Author Topic: o-ring dampener equivalents  (Read 1622 times)
Offline nomadicjester
« on: Sat, 06 April 2013, 13:49:11 »
Hey new to geek hack, have res a lot about kbs on here though. i was hoping you guys would be able to help me with o rings. is there an equivalent in a hardware store to the 40a-r, 40 a-l that i could buy for cheap to try? what would the size be? i live in the u.s. thank you
Re: o-ring dampener equivalents
« Reply #1 on: Sat, 06 April 2013, 16:25:16 »
Almost all the commercial O-rings from places like McMaster-Carr or these http://www.ebay.com/itm/200380989022?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 are always much harder grades.
Personally, I think that the softer the better, and dental bands (for braces) are pretty nice. My daughter had braces, and her leftovers came in very handy. Something like this http://www.ebay.com/itm/Clear-1-8-6-5-Oz-Orthodontic-Elastic-for-Braces-Dental-Rubber-Bands-/310604161429?pt=LH_DefaultDomain_0&hash=item4851736195 might work, but maybe somebody else could verify the size.
When a fool gains power, the first thing he does is silence the wise.
The Next thing he does is gather other fools around him.
The final thing he does is destroy the Nation.
- Plato
Offline nsrexler
« Reply #2 on: Sat, 06 April 2013, 16:31:03 »
I always just get these from Amazon:
http://amzn.com/B0051XWXCE
They feel exactly the same (to me) as WASD's 50A rings, and are about half the price.
« Reply #3 on: Sun, 07 April 2013, 00:55:57 »
yeah i've heard of the orthodontic before, how do those feel/soften noise?
otherwise thanks for suggestions, i appreciate it.
i was thinking 40a-r because i believe they're softer than 50a just wasnt sure what other good substitutes were
thanks
Offline vipjun
« Reply #4 on: Sun, 07 April 2013, 03:09:22 »
I found an assortment pack from a $1 store that had a few in 16 different sizes. Some hardware stores should have them, though depending on the quantity they carry, they might charge up to 50cents for 1.
WTT Realforce 87ub variable for 55G / MX PCB mount
http://geekhack.org/index.php?topic=42360.msg861771#msg861771
Offline AGmurdercore
« Reply #5 on: Sun, 07 April 2013, 06:59:39 »
Or you can always make some yourself as said here http://geekhack.org/index.php?topic=28708.0 there is even video on how to make them.
What the hell am I even doing
« Reply #6 on: Sun, 07 April 2013, 09:26:42 »
My feeling is that the orthodontic bands are thinner and softer than any of the commercial rings, that is why I like them. They have less effect than anything else.
- Plato
« Reply #7 on: Sun, 07 April 2013, 14:04:03 »
anyone know exact size for dental rubber bands?
