Author Topic: Dolch PCB into a G81-1800 Case  (Read 2424 times)
Offline Michael
  • Formerly Bro Caps
« on: Wed, 20 March 2013, 00:42:11 »
Is this possible? Are they roughly the same size PCB?
Offline calavera
Re: Dolch PCB into a G81-1800 Case
« Reply #1 on: Wed, 20 March 2013, 00:55:44 »
I remember someone swapping the dolch internals into a regular 1800 case so it should be a simple job but I can't confirm it.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Wed, 20 March 2013, 07:17:17 »
Yes they use the identical PCB. The only quirk is the lock lights are on another daughter board in Dolch and it's a bit fiddly to get aligned inside the standard 1800 case. I changed mine into 1800 case and hard solder ps/2 cable.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #3 on: Wed, 20 March 2013, 14:35:25 »
Yes - the Dolch is quite literally a G81-1800 with a daughterboard modification. As in, they took the G81-1800 as-is and put it in a new chassis, no controller changes at all. (I used to use a PAC62 on a near daily basis.) That's why it's a connector adapt rather than a logic adapt.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline calavera
« Reply #4 on: Wed, 20 March 2013, 15:06:27 »
Do you have to remove the DOLCH logo on top to open the case?
« Reply #5 on: Wed, 20 March 2013, 15:17:23 »
Yes, there's a screw under there
« Reply #6 on: Wed, 20 March 2013, 17:48:25 »
Oh, another thing... put that G81 plate to use as an underplate after remove all the MY switch. It's definitely a task worth doing as it make the keyboard feel much more substantial and less bouncy. Just don't forget to make sure it's totally insulated from the MX pcb.
« Reply #7 on: Wed, 20 March 2013, 17:53:42 »
I prefer to use the Dolch case. It is sturdier than a G8x-1800 case and it is flatter, which I like. In my opinion, the only thing that the G81-1800 case has for it is if you want the keyboard to be inclined.
Besides, the case has the same colour as the Dolch modifiers.
Offline esoomenona
  • Gnillort?
« Reply #8 on: Wed, 20 March 2013, 18:05:02 »
Maybe OP has a Dolch PCB but no case or caps?
Offline khaangaaroo
« Reply #9 on: Wed, 20 March 2013, 18:10:19 »
I remember there being two logos. I think the one on the bottom had a screw, but the one on the top didn't. I could be wrong, but it wouldn't hurt to start with just the bottom logo and see if that does it.
