Author Topic: DIP Switches  (Read 1560 times)
Offline nsrexler
DIP Switches
« on: Fri, 05 April 2013, 10:08:27 »
The Ducky Shine II I'm using has a DIP switch that swaps the position of the Alt and Windows keys, which is really convenient for me since it allows me to use it on a Mac without having to remap the keys in software. Are there any other keyboards that include a feature like this? The only other one I know of is the upcoming WASD V2.
« Last Edit: Fri, 05 April 2013, 10:16:41 by nsrexler »
Offline daerid
    • Rossipedia
Re: DIP Switches
« Reply #1 on: Fri, 05 April 2013, 10:30:17 »
The only one I know of off the bat is the HHKB
Offline The_Beast
  • I like wood ಠ_๏
Re: DIP Switches
« Reply #2 on: Fri, 05 April 2013, 11:17:35 »
The poker allows you to swap the left alt and left windows key. I don't think it lets you do it for the right tho
Offline Macsmasher
Re: DIP Switches
« Reply #3 on: Fri, 05 April 2013, 20:25:49 »
Further, the HHKB has a 'Mac Mode' selectable via dip switch, which adds media functionality. Mac drivers also available.
http://www.elitekeyboards.com/products.php?sub=pfu_keyboards,hhkbpro2&pid=pdkb400w
Offline nsrexler
Re: DIP Switches
« Reply #4 on: Fri, 05 April 2013, 23:41:16 »
Any other full-size or 87% boards with this feature?
Offline SmallFry
Re: DIP Switches
« Reply #5 on: Fri, 05 April 2013, 23:44:17 »
WASD's V2 will offer this feature...
