Author Topic: .  (Read 5574 times)
Offline esoomenona
  • Gnillort?
« on: Mon, 25 March 2013, 09:25:53 »
« Last Edit: Wed, 15 October 2014, 19:25:05 by esoomenona »
Offline ishumprod
Re: How exactly does a switch actuate?
« Reply #1 on: Mon, 25 March 2013, 09:33:19 »
pushing the stem down separates the contacts, and that is a keypress.
home-made TKL rubber dome keyboard !
« Reply #2 on: Mon, 25 March 2013, 09:52:39 »
No, it is the other way around. At least with 99% of all keyboard switches out there, including the Cherry MX.
You can see in this animation how a typical Cherry MX switch works:
When not pressed, the slider keeps the contacts apart. Pressing down allows them to contact, and thus close an electric circuit.
« Last Edit: Mon, 25 March 2013, 09:54:20 by Findecanor »
Offline ishumprod
« Reply #3 on: Mon, 25 March 2013, 09:53:41 »
are you sure ??
i twisted my mind when i opened my blue switch =O
« Reply #4 on: Mon, 25 March 2013, 09:56:15 »
The Blue switch is a bit more complex, because the slider consists of two parts. Everything but the slider is the same as in all other Cherry MX switches, though.
Offline esoomenona
  • Gnillort?
« Reply #5 on: Mon, 25 March 2013, 09:58:58 »
« Last Edit: Wed, 15 October 2014, 19:25:24 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #6 on: Mon, 25 March 2013, 09:59:53 »
« Last Edit: Wed, 15 October 2014, 19:25:32 by esoomenona »
« Reply #7 on: Mon, 25 March 2013, 14:59:11 »
When I have my switches apart, if I so much as touch that spring with any force at all, I toss the switch.
Pinching it is quite more than enough to ruin it.  If anything happens to that mechanism, the switch won't work right.
Offline esoomenona
  • Gnillort?
« Reply #8 on: Mon, 25 March 2013, 15:02:09 »
« Last Edit: Wed, 15 October 2014, 19:25:42 by esoomenona »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #9 on: Mon, 25 March 2013, 15:05:55 »
Oh, I'm going to fix it. No matter the time it takes. Because I don't have any soldering equipment to swap it out right now... :/
What key is it?
When modding switches, I always test the switch before I solder. It really only works with tactile switches, but I'll push the switch down a couple times to make sure that I actually feel a bump. If it feels like a linear switch, I know I've bent the leaf and I tend to just replace the whole switch.
Offline esoomenona
  • Gnillort?
« Reply #10 on: Mon, 25 March 2013, 15:25:02 »
« Last Edit: Wed, 15 October 2014, 19:25:49 by esoomenona »
« Reply #11 on: Mon, 25 March 2013, 17:01:52 »
Just replace it.  I'm trying to save you some time
Offline esoomenona
  • Gnillort?
« Reply #12 on: Mon, 25 March 2013, 17:04:52 »
« Last Edit: Wed, 15 October 2014, 19:25:57 by esoomenona »
« Reply #13 on: Mon, 25 March 2013, 17:18:18 »
No the leaf and the pins are one piece.  They are soldered on.
Offline esoomenona
  • Gnillort?
« Reply #14 on: Mon, 25 March 2013, 17:19:26 »
« Last Edit: Wed, 15 October 2014, 19:26:05 by esoomenona »
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #15 on: Tue, 26 March 2013, 04:19:10 »
heh same issue,
i just messed up like 5 of the little contact leaf things inside when i was taking apart my RACE and i cant seem to get them back to normal. looks like that picture you made. This was the first time i've ever done disassembly on a mass scale before, usually i just de-solder everything.  i have some extra pcb-mount switches around so im going to replace (unsolder, solder in new) because it just seems really complicated to fix the contact leaf thing.
Offline esoomenona
  • Gnillort?
« Reply #16 on: Tue, 26 March 2013, 08:59:35 »
« Last Edit: Wed, 15 October 2014, 19:26:13 by esoomenona »
Offline WhiteFireDragon
    • youtube
« Reply #17 on: Sun, 31 March 2013, 02:09:31 »
That metal part sticking out is really fragile. Don't touch it if you ever take your switches apart. If you accidentally bent it somehow, you can rebend it back to original shape, although getting exact is very hard and you depend on a little bit of luck. Even if it looks like how it is before, the middle part that actually make the contact might not be exact. This will cause it to actuate a tad before or after where it's suppose to, and if it's too far off, it won't actuate at all.
how did you bend that spacebar switch in the first place?
Offline esoomenona
  • Gnillort?
« Reply #18 on: Sun, 31 March 2013, 02:36:25 »
« Last Edit: Wed, 15 October 2014, 19:26:21 by esoomenona »
