Author Topic: Razer Goliathus Extended Mouse Pad  (Read 3322 times)
Offline csloan1218
  • Technomancer
« on: Wed, 10 April 2013, 23:17:28 »
I was wondering if anyone had this pad and could give some feedback on it.
Or another deskmat similar.
http://www.amazon.com/gp/product/B004JMZXMK/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Ducky DK9008 Shine II Blue LED Backlit (Red Cherry MX)
Leopold Linear Touch FC500RR/AB (Red Cherry MX)
Offline ekw808
  • Ekw
« Reply #1 on: Wed, 10 April 2013, 23:30:26 »
It sheds
[One Keyboard at a time]
Offline daerid
    • Rossipedia
« Reply #2 on: Wed, 10 April 2013, 23:56:40 »
Not exactly sure what he means by "sheds" but I've been using that exact pad for about two years and I love the thing. Best thing about it is the stitched edge which prevents fraying
Offline csloan1218
  • Technomancer
Re: Razer Goliathus Extended Mouse Pad
« Reply #3 on: Thu, 11 April 2013, 00:20:59 »
Can you post some pics, after 2 years of use your pad is a great example
Offline PointyFox
« Reply #4 on: Thu, 11 April 2013, 00:23:01 »
You could check out the 314 reviews of it on Amazon.  I found a review that mentions the shedding. "The cloth material generates a huge amount of lint that gets everywhere on the underside of the mouse including the laser compartment."  Since there are not many reviews like this, I would assume that people who experience shedding have something under their mice scratching it.
Offline csloan1218
  • Technomancer
« Reply #5 on: Thu, 11 April 2013, 01:34:12 »
Most of the shedding gripes seem to be from users of mice like the Razer Orochi, I would hope my g9x wouldn't have the same issues.
Offline Potologue
« Reply #6 on: Thu, 11 April 2013, 18:51:15 »
I really like mine. I probably won't go back to a normal length mouse mat anytime soon.  I've only had it for 4 months so far, so I can't really comment on durability/shedding yet. Though it does feel like it will last.
« Reply #7 on: Thu, 11 April 2013, 19:01:53 »
I found it collected dust easily and caused me sensei to skip. Switched to an artisan pad, and won't go back. The goliath does make a nice pad on the desk though.
Offline daerid
    • Rossipedia
« Reply #8 on: Thu, 11 April 2013, 20:03:18 »
I'll try to snap some pics here. I just recently moved over to my old eXactMat, so I gotta dig it up. Never had any issues with it creating any "lint", but like all cloth pads it picked up a decent amount of sweat over the years. The only complaint I have about it is that the part under my mousing wrist started curling up a little bit.
Offline cobraj
« Reply #9 on: Thu, 11 April 2013, 20:22:32 »
I quite like the Extended version.
Just a note, don't wash it in water lol.
I did that to one, and it just got destroyed lol :(
Offline csloan1218
  • Technomancer
« Reply #10 on: Thu, 11 April 2013, 20:33:29 »
Alot of positive comments, I'll take the plunge on this one.
Thanks, and I look forward to the pics daerid!
Offline daerid
    • Rossipedia
« Reply #11 on: Fri, 12 April 2013, 01:28:38 »
How would you suggest cleaning it? I reaaaally need to get mine cleaned :(
Offline cobraj
« Reply #12 on: Fri, 12 April 2013, 02:15:46 »
i normally just get a really soft towel, wet it a bit (not too much) and just wipe it down.
Seems to have worked for me, but not sure if the mousepad of mine which got destroyed was a bad batch or not.
So probably a good idea to just try it out on a small area of the mousepad which you don't normally use, just in case :)
Offline purple_haze
« Reply #13 on: Fri, 12 April 2013, 13:37:22 »
too big.
Das Keyboard Silent S MX Browns | Filco Majestouch 2 MX Browns | Filco Majestouch MX Blues TKL
