Author Topic: Decent cherry caps  (Read 3355 times)
Offline Mugen
  • O-Rings are the murderers of keyboard souls
Re: Decent cherry caps
« Reply #1 on: Sun, 17 March 2013, 17:44:59 »
Do you know what switches these boards have?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Sun, 17 March 2013, 17:45:31 »
Both are MY switches
Offline whiskytango
  • Don't touch the trim
« Reply #3 on: Sun, 17 March 2013, 17:57:57 »
wasn't there a thread a while back where somebody went to Ocean Tech and cleaned them out of all the boards that were in good or decent shape to distribute them to members here?
I thought I remembered reading that all the boards left there were in bad shape.
Offline bavman
« Reply #4 on: Sun, 17 March 2013, 18:00:55 »
If you look really closely at the Esc key you can see your reflection
Offline The_Beast
  • I like wood ಠ_๏
« Reply #5 on: Sun, 17 March 2013, 18:03:17 »
Pretty sure that was inlikeflynn
Offline whiskytango
« Reply #6 on: Sun, 17 March 2013, 18:03:57 »
http://geekhack.org/index.php?topic=37672.0
I found the thread I was thinking of. Check reply #42
Maybe they got some more in by now?
Edit: Yeah it was inlikeflynn, good call
« Last Edit: Sun, 17 March 2013, 18:06:11 by whiskytango »
Offline tinlong117
« Reply #7 on: Sun, 17 March 2013, 20:26:29 »
the f row of 7000 LPBUS is dyesub.
Offline ideus
  • Björkö.
« Reply #8 on: Sun, 17 March 2013, 20:30:06 »
I just bought one caps set from them, I will let you know how they look like when they arrived.
« Reply #9 on: Sun, 17 March 2013, 20:32:47 »
They are SP; pretty common for many of these.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #10 on: Sun, 17 March 2013, 20:35:27 »
I bought one of the white on black boards they had.  $10 + shipping seemed like a good deal for what I'd be getting out of it.  Hopefully the caps aren't garbage.
For the moment at least, they're going on a poker for me.  They may spend a photo session on a mx-mini, but yeah.  I may use it as an opportunity to check out the gradient F row from SP or just use my novelty stuff up there anyways.
« Reply #11 on: Sun, 17 March 2013, 20:40:36 »
I have a set from inlikeflynn.
Offline SmallFry
Re: Re: Decent cherry caps
« Reply #12 on: Sun, 17 March 2013, 21:26:59 »
Me too, the only problems for me were the Escape (replaced with a red one), the F8 key for some odd reason and the down arrow has a bit of shine. Very nice for $15.
