Author Topic: Do linear Alps switches exist? Gaming keyboard on the cheap  (Read 7960 times)
Offline BADBADNOTGOOD
« on: Mon, 22 April 2013, 17:07:21 »
I was looking at Ripsters alps comparison picture and noticed they were all either tactile or clicky...
I also thought i read somewhere that black alps and the ducky green alps were oth linear.
Was hoping someone could clear this up for me and maybe recomend a specific keyboard with linear alps (if it exists)
Re: Do linear Alps switches exist? Gaming keyboard on the cheap
« Reply #1 on: Mon, 22 April 2013, 17:08:05 »
I have a Ducky 1087XM with Linear Black Alps that I got from MK.com. I know Akimbo and Smallfry both really like Linear Green Alps.
Offline Rule16
  • R.I.P. SmallFry
« Reply #2 on: Mon, 22 April 2013, 17:26:12 »
I think ducky's green alps are tactile I have a vintage green alps board with double shots and it feels great.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline daerid
    • Rossipedia
« Reply #3 on: Mon, 22 April 2013, 17:58:41 »
I also have a 1087XM with linear blacks from MK. And they are indeed linear (but the activation point is so freaking high as to be practically unusable).
« Reply #4 on: Mon, 22 April 2013, 18:08:15 »
What about the original black Alps. Like the Dell AT-101. Are they linear?
« Reply #5 on: Mon, 22 April 2013, 18:09:47 »
The Dell AT101W I have is tactile
« Reply #6 on: Mon, 22 April 2013, 18:21:14 »
Thanks for all the replies. Looks like alps cant compete with cherry mx reds. I will probably end up buying a 70$ rosewill off newegg since there doesnt seem to be a cheaper option.
Offline daerid
    • Rossipedia
« Reply #7 on: Mon, 22 April 2013, 19:21:34 »
You can easily remove the tactile leaf from Alps switches (clicky or non-clicky). At that point they feel almost exactly like reds.
Offline jabar
« Reply #8 on: Mon, 22 April 2013, 19:24:43 »
Not sure how many ALPS boards have NKRO or anti-ghosting routing for WASD support.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
« Reply #9 on: Mon, 22 April 2013, 20:22:28 »
Do you have a link or how to for that? It seems like a fun project to try out
Offline Hyde
  • White Tofu Extraordinaire
« Reply #10 on: Mon, 22 April 2013, 21:28:47 »
I'll try to make a tutorial over the weekend, I've recently modded my g/f's clicky ALPS to quiet ALPS.
While it's not hard but I'd say it's still a pain in the butt to modify 108 switches.  Though the end result was nice though  :P
« Reply #11 on: Mon, 22 April 2013, 22:11:13 »
Awsome! I will be looking forward to that
Offline dante
« Reply #12 on: Mon, 22 April 2013, 22:24:11 »
I suggested to Matias that he should have a linear Alps variant but he thinks linear switches are a fad.
Offline TotalChaos
  • Indy Game Coder
« Reply #13 on: Tue, 23 April 2013, 08:55:06 »
A fad that has been running for 30 years?
Offline hasu
  • @tmk
« Reply #14 on: Tue, 23 April 2013, 10:30:50 »
Green Alps worth pursuing. But it is difficult to get good shape one.
XM is not Alps. Don't be confused with wrong terminology.
Offline daerid
    • Rossipedia
« Reply #15 on: Tue, 23 April 2013, 11:57:35 »
I don't really have any alps switches accessible at the moment (my 1087xm is packed up in a box somewhere), but I ended up using two small flathead screwdrivers to release the clips holding the top part of the switch in place. Then a small set of needlenose pliers to gently pull up the switch casing. At that point, you should have the spring in the center, and the tactile/clicky leaf just below it. Just pull that out, and replace the top part of the switch (make sure to get the spring up inside the switch stem), and press it down. It'll click back into place.
« Reply #16 on: Tue, 23 April 2013, 14:30:22 »
... I ended up using two small flathead screwdrivers to release the clips holding the top part of the switch in place. Then a small set of needlenose pliers to gently pull up the switch casing.
With the right type of tweezers you can do both in one operation. Insert, squeeze, lift.
When you put a switch back together, it is easiest to hold the keyboard upside down with one hand while you press the spring/slider/top combo with the other hand from underneath.
Offline R E D H O T
« Reply #17 on: Tue, 23 April 2013, 14:53:42 »
What about brown alps? According to Deskthority Wiki, brown alps is linear and tactile, but that doesn't sound accurate.
I've tried simplified green alps(Ortek MCK-101FTN) and compare to reds they don't feel as "linear". Maybe I need to take time and lube them IDK.
Offline Tarzan
  • formerly known as Greystoke
Offline AKIMbO
  • HHKBro
« Reply #19 on: Tue, 23 April 2013, 16:10:42 »
There's an Apple M0116 keyboard on eBay right now, says it has Salmon/Pink Alps.  Are these linear?
http://www.ebay.com/itm/Vintage-Apple-keyboard-M0116-cord-Salmon-Pink-Alps-mechanical-switches-/221215485614?pt=US_Vintage_Computing_Parts_Accessories&hash=item3381786eae
Salmon alps are not linear....they are tactile and very much so.
If you guys are craving linear alps....then buy my linear green alps Zenith ZKB2-AT.  It's only been in the classifieds section for an entire freaking month! (It's in good shape too :P)
| KBD75 (box reds)
