Author Topic: Looking to buy a tkl board  (Read 4065 times)
Offline phoxxii
« on: Sat, 23 March 2013, 12:55:27 »
Hi guys, first time posting here!
I've been using a Das Keyboard Ultimate, with MX blues, for around 7 or 8 months now, and am looking into getting a new board that is tkl. I type in the Dvorak layout, and really would like either blank keycays stock, or the availibility to purchase blank keycaps. I'm not a huge fan of backlit, as it would have no real effect on me, with the blank keycaps, but have no problem buying a keyboard with backlighting.
I'm considering switching to MX reds, as I play a lot of dota 2 and starcraft.
Some options would be awesome, I have been looking at leopold, also the pure or poker.
Thanks guys!
Offline Lu_e
Re: Looking to buy a tkl board
« Reply #1 on: Sat, 23 March 2013, 13:49:20 »
is a cm storm quick fire rapid in that layout? comes in reds...
Just say NO to ABS keycaps
Offline iri
-Ray Bradbury
Offline iri
« Reply #3 on: Sat, 23 March 2013, 14:17:32 »
can anyone suggest me a pcb-mounted tkl or 75% without backlighting?
-Ray Bradbury
Offline gnubag
« Reply #4 on: Sat, 23 March 2013, 14:25:27 »
pretty much any tkl you can find (regularly).
cm
filco
razer
leopold
kbt
choc mini
and the keycool
come in mind idk if there are others
Offline iri
« Reply #5 on: Sat, 23 March 2013, 14:33:09 »
pcb-mounted. where switches are attached to a printed circuit board and can be opened without desoldering them.
-Ray Bradbury
Offline gnubag
« Reply #6 on: Sat, 23 March 2013, 14:46:51 »
oops my bad
i think there are some keycool or so from china
Offline Bells
« Reply #7 on: Sat, 23 March 2013, 15:35:07 »
I recently bought a CM QFR and i love it!
i can def. recommend it for you!
otherwise take a look on ducky's keyboards :p
my friend bought it for me from Taiwan it's in the mail in a couple of days. :P
Ducky Shine 2 MX Blacks
Offline phoxxii
« Reply #8 on: Sat, 23 March 2013, 15:44:27 »
I think I might be looking at the leopold, but would prefer if i could get it in beige/white, rather than black.  Also, where could I find replacement keys, in a variety of colours? Would they fit on the board fine?
With the Filco, is the USB cable removable?
Thanks again!
Offline Bells
« Reply #9 on: Sat, 23 March 2013, 15:47:25 »
If you're desperately in need of new keycaps, try out WASD's (modify yourself) otherwise take throw a thread on the forum, loads of nice keycaps!
Offline ComradeSniper
  • HHKB Pro
« Reply #10 on: Sat, 23 March 2013, 16:26:26 »
Thanks again!
The Filco does not have a detachable USB cable.
Offline tauburn
« Reply #11 on: Sat, 23 March 2013, 16:27:14 »
Thanks again!
the filco cable is removable inside the case, but not from the outside. so if you want to install a custom cable you can but you cant just unplug it whenever you please.
Offline phoxxii
« Reply #12 on: Sat, 23 March 2013, 20:45:27 »
What about a kbt poker or pure?
Would those be a decent option for gaming/typing? It seems like they have a lot of following with many of the people here...
phoxxii
Offline tauburn
« Reply #13 on: Sat, 23 March 2013, 20:47:56 »
phoxxii
i'd go for the poker out of those two. theyre fine as long as you dont care about numpads
Offline phoxxii
« Reply #14 on: Sat, 23 March 2013, 21:00:55 »
What about this?
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=185
I'd also be able to order a set of blank pbt keycaps. (probably white)
With a poker, are regular sets of keycaps compatible?
Offline Rule16
  • R.I.P. SmallFry
« Reply #15 on: Sun, 24 March 2013, 11:32:15 »
Thanks guys!
You don't need a linear switch for starcraft and dota 2, you can use whatever switch you want. The linear switch thing is just for games where you move around w/ wasd or need to double tap. Even MLG starcraft players just choose whatever switch they think feels best to them.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline babyhands
« Reply #16 on: Mon, 25 March 2013, 12:16:32 »
I PM'd you, I might have just what you want!
Offline phoxxii
« Reply #17 on: Mon, 25 March 2013, 21:12:59 »
Think I'm going to bite the bullet and buy a HHKB2, once I attain the proper funds.
We shall see how that goes!
Offline bazemk1979
« Reply #18 on: Mon, 25 March 2013, 21:33:48 »
OP just sent you PM, you can have NIB TKL with reds for $65 shipped, gave you the nick of the guy that sells them, he is cool and legit :)
