Author Topic: Need help on choosing keyboard!  (Read 2682 times)
Offline linziyi
  • The one with many questions
« on: Sat, 20 April 2013, 18:44:38 »
Hi! I am currently looking for my first mechanical keyboard, price range below $100, preferably blue switches and includes a number pad! I don't really need backlight or media keys. I play piano so my fingers are accustomed to a high resistance (don't know what's the terminology in keyboard), so I'm looking for a very solid built keyboard. I don't mind buying used keyboards (Or should I buy a new one?) if the price is ok. Any suggestion for me?
Thanks in advance!
« Last Edit: Sat, 20 April 2013, 20:46:06 by linziyi »
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline DrakeMegrim
Re: Need help on choosing keyboard!
« Reply #1 on: Sat, 20 April 2013, 19:04:59 »
Loads of people recommend QFR for boards so long as you don't want to do any modding. I love Leopold and their "spacier" TKL layout. My current board is a choc mini MX Blue and I don't really care for the condensed layout.
Offline Dreamre
    • kbdlife
« Reply #2 on: Sat, 20 April 2013, 20:14:45 »
I would go with the QFR or you should consider getting the QuickFire Stealth (just came out, however, I think it's limited in stock).
As for the numpad, you don't REALLY need it. In my opinion, it's better without! Just need to learn to live without it :P.
Offline linziyi
« Reply #3 on: Sat, 20 April 2013, 20:21:29 »
But it doesn't have blue switches...
Ducky DK9008G2 Pro
Offline Dreamre
    • kbdlife
« Reply #4 on: Sat, 20 April 2013, 20:23:26 »
Both of them has blue switches ;D.
Offline linziyi
« Reply #5 on: Sat, 20 April 2013, 20:50:42 »
What's the difference between stealth and the regular version? The internet says it's without "branding", why does that mean?
Ducky DK9008G2 Pro
Offline Dreamre
    • kbdlife
« Reply #6 on: Sat, 20 April 2013, 20:54:45 »
The stealth has the writing below the cap (on the front) similar to the Filco MJ2 Ninja and "branding" means the physical writing on the keyboard.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #7 on: Sat, 20 April 2013, 20:58:27 »
You might want to go for something with green or white switches. Both are clickly, but require more force and would more than likely be closer to a piano key. Blues may be too light for you
« Reply #8 on: Sat, 20 April 2013, 21:33:04 »
You might actually consider a Unicomp BS board. High resist, totally satisfying to type on, and very affordable. The build quality is also exceptional and the board will likely last you a lifetime. They may not be the prettiest board on the block, but they feel great and are solid as a robots nipples.
Offline jabar
« Reply #9 on: Sat, 20 April 2013, 21:51:09 »
I would recommend looking at used boards but the listings here get picked through very quickly. That and going used will involve a lot more research since you won't know what will become available. It depends how much time you want to spend; I'm still reading about keyboards and I already own 6 used (some vintage) boards.
Are you more of a gamer? FPS or MMO? Or do you mostly type? I've had no issues with Blues for either application although some can't game with them. Since you're interested in Blues, if you can pop into a local computer store like Micro Center or Fry's (not Best Buy), you should be able to play with a Razer Blackwidow which has MX Blues (don't buy Razer keyboards). Blues are extremely light and you will always bottom out if you are more accustomed to heavier resistance. MX Greens on the Cooler Master QFR or Trigger could be a good option for you (however, sustaining MX Greens for FPS gaming wore my hands out fast).
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline linziyi
« Reply #10 on: Sat, 20 April 2013, 22:24:44 »
Thanks for reply! I mostly play RTS games like SC2 and Dota2. Green switches seem to fit me (again I don't really know) for its high resistance, are they only available on Cooler master keyboards?
Ducky DK9008G2 Pro
Offline linziyi
« Reply #11 on: Sat, 20 April 2013, 22:55:52 »
Guess I'll wait for a full size green switch keyboard for there is only QFR right now...
Ducky DK9008G2 Pro
Offline Hour
« Reply #12 on: Sun, 21 April 2013, 01:30:17 »
The Razer Blackwidow is an excellent starter keyboard, for below $100, blue switch and no backlight!
Offline knotra
  • I ญญญ♥ ⌂ ♫
« Reply #13 on: Sun, 21 April 2013, 21:55:53 »
The Razer Blackwidow is an amateur mechanical keyboard. The backboard is cheap, the keycaps are cheap, and the overall keyboard is flimsy. To add to that, Blackwidows do have backlighting.
Blue switches are generally pretty light, so if you want keys with more resistance and feel like piano keys, try getting cherry mx greens, blacks, or whites.
These are a few places that sells good keyboards.
http://mechanicalkeyboards.com/index.php
http://www.daskeyboard.com/
http://elitekeyboards.com/products.php?sub=leopold,fullsize
Keyboards: Razer Blackwidow Ultimate, Das Model S Ultimate Tactile Soft, Das Model S Professional Tactile Click, Corsair Vengeance K90, Steelseries 6gv2 Black Switch, Filco Ninja Majestouch-2 Soft Linear Action, Ducky DK9087 Shine II w/ Browns, Ducky DK9008 Shine II w/ Blues, WASD Keyboard v1 w/ Browns, Leopold FC200R Tacticle Touch, White Filco Majestouch-2 TKL Click Action, Ducky DK9008G2 PRO Dark Grey Version PBT w/ Clears, Realforce 87U Tenkeyless 45g White/Grey
Offline linziyi
« Reply #14 on: Sun, 21 April 2013, 22:05:56 »
Thanks for replies! I am now looking into a green switch keyboard, but unable to find an alternative to CM Storm's quickfire rapid, so I think I should wait a bit longer for a full size one.
Ducky DK9008G2 Pro
Offline jabar
« Reply #15 on: Mon, 22 April 2013, 00:46:27 »
At the moment it's either a Cooler Master QFR or Trigger for MX Greens. Ducky may have another round of fullsize PBT keycap MX Green boards but it won't be happening in the US for a while.
Phantom 7bit
Offline linziyi
« Reply #16 on: Mon, 22 April 2013, 00:48:48 »
Someone is offering a used QFR with filco ninja caps for $50 + shipping, is it a good deal (or is it a good idea for a new person to mech keyboards to buy a second hand keyboard)?
Ducky DK9008G2 Pro
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #17 on: Mon, 22 April 2013, 04:40:43 »
Buy Unicomp. You will get solid keyboard with great feel and top quality keycaps, to be honest best I've ever seen in industry (really even my HHKB's keys suck compared to pearl white Unicomp buttons).
