Author Topic: SteelBeauty: Laser Cut, StainlessSteel, 65%  (Read 44051 times)
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« on: Fri, 12 April 2013, 06:57:12 »
Here I present you with my precious! Industrial looking, stainless steel, 65% layout waiting for the DSA Retro keys of course! Now to the soldering (a looong way to go)
Weight 1kg / 2.2 pounds
Side by side with a Filco TKL
3 layers + plate. 13mm total height (1.5 + 5 + 5 + 1.5):
MX Blues ready! But I'm going to change the spacebar one with an MX Green and the arrows with MX brown or grey... will see.
Test with keycaps
It turned out really well, I'm totally in love with it... and it didn't cost that much (approx $60, the 5mm layers are costy but the plate itself is pretty inexpensive)
Re: SteelBeauty: Laser Cut, StainlessSteel, 65%
« Reply #1 on: Fri, 12 April 2013, 07:12:31 »
That's awesome.  Now get those keys!  :p
Offline Sai
« Reply #2 on: Fri, 12 April 2013, 07:13:40 »
Yes. it truly is a beauty.  :'(
« Reply #3 on: Fri, 12 April 2013, 07:15:08 »
The jelly, I has them ;)
Seriously, that looks amazing and I cant wait to see it with your caps/ all built up :D
« Reply #4 on: Fri, 12 April 2013, 07:18:46 »
Wait, wait wait.  Where's the stabilizers?
Offline codyeatworld
« Reply #5 on: Fri, 12 April 2013, 07:22:04 »
I thought the same thing, but I think he only needs one for the spacebar.
Cannot wait to see this thing with retro, any plans to plate the steel? like gold or bronze?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #6 on: Fri, 12 April 2013, 07:36:03 »
what stabilizers?! All keys are <1.75 :P except for the spacebar of course :)
I'm looking for a very industrial look... but maybe bronze... mmmh
Offline esoomenona
  • Gnillort?
« Reply #7 on: Fri, 12 April 2013, 07:55:42 »
It's looks really good, Matt3o. Congratulations.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #8 on: Fri, 12 April 2013, 08:14:39 »
That's one nice case! CAN I HAS!!!!!!!
-Enzo Ferrari
« Reply #9 on: Fri, 12 April 2013, 09:32:28 »
The spacebar stabilizers.  It obviously isn't plate mount and the holes aren't big enough to fit the PCB mount through...
« Reply #10 on: Fri, 12 April 2013, 09:35:26 »
Costar :)
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Offline WhiteFireDragon
    • youtube
« Reply #12 on: Fri, 12 April 2013, 11:01:36 »
The 5mm plates were also laser cut? Those inside edges look really clean, I can even see the semi reflection. I wish the US had 1.5mm thick sheets available. The closest we have here is 16gauge.
« Reply #13 on: Fri, 12 April 2013, 11:03:54 »
Was the price of 2x 5mm plates the same, cheaper, or more expensive than 5x 2mm plates? :)
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #14 on: Fri, 12 April 2013, 11:11:10 »
yes, they are all laser cut and pretty good quality. I can have them cut at 1, 1.1, 1.2, 1.3, 1.4, 1.5 ... up to 10mm I guess.
Also I chose the no finish sheet, just a bare SS, but there are many options (satin, mirror-gloss, ...)
probably it's going to cost more because you use more man-power and more machine-time
Offline rurushu
« Reply #15 on: Fri, 12 April 2013, 14:18:44 »
nice case matt3o!!!! it looks like it meant "business"  :p :p
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #16 on: Fri, 12 April 2013, 20:50:51 »
Awesome case!
Offline rurushu
« Reply #17 on: Fri, 12 April 2013, 23:48:46 »
oh yea, i just realized one thing....
is this what the koreans called "vicki" style case? the switches are "naked"  ;D
« Reply #18 on: Sat, 13 April 2013, 00:16:18 »
vicki style, eh?  Never heard that.  I like it though, very geek chic.
Offline rurushu
« Reply #19 on: Sat, 13 April 2013, 00:37:31 »
well, to be honest, initially i also didnt know what "Vicki" meant, though i often saw the word in KBD
then, when zenuty showed his two-some case (in the media section), which had a similar appearance on the top...
the switches are exposed, or say, naked  :p :p "Vicki style" is what he used to describe them  :D
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #20 on: Sat, 13 April 2013, 02:29:39 »
yes the switches are naked, so geeky for a full metal case :) It would be perfect with SA family keycaps, but it should be fine with DSA too.
at OTD they did this a while back
never heard of "vicki", but in the picture metalliqaz linked the keyboard is naked on the sides (mine is not)
Offline TDub
« Reply #21 on: Mon, 15 April 2013, 03:28:23 »
Man that looks hot. I was always intrigued by the corsair keyboards for leaving the switches exposed like that. Didn't really want to buy one of those though, but I would really love to have a case like that. Great work Matt3o!
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #22 on: Fri, 19 April 2013, 12:07:45 »
there you go
Offline aggiejy
« Reply #23 on: Fri, 19 April 2013, 12:14:28 »
That is a thing of beauty. :)
Offline agodinhost
    • Dr Ian O Xaman
« Reply #24 on: Fri, 19 April 2013, 16:02:58 »
Awesome keys!!!
Congrats!!!
I would paint the case to black or brown ...
Offline Mugen
  • O-Rings are the murderers of keyboard souls
« Reply #25 on: Sat, 20 April 2013, 02:08:59 »
What insides are you using? what pcb?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #26 on: Sat, 20 April 2013, 02:15:14 »
everything's custom (teensy based). I'm working on it this weekend. I'll post pictures.
As a side note, the sound and feel of the keys is really great. The full steel body gives this beauty such a steadiness that all you hear is the switch sound. It makes a Filco feel cheap.
Offline calavera
« Reply #27 on: Sat, 20 April 2013, 02:22:51 »
So it's not functional yet?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #28 on: Sat, 20 April 2013, 02:32:35 »
lots of soldering awaits me today :)
« Reply #29 on: Sat, 20 April 2013, 09:52:06 »
Are you using lowpoly's method, or did you have a PCB made?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #30 on: Sat, 20 April 2013, 10:13:42 »
lowpoly (soldering right now)
Offline mashby
  • What Up Shoney? (ツ)_/�
    • Mashby
« Reply #31 on: Sat, 20 April 2013, 10:21:45 »
This is a beautiful board. Super impressed Matt3o. Nice job.
« Reply #32 on: Sat, 20 April 2013, 10:24:58 »
Matt30, that board is gorgegous. Makes me regret not getting in on the Retro buy but it's all good. These pics will whet my appetite :D
Offline daerid
    • Rossipedia
« Reply #33 on: Sat, 20 April 2013, 23:41:39 »
Jesus that's nice. The DIY stuff is definitely tempting me back to the land of Cherry.
Offline n0rvig
« Reply #34 on: Sun, 21 April 2013, 00:07:33 »
Wow! Seriously impressed at the level of custom DIY-ness. Those retro caps are awesome too.
Offline Kayliss
« Reply #35 on: Sun, 21 April 2013, 03:03:03 »
Nice job. Those keys suit it perfectly, a little jealous.  :D
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #36 on: Sun, 21 April 2013, 03:41:13 »
thank you guys... it has been a looong way. Today I'll post more pictures of the (hopefully) working prototype
Offline hargon
« Reply #37 on: Sun, 21 April 2013, 04:17:00 »
I'm looking forward to this. Please include information about controller programming too.
Offline Mugen
« Reply #38 on: Sun, 21 April 2013, 07:39:51 »
It looks f***ing sick, cant stop drooling. did you design and draw the plate and layers yourself?
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #39 on: Sun, 21 April 2013, 08:01:31 »
yes indeed!
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #40 on: Sun, 21 April 2013, 08:09:44 »
Awesome!  :)
A Ghost From The Past
Offline stoic-lemon
« Reply #41 on: Mon, 22 April 2013, 05:16:20 »
Superb. I really like this style of board. I think it should become a 'thing'.
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #42 on: Mon, 22 April 2013, 06:04:59 »
yesterday was big soldering day
unfortunately due to space constraints I couldn't find a pretty way to put wires... but it works. Now to the software.
Offline phetto
  • HHKB JP
« Reply #43 on: Mon, 22 April 2013, 06:07:13 »
You are such a pro! Nice job. Really like it :]
Offline Broadmonkey
« Reply #44 on: Mon, 22 April 2013, 14:54:13 »
That is just beautiful!
Offline agodinhost
    • Dr Ian O Xaman
« Reply #45 on: Tue, 23 April 2013, 13:24:51 »
Geeeeeeeeeeeeee, so many wires!
Awesome work man!
I'm kinda paranoiac with exposed wires and short circuits though ...
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
« Reply #46 on: Tue, 23 April 2013, 13:37:01 »
Awesome work man!
you took too much time to design the PCB :) I had to be creative :P
« Last Edit: Tue, 23 April 2013, 14:46:47 by Matt3o »
Offline nfc
R: SteelBeauty: Laser Cut, StainlessSteel, 65%
« Reply #47 on: Tue, 23 April 2013, 13:57:34 »
Ahh... you wasn't desoldering the usb port on the teensy ;D
Offline Matt3o
  • -[起財-
  • ** Robot Emeritus
Re: R: SteelBeauty: Laser Cut, StainlessSteel, 65%
« Reply #48 on: Tue, 23 April 2013, 14:47:11 »
I tried, and fried a teensy
Offline JPG
  • Model F is my new passion!
« Reply #49 on: Tue, 23 April 2013, 14:51:31 »
I think you forgot to add wire for full backlit!  :p
