Author Topic: CHERRY MX-Board 3.0(G80-3850)  (Read 18310 times)
Offline xiaodian317
« on: Thu, 11 April 2013, 10:15:52 »
Anybody know this keyboard from CHERRY?
« Last Edit: Thu, 11 April 2013, 10:40:01 by xiaodian317 »
Offline kuo2200
Re: CHERRY MX-Board 3.0(G80-3850)
« Reply #1 on: Thu, 11 April 2013, 11:38:21 »
It's a cherry G80-3800 i think
Offline Hyde
  • White Tofu Extraordinaire
« Reply #2 on: Thu, 11 April 2013, 11:51:52 »
The top 2 keyboard in the pics are G80-3800 (Cherry MX-Board 2.0), while the bottom 2 are G80-3850 (Cherry MX-Board 3.0).
Though I didn't know they come with wrist rest.  How do you like it so far?  Also how does the flat keys feel?  :D
Offline daerid
    • Rossipedia
« Reply #3 on: Thu, 11 April 2013, 12:46:12 »
I've been intrigued by this board ever since I heard about it. Mainly the low-profile key caps. They fit standard size stems, but are a few mm shorter. Wish I could get some low profile Topre caps that would fit on a RealForce.
Offline Tarzan
  • formerly known as Greystoke
« Reply #4 on: Thu, 11 April 2013, 13:33:54 »
That's the "gaming" Cherry G80, isn't it?  Nice-looking unit!  Where did you get it?
Offline Q404
« Reply #5 on: Thu, 11 April 2013, 13:34:43 »
I think its availibale on keyboardco.com
« Reply #6 on: Thu, 11 April 2013, 14:52:48 »
The keyboards at the top and in the middle don't have low-profile keys!
The red triangle on the right is a rubber foot on a keyboard that is upside-down.
Did the Cherry logo placed front and centre not answer that for you? ;)
[The low-profile key caps] fit standard size stems, but are a few mm shorter
From what I have heard, the Caps Lock key has a non-standard stem location...  :rolleyes:
Offline Chanc3
« Reply #7 on: Thu, 11 April 2013, 17:00:59 »
Worth a read: http://www.play3r.net/reviews/tech/cherry-mx-board-3-0-g80-3850-mechanical-keyboard-review/
I also happen to have the 3850 and the 3800 on me so any questions, feel free to ask.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #8 on: Fri, 12 April 2013, 05:48:41 »
Thank you for that link, nice to see the mother-ship actually refine it's beautiful product.
Just have one question for you, does it creak when you type furiously fast on the keys?  Meaning the plastic casing itself, is it firm or still flimsy and weak like the G80-3800 MX-2.0?
Please say they fixed that problem because Gamer's in general are absolutely merciless when it comes to using keyboards.
« Last Edit: Fri, 12 April 2013, 05:52:07 by Elrick »
Offline kaiserreich
  • HHKB Elite
« Reply #9 on: Fri, 12 April 2013, 06:14:13 »
Is it still using the same caps lock from MX2.0?
Offline esoomenona
  • Gnillort?
« Reply #10 on: Fri, 12 April 2013, 08:14:41 »
In the picture, it isn't. At least, it's not stepped like the MX2.0. I couldn't tell you about switch placement.
Offline xiaodian317
« Reply #11 on: Fri, 12 April 2013, 08:25:08 »
Thanks for your link that so I know 3850 is sold to all the world.
Offline philoyu
« Reply #12 on: Fri, 12 April 2013, 10:28:31 »
3850,3800,我已经有了,并且使用了一段时间了。我还MOD了3850 ;D
Offline vipjun
« Reply #13 on: Sun, 14 April 2013, 21:28:09 »
Do these use PCB mount ? meaning i can change the switches without soldering ?
WTT Realforce 87ub variable for 55G / MX PCB mount
http://geekhack.org/index.php?topic=42360.msg861771#msg861771
Offline Chanc3
« Reply #14 on: Mon, 06 May 2013, 12:10:37 »
Apologies for the late reply, but these are plate mount!
Offline GeoTang
« Reply #15 on: Mon, 06 May 2013, 18:24:28 »
Low profileee
I love the aesthetic of this keyboard. It hasn't been that long since the 2.0 came out though. Hope they made it less flimsy.
Offline asgeirtj
« Reply #16 on: Sun, 20 July 2014, 14:04:09 »
Is it possible to buy these keycaps standalone to put on other keyboards?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline divito
« Reply #17 on: Sun, 20 July 2014, 22:33:46 »
I wish; sadly I'm not sure it will ever happen.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline Hyde
« Reply #18 on: Sun, 20 July 2014, 22:55:57 »
Someone on geekhack (forgot which thread it was) found the company that makes those keycaps, I believe he contacted them but didn't seem to get any response.
Also we're assuming the MOQ will be pretty high.
« Reply #19 on: Sun, 20 July 2014, 23:01:12 »
It's Devlin who's making them.  It's their L series caps.  And I've contacted them before and they basically said they'd only work with people through QWERkeys.  After my last GB with them, I decided that it definitely wouldn't happen.  Devlin wouldn't even send on a color ring or pictures of the colors they had available for a GB through QWERkeys.
« Last Edit: Sun, 20 July 2014, 23:04:06 by nubbinator »
Offline divito
« Reply #20 on: Sun, 20 July 2014, 23:07:12 »
Some interesting stuff they offer. Pretty sad overall, I want some low profile.
« Reply #21 on: Sun, 20 July 2014, 23:09:01 »
You can ask in the Product Request Thread on the QWERkeys subforum if they'll do a buy with them.  It wouldn't be bad if they carried it in their store.
Offline asgeirtj
« Reply #22 on: Tue, 22 July 2014, 11:53:25 »
So i guess DSA is the best alternative available today?
Offline dante
« Reply #23 on: Tue, 22 July 2014, 12:05:29 »
You can buy the Cherry keycaps on TaoBao.  They come in black abs, black pom, white pbt flavors.  Both printed and blank.
You will likely want to mix them up with DSA for some of the non-standard stem keys.
MechanicalKeyboards.com is a Cherry dealer.  Might want to ask them if they can get it.
