Author Topic: IBM Model M15 problem  (Read 3419 times)
Offline Kscorps
    • Lumine Hall
« on: Tue, 09 April 2013, 17:55:11 »
Hey Geekhack,
So, I'll make this as short as possible. The knob on my Model M15 will not turn past a fraction of a revolution (I can still turn it a little bit,) after my first few days of owning it. Will a lubricant such as WD-40 sprayed onto the screw loosen it up enough to be removed? Trying to get the thing into shape for sale, and I don't want to break anything by forcing it. I am not sure about which oil to use, as I don't know what type of plastic the M!5 is made of.
By the way, the keys feel superb. It's my first experience with buckling springs, though I'd rather own a regular M.
There is enough space for me to wiggle it to fit a thin nozzle or straw into. Thanks guys!
« Last Edit: Tue, 09 April 2013, 17:58:05 by Kscorps »
Offline csloan1218
  • Technomancer
Re: IBM Model M15 problem
« Reply #1 on: Tue, 09 April 2013, 18:36:03 »
Some lubricants are corrosive to plastics, I would be very careful using something like wd40.
Ducky DK9008 Shine II Blue LED Backlit (Red Cherry MX)
Leopold Linear Touch FC500RR/AB (Red Cherry MX)
Offline Kscorps
    • Lumine Hall
« Reply #2 on: Tue, 09 April 2013, 18:56:29 »
That's why I'm waiting until I can figure out what I can do to move that knob. I'm betting it's a type of plastic that I can use it with, but I cannot take any risks until I am fully sure of what I am working with.
Offline hoggy
  • * Moderator
« Reply #3 on: Wed, 10 April 2013, 07:49:01 »
Fancy a swap?  I've got a clean and tested model m...
Offline tiarnachutch
« Reply #4 on: Thu, 18 April 2013, 09:22:19 »
Even if its a bit tight, you should have no trouble selling. I for one have been looking for a reasonable one for months.
Home: IBM Model M (1991)
Work: WASD with Cherry MX Blues, Microsoft Ergonomic 4000, Goldtouch v1
Offline Kscorps
    • Lumine Hall
« Reply #5 on: Sun, 21 April 2013, 16:20:46 »
http://www.ebay.com/itm/IBM-Model-M15-Adjustable-Keyboard-13H6689-/261204315644?Item=261204315644#sp_cr
I've put it up for sale here, though I don't have enough posts for classifieds.
« Reply #6 on: Sun, 21 April 2013, 23:48:38 »
It's on my watchlist, though the reserve is a bit ominous.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Sun, 21 April 2013, 23:51:36 »
WD40 isn't a lubricant, it's more for displacing water
Try to find a plastic safe rust penetrator
