Author Topic: build quality of cherry vs ducky?  (Read 2844 times)
Offline iri
« on: Fri, 22 March 2013, 14:32:22 »
i'd like to purchase either a Ducky DK9087G2 PRO, or a cherry g80-3000, both brand new. is there a noticeable difference in build quality between ducky and cherry keyboards?
-Ray Bradbury
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: build quality of cherry vs ducky?
« Reply #1 on: Fri, 22 March 2013, 14:34:43 »
PCB vs Plate mount would be the main difference in the feel of either of these.
I don't really follow Ducky but their build quality seems to have greatly improved since they started producing boards a few years ago.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Fri, 22 March 2013, 14:39:58 »
Yes. Ducky have a much higher over all build quality. If you want Cherry best to buy vintage. The older ones are made much better than they do now. The best thing Cherry had going was the doubleshots and dyesubs which they ceased making on production years ago now.
If you just want to try a PCB mount board I would go with the GH60, Poker/Pure, Plum 96 or Neo Zelia instead of a current production G80.
« Last Edit: Fri, 22 March 2013, 14:42:07 by IvanIvanovich »
Offline iri
« Reply #3 on: Fri, 22 March 2013, 14:46:19 »
these boards are both pcb-mounted.
heh, so not vintage switches?
thanks, иван иваныч, you just gave me more options to consider )
-Ray Bradbury
Offline iri
« Reply #4 on: Fri, 22 March 2013, 15:05:32 »
heh, i have to say i liked none of these. though i may get a poker eventually.
-Ray Bradbury
« Reply #5 on: Fri, 22 March 2013, 15:08:23 »
What you should find yourself is a G80-3000SAV. Super sexy.
Offline Skull_Angel
« Reply #6 on: Fri, 22 March 2013, 16:31:46 »
The Ducky is plate mounted, a quick google image search brings up many pictures.
Offline iri
« Reply #7 on: Sat, 23 March 2013, 01:29:27 »
mechanicalkeyboards.com lies then.
-Ray Bradbury
