Author Topic: Rit Dye Experiment pt. 2  (Read 9487 times)
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
« on: Wed, 17 April 2013, 22:16:24 »
I threw the scientific method to the wind for this one. I figure the process is basic enough. I chose Tangerine Orange for this run... I think it turned out well. What do you think?
Top cap is my reference cap. Middle row is everyone's favorite, GH. Bottom row is a ;) emoticon, a skull, and a m (for meeba!).
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Re: Rit Dye Experiment pt. 2
« Reply #1 on: Wed, 17 April 2013, 22:19:13 »
Looks like a ghost scared the colour out of your caps! :p
They look pretty cool. If your refine the process, I'm sure you can get some pretty amazing results!
Offline funkymeeba
  • CRUMPULAR
« Reply #2 on: Wed, 17 April 2013, 22:22:28 »
Actually, the glue trick worked a lot better this time. The dye didn't take as well as I'd like... but if it's like the last batch I made, the dye will appear a bit bolder by tomorrow.
Offline funkymeeba
  • CRUMPULAR
« Reply #3 on: Wed, 17 April 2013, 23:08:56 »
Here's batch #2 from tonight... The wine color is a lot easier to deal with than tangerine.
Top is reference, middle is M, bottom-left is a skull thing, and the remaining three on the bottom were intended to be beer mugs. :D
« Reply #4 on: Wed, 17 April 2013, 23:13:31 »
Bottom left looks awesome! It looks like a scream mask, or some kind of wailing spectre.
Offline mmmty
  • bang! bang!
« Reply #5 on: Wed, 17 April 2013, 23:30:44 »
My Tangerine Orange came out pretty good but...
Keyboardless
« Reply #6 on: Wed, 17 April 2013, 23:32:27 »
mmmm those look like candy mmmty
Offline funkymeeba
  • CRUMPULAR
« Reply #7 on: Wed, 17 April 2013, 23:35:04 »
Ouch! Which caps did you do that with?
Offline mmmty
  • bang! bang!
« Reply #8 on: Thu, 18 April 2013, 07:40:10 »
Those were blank CCs.
Ok, they were just some crappy keys I used to testing. I think they were ALPS.
Keyboardless
Offline mmmty
  • bang! bang!
« Reply #9 on: Thu, 18 April 2013, 07:40:42 »
I guess I should kept the heat low and not boiling.
Keyboardless
« Reply #10 on: Thu, 18 April 2013, 08:03:42 »
That blank tangerine looks pretty awesome :D
Offline Dubsgalore
« Reply #11 on: Thu, 18 April 2013, 08:16:01 »
meeba cap testing?
Offline Tarzan
  • formerly known as Greystoke
« Reply #12 on: Thu, 18 April 2013, 08:32:30 »
I've managed to melt several Alps keycaps with both chemicals and heat, they're definitely not as robust as the PBT caps.
Offline Mandolin
  • Crystal Connoisseur
« Reply #13 on: Wed, 01 May 2013, 04:59:58 »
The tangerines look uneven, appart from the letters. The more saturated the color, the better it sticks.
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
Online Findecanor
« Reply #14 on: Wed, 01 May 2013, 09:38:51 »
Batik caps. ;D
Offline esoomenona
  • Gnillort?
« Reply #15 on: Wed, 01 May 2013, 09:48:25 »
Photos of the latest batch, meebs? I know one color wasn't working all too well, but didn't another take better?
Offline funkymeeba
  • CRUMPULAR
« Reply #16 on: Wed, 01 May 2013, 16:21:08 »
The caps were still a bit wet when I took those pictures. I had them drying off on that paper towel. The color is reasonably consistent across the set.
Check PMs in a couple of minutes. :D
Offline esoomenona
  • Gnillort?
« Reply #17 on: Wed, 01 May 2013, 16:23:48 »
mmmty, do those caps still fit on switches and work properly?
