Author Topic: Is this possible?  (Read 2176 times)
Offline Emmiya
Is this possible?
« on: Fri, 19 April 2013, 22:34:40 »
So, I have a feeling I know the answer to this anyway, however i'll ask in case i'm mistaken.
Is it possible to alter the input of a certain key?
for example with this Could you edit the Insert/Delete to activate Page Up/Page Down.
Or in my specific need here, could you alter the Scroll/Switch/Num Lock to PrntScrn. To a lesser extent, possibly using browser functions also, such as page back/forward. or just straight up disable the keys?
Thanks <3
« Last Edit: Fri, 19 April 2013, 22:38:02 by Emmiya »
Offline The_Beast
  • I like wood ಠ_๏
Re: Is this possible?
« Reply #1 on: Fri, 19 April 2013, 22:39:13 »
Yup, a simple Autohotkey script could easily change key positions/locations
Maybe on the second one, it would depend on what AHK and your browser supports
Offline Emmiya
« Reply #2 on: Fri, 19 April 2013, 22:51:43 »
Interesting :o looks like im going to have to reinstall AHK in preperation for the choc mini to re-arrive. Just need to decide what to bind the other 2 keys to now.
Ta' very muchly <3 xoxo
