Author Topic: 67g Korean Springs?  (Read 3608 times)
67g Korean Springs?
« on: Mon, 18 March 2013, 23:23:18 »
I've been searching for some Korean springs since Sherryton has gone silent on me about 65g springs and I stumbled across this thread at KBDMania: http://www.kbdmania.net/xe/index.php?mid=purchase&document_srl=6027801&6027801_cpage=1
If I'm reading that correctly, they were testing out some 67g springs.  Has anyone actually gotten their hands on 67g springs?
Re: 67g Korean Springs?
« Reply #1 on: Wed, 20 March 2013, 19:35:21 »
Little self bump.
Are these 67g springs a real thing or are they something that we won't ever really see?
Offline WhiteFireDragon
    • youtube
« Reply #2 on: Fri, 22 March 2013, 07:45:11 »
I've personally never seen them in use. Highest is 65g, and if someone wants a tad stiffer, it's usually vintage blacks.
Offline Tarzan
  • formerly known as Greystoke
« Reply #3 on: Fri, 22 March 2013, 09:40:46 »
Bro Caps offered me some 80g springs.  Haven't seen them yet, so I can't confirm they're really that heavy.   :(
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #4 on: Fri, 22 March 2013, 09:43:19 »
Question is whether one could really tell the difference between 65 and 67. :P
Offline davkol
  •  Post Editing Timeout
« Reply #5 on: Fri, 22 March 2013, 10:41:11 »
Aren't springs in MX Black basically 80g? I'd appreciate something like 70g.
Offline khaangaaroo
« Reply #6 on: Fri, 22 March 2013, 12:04:14 »
I thought vintage blacks springs were lighter than modern blacks.
« Reply #7 on: Fri, 22 March 2013, 12:09:37 »
I'm waiting to test the 63.75g springs.  I don't know how anyone could stand to use anything else
Offline Tarzan
« Reply #8 on: Fri, 22 March 2013, 12:26:04 »
Ah, you obviously haven't tried the 61.275g springs! Simply the best!
 :p
Offline Skull_Angel
« Reply #9 on: Fri, 22 March 2013, 16:05:54 »
Has anyone posted weighting on Vintage Blacks? I'm normally pretty good about numbers, but don't remember anything about them other than "lighter than modern Black, but heavier than Red".
Offline khaangaaroo
« Reply #10 on: Fri, 22 March 2013, 16:12:30 »
Offline Skull_Angel
« Reply #11 on: Fri, 22 March 2013, 16:37:30 »
60~63 actuation force... That's about the same as what's been recorded for modern Blacks iirc.
Could it be that they use a different spring design? That would account for a lighter feel for the first 2mm travel.
