$*
« Reply #12 on: Sun, 17 March 2013, 18:27:39 »
Those clip-type pullers are worthless anyways. Either your caps will break, or that clip will break, so it was a blessing in disguise.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: #%$*
« Reply #13 on: Sun, 17 March 2013, 18:54:32 »
Yes those suck. They break super easy. I only had one good plastic one, it never scratched or harmed a keycap, and simply wore out instead of broke.
15989-0
The little tabs that grasped the underside of the key wore off totally. It was the first not home made keypuller I had and it came free with some keycap I bought from someone long ago. I have the wire Cherry one with the switch in it now.
Offline deSheol
  • Thorpe
Re: #%$*
« Reply #14 on: Mon, 18 March 2013, 01:30:30 »
that tends to happen, bro. get a wire keypuller!
Offline calavera
Re: #%$*
« Reply #15 on: Mon, 18 March 2013, 01:32:39 »
I think that happens to all of them eventually. Those plastic ones suck.
Offline WarNutts
Re: #%$*
« Reply #16 on: Mon, 18 March 2013, 06:19:44 »
lol that sucks man!
Offline rurushu
Re: #%$*
« Reply #17 on: Mon, 18 March 2013, 09:56:51 »
I am actually glad that you broke it, coz now you can save your future keys from scratches!!! (sincerely, not being sarcastic or anything)
that thing is a potential keycaps scratcher, especially for caps with polished coating...
wire keypuller is the way to go!!!! I'm using a filco one....
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
Re: #%$*
« Reply #18 on: Mon, 18 March 2013, 10:39:12 »
I'm cheap. Paper clips for me.
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Re: #%$*
« Reply #19 on: Mon, 18 March 2013, 10:49:43 »
I use paper clips all the time, when I don't have my dental pick handy. :)
Offline SmallFry
Re: #%$*
« Reply #20 on: Mon, 18 March 2013, 11:19:07 »
I keep a wire puller on my keys, took a WASD one, cut it down with my handsaw and drilled a new hole for the keyring. Works really well when I'm on the move.
Offline nullstring
Re: #%$*
« Reply #21 on: Mon, 18 March 2013, 11:42:34 »
only on geekhack would you find someone who would need to exchange keycaps while "on the move"
Re: #%$*
« Reply #22 on: Mon, 18 March 2013, 11:47:22 »
You never know when you might find a strange keyboard while out and about, and need to pull a keycap to see what type of switches it has. :D
Offline Lunartuna
  • Good bye money!
Re: #%$*
« Reply #23 on: Mon, 18 March 2013, 12:50:56 »
Great so now I need 2!  :p
Re: #%$*
« Reply #24 on: Wed, 20 March 2013, 08:19:31 »
A keycap puller on your car key chain may be odd, but not illegal. A beer bottle opener associated with car keys always seemed a bit incriminating.
When a fool gains power, the first thing he does is silence the wise.
The Next thing he does is gather other fools around him.
The final thing he does is destroy the Nation.
- Plato
Offline baldgye
  • Will Smith Disciple
Re: #%$*
« Reply #25 on: Wed, 20 March 2013, 08:23:29 »
Those plastic ring things have always looked super bad, but I've only ever used a wire-puller
Offline ideus
  • Björkö.
Re: #%$*
« Reply #26 on: Wed, 20 March 2013, 08:27:05 »
But you lost your WASD geek logo  :) . You have to scribe a new one in the plastic left over.
Offline Jocelyn
  • 조셀린
Re: #%$*
« Reply #27 on: Wed, 20 March 2013, 08:28:41 »
It's okay, he didn't pay for it :)
Offline alaricljs
  • I be WOT'ing all day...
Re: #%$*
« Reply #28 on: Wed, 20 March 2013, 08:30:34 »
For a while before I bothered getting a real puller I was using a length of string.  Bit niggly to get settled around a keycap (2 loops, on for either side just like a normal puller) but a whole lot easier than using just my fingers.
Filco w/ Imsto thick PBT
Offline SmallFry
Re: Re: #%$*
« Reply #29 on: Wed, 20 March 2013, 08:35:44 »
I gave that puller to my boss and convinced him to get a board... :D
Re: #%$*
« Reply #30 on: Wed, 20 March 2013, 08:38:04 »
SmallFry, it's not nice to hack people's wallets :P
Offline Jocelyn
  • 조셀린
Re: Re: Re: #%$*
« Reply #31 on: Wed, 20 March 2013, 08:40:32 »
lol definitely for a good cause :)
Offline SmallFry
Re: #%$*
« Reply #32 on: Wed, 20 March 2013, 08:52:29 »
Psh, I'll hack wallets all I want CPTBadAss!
Offline ideus
  • Björkö.
Re: Re: Re: #%$*
« Reply #33 on: Wed, 20 March 2013, 08:52:46 »
Then, he will assign you the project of upgrading his key-chain-cap-puller with the proper GH identifier / logo.
Offline justin one
Re: #%$*
« Reply #34 on: Wed, 20 March 2013, 13:08:19 »
This also happened to my plastic puller. I have a few wire pullers but they feel clunky to use. I prefer the plastic pullers.
[ KBC Poker ] [ Ducky DK9087 ]
