Author Topic: Some IBM rarities  (Read 6419 times)
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: Some IBM rarities
« Reply #2 on: Fri, 29 March 2013, 20:39:58 »
whaaaat, I've never seen a rack mount model m before...
Offline bazemk1979
« Reply #3 on: Fri, 29 March 2013, 21:00:17 »
green alps I believe
Offline RougeR
« Reply #4 on: Fri, 29 March 2013, 21:09:57 »
saw the industrrial pcjr look a like, domes i think
Buckling spring warrior!
Offline jwaz
  • * based mod
« Reply #5 on: Fri, 29 March 2013, 21:13:52 »
Who got the prototopre?
Offline SmallFry
« Reply #6 on: Fri, 29 March 2013, 21:15:57 »
HaaTa.
Offline RougeR
« Reply #7 on: Fri, 29 March 2013, 21:22:09 »
what on earth is it
New IBM 6247440 Keyboard for 5086 Processor
Offline bazemk1979
« Reply #8 on: Fri, 29 March 2013, 21:53:51 »
what on earth is it
and you call yourself buckling springs warrior huh!!! lol have no clue dude, might be BS, might be alps, might be rubber dome.... need to ask the seller if its clicky, but even rubber domes make some sort of click... and if seller have no clue of mech boards he will tell you YES it clicks!!!!   see the XT industrial link, seller have knowledge and he says its not clicky = rubber dome :)
« Reply #9 on: Sat, 30 March 2013, 12:19:47 »
how about these?
http://www.ebay.com/itm/IBM-Industrial-NON-CLICKY-PC-Keyboard-with-Attached-Cord-WORKS-CLEAN-w-box-/251251795062?pt=PCA_Mice_Trackballs&hash=item3a7fc62476
Saw this when it was first posted on ebay. I believe it's the same as webwit'- so-called "frankenboard". It'd be good to swap the guts out of a real XT into it.
http://webwit.nl/input/ibm_industrial/xt/
At a guess, it's probably either acer-like spring over membrane or capacitive foam/foil.
I've been doing a ton of IBM research lately, so just thought I'd share.
Blazemk, that "IBM 6247440 Keyboard for 5086 Processor" keyboard is almost certainly "prototopre". The keyboards for the IBM 5085 GPU (1983) were capacitive BS, and the keyboard for the 5086 (1986, just before the RS/6000 series) is prototopre. Also, looking at the key legends in the picture, it's the same as both the "prototopre" 'boards I've seen.
Do I call myself a "buckling spring warrior" ? No. But I have done my homework, especially as far as these IBM CAD workstation keyboards go.
Also: another teaser. There's right now a very interesting IBM keyboard on eBay that you missed. I have it, and will be taking better pictures of, and will be documenting.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #10 on: Sat, 30 March 2013, 12:22:31 »
someone should pick up that F-alike. capacitive foam/oil would be super cool to see the internals of.
Offline RougeR
« Reply #11 on: Tue, 02 April 2013, 20:20:11 »
id do it but shipping is murder to the uk
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #12 on: Fri, 16 May 2014, 15:25:17 »
There is a very cool looking IBM 6247440 on eBay http://www.ebay.com/itm/New-IBM-6247440-Keyboard-for-5086-Processor-/121184199564?pt=PCA_Mice_Trackballs&hash=item1c3724238c, I know nothing about them but found someone's Flickr album on them here: https://www.flickr.com/photos/triplehaata/sets/72157643179098933/page1/.
Very tempted to try the IBM Cupped Rubber, anyone have more information on these? This thread that I've posted in is all I could find.
Offline esoomenona
  • Gnillort?
« Reply #13 on: Fri, 16 May 2014, 15:52:41 »
They look like Topre rubber domes. Is it also capacitive? I think I'm going to buy it and see what's up.
Offline esoomenona
  • Gnillort?
« Reply #14 on: Fri, 16 May 2014, 16:11:39 »
Never mind. I looked at the pictures, and I don't believe it to be capacitive. It seems the pit in the middle of the rubber is what presses the two matrix sheets together to make contact.
Offline jwaz
  • * based mod
« Reply #15 on: Fri, 16 May 2014, 16:14:03 »
It's a "prototopre" with the blue and green dye-subbing.
Works with a soarer converter IIRC.
edit: HaaTa has spoken these are newer than the capacitive variety.
« Last Edit: Fri, 16 May 2014, 16:48:26 by jwaz »
Offline digi
  • elite af tbh
« Reply #16 on: Fri, 16 May 2014, 16:16:31 »
I have no idea if they're capacitive or not, I would also really like to know. It appears that there is no cable included with the keyboard and I'm not sure if it speaks ps/2 or what.
« Reply #17 on: Sat, 17 May 2014, 18:27:48 »
should speak IBM RT protocol and work with a soarer.
These are the newer versions of the prototopre keyboards. The fun legends are for graphics / CAD workstation use
