Author Topic: MX White mini group buy  (Read 47891 times)
Offline remedyhalopc
Re: MX White mini group buy
« Reply #50 on: Sat, 27 April 2013, 14:46:18 »
Damn! Wish I could of gotten in on this. I would've bought 70.
Offline turtle
« Reply #51 on: Sat, 27 April 2013, 15:14:03 »
Damn.. Too late..
Offline Dubsgalore
« Reply #52 on: Sat, 27 April 2013, 15:16:13 »
awesome about that price reduction!
Offline majnu
« Reply #53 on: Tue, 30 April 2013, 16:49:32 »
so you guys are the reason why I can't get my cherry whites  :eek:
been waiting ages for these to come in stock and it's been showing 5-7 days for ages.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #54 on: Tue, 30 April 2013, 17:21:39 »
If anyone drops out, or if there are extras, I would be interested in ~75, but I'm flexible.  ;D
« Reply #55 on: Fri, 03 May 2013, 00:00:25 »
uh yeah paid up
Offline gameaholic
« Reply #56 on: Fri, 03 May 2013, 15:32:04 »
What would a good weight of korean springs to pair up with these? 45g, 55g, 62g?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline keymaster
  • Topre Revolution Theorist
« Reply #57 on: Fri, 03 May 2013, 15:42:08 »
It comes down to preference. I think 62g or 55g would be a good match. 45g may be too light, they're lighter than mx brown or mx red springs.
« Reply #58 on: Fri, 03 May 2013, 16:01:19 »
I'm putting 62g in mine. I tried ergo-Whites on Hashbaz's Universal Switch Tester and they felt amazing. I need moar in my life
Offline WhiteFireDragon
    • youtube
« Reply #59 on: Fri, 03 May 2013, 16:04:22 »
When you guys get these, please report back if the clicking is inconsistent between switches. The bag of mx whites I have do not have uniform clicking. Some click more than others.
Offline Jocelyn
  • 조셀린
Re: Re: MX White mini group buy
« Reply #60 on: Fri, 03 May 2013, 16:06:06 »
I was just about to post this! Please post your findings :)
« Reply #61 on: Fri, 03 May 2013, 16:09:17 »
My race with whites is like that iirc. They all feel the same though. Some just seen to click less or more.
« Reply #62 on: Fri, 03 May 2013, 16:10:26 »
My Pure has uniform clickyness ^__^
« Reply #63 on: Fri, 03 May 2013, 16:34:12 »
The default MX white spring is similar to clear or black?
Offline rknize
    • metaruss
« Reply #64 on: Fri, 03 May 2013, 16:46:06 »
Black.
Russ
Offline CommunistWitchDr
  • >implying keyboards
« Reply #65 on: Fri, 03 May 2013, 17:02:02 »
Its closer to green, 80g.
Offline OrangeJewce
  • ssk.ℜ
  • King of the Jewce
« Reply #66 on: Fri, 03 May 2013, 17:12:47 »
Black.
There is debate whether it actually is a black spring. For now it has been confirmed that White and Greens have identical springs.
Cheers,
IBM Model M 1390120, Otaku Unicomp+RGB, CM QFR Green, Ducky YOTD Red, SSK MKII,
ErgoDox Blue, ErgoDox White
Offline rknize
    • metaruss
« Reply #67 on: Fri, 03 May 2013, 17:58:04 »
I have all three in front of me and they appear to be exactly the same.
Russ
Offline rknize
    • metaruss
« Reply #68 on: Fri, 03 May 2013, 19:59:13 »
FWIW (sorry about the crappy pics):
Some length, same diameter, same number of coils, and the same wire thickness.  These are modern switches.  The vintage black springs are different and the white switch has been through at least three generations over the years.
« Last Edit: Fri, 03 May 2013, 20:01:08 by rknize »
Russ
Offline Tarzan
  • formerly known as Greystoke
« Reply #69 on: Fri, 03 May 2013, 20:07:18 »
So, one clicky, one tactile, and one linear?  But all the same spring strength?
I like White and Green switches interchangeably, but I tend to bottom out the linear Blacks.  I must be unconsciously expecting the feedback to clue me in as to switch closure.
Maybe Blacks would work better with red rubber rings...
Offline rknize
    • metaruss
« Reply #70 on: Fri, 03 May 2013, 20:22:39 »
Well, you have to be take the leaf spring into account on any tactile switch.  That is why the actuation force of the green/white is higher than the black.  Not only are you compressing the coil spring, but you are deflecting the leaf spring of the contact further outward as it rides over the little bump on the stem.  The stems of linear switches are smooth.
Russ
« Reply #71 on: Fri, 03 May 2013, 21:23:33 »
i do believe i will be replacing those with 55g
Offline Dubsgalore
« Reply #72 on: Sat, 04 May 2013, 08:01:51 »
inconsistent clickyness?
hope we don't have to deal with that :)
Offline Irisviel
« Reply #73 on: Sat, 04 May 2013, 08:47:14 »
What should I buy?
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #74 on: Thu, 09 May 2013, 19:29:20 »
Bird the word?
« Reply #75 on: Thu, 09 May 2013, 20:32:25 »
Oh yeah, how's this goin?
Offline realex
« Reply #76 on: Sat, 11 May 2013, 08:06:31 »
i am typing on an ergo white modded board right now and i can indeed confirm that there is approximately 1 in 30 switches that has a slightly different click sound. i have experienced this with both pcb and plate mounted boards it is definitely a switch issue.
the most accurate i could describe it would be, that they are different in terms of hollowness/reverb of the click, some just sound dryer than others. there are fluctuations towards both extremes, so some might get near blue sharpness and some might have their click on a very low sound level instead.
i'll have to test if my microphone is actually capable of recording this properly, if so i could post a video later should someone be interested.
Offline rknize
    • metaruss
« Reply #77 on: Sat, 11 May 2013, 20:18:10 »
The ones that are too clicky can be fixed by making sure that the slider is greased appropriately.  A tiny dab in the rail between the slider and the stem is all that is needed.  The ones that are especially quiet might have a defect.  The ones I ran across did not appear to have too much grease.  Rather they had some other problem that caused the slider and stem to bind.  They can usually be fixed with an exacto.
Russ
« Reply #78 on: Sun, 12 May 2013, 02:44:23 »
Basically Rapid decided to up the price on me. I'm still doing it, but at a small loss. It took a while since I tried to get a few quotes post price raise.
I'm thinking I'll like offer to test each switch and replace defects with some of my personal extras (I have plenty) for like $.02 a switch to help make up for losses.
« Reply #79 on: Sun, 12 May 2013, 02:45:30 »
Spread the loss out among the buy-members!  So we can all help out.
« Reply #80 on: Sun, 12 May 2013, 02:46:52 »
Make CPT pay for the loss, win-win!
« Reply #81 on: Sun, 12 May 2013, 02:48:02 »
But....I went too hard in the Glissant auction  :-X
« Reply #82 on: Sun, 12 May 2013, 02:48:32 »
Too many dongs
  • Kitteh Overlord
  • Say WHAAT...
« Reply #83 on: Sun, 12 May 2013, 03:29:21 »
Too many dongs
Those dongs do add up.
« Reply #84 on: Mon, 13 May 2013, 10:07:49 »
Thanks, just keep us up to date.
« Reply #85 on: Mon, 13 May 2013, 14:04:27 »
I've placed the order and paid. Now to wait till tomorrow for conformation because of time zones.
Bloody Brits.
Offline codyeatworld
« Reply #86 on: Mon, 13 May 2013, 14:40:40 »
Bloody Brits.
Thanks a lot for doing this, I'll have my payment this week!
Offline TheQsanity
  • SmallFry Lovin'
« Reply #87 on: Mon, 13 May 2013, 14:51:08 »
Wow this was a great price... im still waiting on my plate mount whites from Prof...
SmallFry! <3
Offline mashby
    • Mashby
« Reply #88 on: Mon, 13 May 2013, 15:18:46 »
If there are any extras, or if anyone has a change or heart. I'm happy to step in.  ;D
« Reply #89 on: Mon, 13 May 2013, 15:24:29 »
mashby I'll let you know if I have extras
« Reply #90 on: Mon, 13 May 2013, 15:31:01 »
I may have about ~60 left over, I ordered 150 and will probably just use them for an 86 key layout.
« Reply #91 on: Mon, 13 May 2013, 15:57:18 »
Add me to this list of if your unhappy and you know it....send me your white switches!
Offline shawn o
« Reply #92 on: Mon, 13 May 2013, 16:10:06 »
« Last Edit: Wed, 23 October 2013, 21:40:07 by shawn o »
« Reply #93 on: Wed, 15 May 2013, 04:25:02 »
Order is confirmed with rapid now. I'll keep ya posted when they ship.
  • Kitteh Overlord
  • Say WHAAT...
« Reply #94 on: Wed, 15 May 2013, 04:32:20 »
Ah snap!  :p
Offline TheQsanity
  • SmallFry Lovin'
« Reply #95 on: Thu, 16 May 2013, 02:38:51 »
Any leftoevers any more orders?
SmallFry! <3
Offline pandather
  • Formerly gopanthersgo1
  • Hello, I'm Mark.
« Reply #96 on: Mon, 20 May 2013, 22:15:43 »
I'd take a single leftover for a key chain. ;)
Offline naokira
  • The King in the North
« Reply #97 on: Sun, 26 May 2013, 18:52:09 »
Damn! Just got into whites. So close...
FaceW in LZ-CE
« Reply #98 on: Tue, 04 June 2013, 11:36:30 »
Sent rapid an email requesting an update. Will post response here when I get it.
« Reply #99 on: Wed, 05 June 2013, 07:59:04 »
Dammit, looks like its going to be longer than expected.
"Please be advised that we have got 562 pcs in stock and we are awaiting a delivery from our supplier on the balance. We have received an update from our supplier that the outstanding qty of 1535 pcs will be delivered to us by 18th of August"
