Author Topic: My 3D printed Portal keycaps  (Read 10108 times)
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« on: Wed, 24 April 2013, 16:50:15 »
After having no luck purchasing a portal modifier set, I decided to do the next best thing- print my own. (I'm still looking to buy a set by the way) Using calipers and AutoCAD, I was able to make a near perfect replacement. After printing it, I used acrylic paint to fill in the engraving and then sanded off the access. I think it turned out pretty good. I also made a space bar, but I'm having some issues that I'm working out.  Anyways, here are the pics:
Cheers
« Last Edit: Wed, 24 April 2013, 16:52:10 by TheFlyingRaccoon »
HHKB Pro 2   SmallFry Keyboard
Re: My 3D printed Portal keycaps
« Reply #1 on: Wed, 24 April 2013, 16:52:26 »
They turned out well, especially compared to some of the other 3dprinted caps I've seen. The painting's pretty good too!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Wed, 24 April 2013, 16:53:09 »
Looks great!
How's the surface finish/ how smooth are they?
Offline osxoep
« Reply #3 on: Wed, 24 April 2013, 16:54:12 »
This is cool. Stuff like this makes me wish I had a 3d printer.
HHKB Pro JP with hasu's controller (waiting for MX sliders)
  • HHKB Pro
« Reply #4 on: Wed, 24 April 2013, 16:55:20 »
Thanks! Yeah I'm not too happy about the paint; there is some excess I wasn't able to sand off. I'm really happy about how nice the 3D printer worked though.
Yeah I'm super happy my school has one I can use :D
Looks great!
Thanks! The surface had some ridges due to how the 3D printer prints layer by layer, but some really light sanding took care of that.
« Last Edit: Wed, 24 April 2013, 16:58:40 by TheFlyingRaccoon »
Offline baldgye
  • Will Smith Disciple
« Reply #5 on: Wed, 24 April 2013, 17:11:48 »
wouldn't it be better to use 3D printing to generate molds rather than the keys them self's ?
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #6 on: Wed, 24 April 2013, 17:15:08 »
depends on your goals? we need more experimentation with extrusion head printing to really know frankly
Offline aesthetics1
« Reply #7 on: Wed, 24 April 2013, 17:16:07 »
+1 to this. Once you have a solid mold, you can experiment with the different methods of printing/painting/infilling the legends on the keys.
Home: Filco Majestouch TKL MX Red | Work: Ducky Shining (Blue LED) MX Black | Collection: CM Quickfire Rapid MX Red
Offline mkawa
« Reply #8 on: Wed, 24 April 2013, 17:19:12 »
yah but you're also restricted to materials that melt at low temp and have very low shrinkage rates or are rtv and so on for the casting. abs can be dirsctly extruded by most of the desktop units now
  • HHKB Pro
« Reply #9 on: Wed, 24 April 2013, 17:34:45 »
Yes this is one of the ideas that was processed during brainstorming. However, I was not able to find a material that could be melting and molded without melting the mold itself. I would have to have a low melting point yet remain solid.
Offline mkawa
« Reply #10 on: Wed, 24 April 2013, 17:37:05 »
bam
Offline Rayne
  • For Science!
« Reply #11 on: Wed, 24 April 2013, 18:59:47 »
These look super sick! They seem to have a rustic or beat up look to them, which really like.
« Last Edit: Wed, 24 April 2013, 19:03:34 by Rayne »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #12 on: Wed, 24 April 2013, 19:01:59 »
You could print something off, make a silicone mold and use that to pour pewter caps (low enough pour temp for a silicon mold)
  • HHKB Pro
« Reply #13 on: Wed, 24 April 2013, 19:09:14 »
That is a great idea! I might have to look into that.
Thanks! I think the "rustic" look is primarily because of the excess paint I was not able to sand off. That's definitely an interesting way of thinking about it though.
« Reply #14 on: Wed, 24 April 2013, 19:11:44 »
Looks great!
I would imagine it's like the sample I brought to the meet if you remember that.
OP, this is super cool. How'd you color the caps?
  • HHKB Pro
« Reply #15 on: Wed, 24 April 2013, 19:15:07 »
Looks great!
« Reply #16 on: Wed, 24 April 2013, 22:46:11 »
Sorry, i totally skimmed. I'd don the cone of shame but I think it's still on from another thread XD
Offline D1G1TALD3ATH
« Reply #17 on: Fri, 26 April 2013, 06:47:53 »
Dude! those are awesome!
Offline Rule16
  • R.I.P. SmallFry
« Reply #18 on: Fri, 26 April 2013, 12:05:17 »
I wish I could see it, but imgur is blocked at school :(
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
« Reply #19 on: Sat, 27 April 2013, 06:46:06 »
Do they fit well on the switches?
Any chance of an upskirt shot?
Offline Grim Fandango
« Reply #20 on: Tue, 30 April 2013, 08:09:09 »
I really like the way these look. They are not clean and perfect, but imo that kind of works in their favor. More interesting than the normal ones for sure. Good job.
Offline baldgye
« Reply #21 on: Tue, 30 April 2013, 08:13:16 »
fair enough
Offline GeoTang
« Reply #22 on: Mon, 06 May 2013, 18:41:33 »
Do you know what the 3d printer's model was?
If not, how thin were the layers for the keycaps?
Offline Mandolin
  • Crystal Connoisseur
« Reply #23 on: Mon, 06 May 2013, 19:09:27 »
They look like you took a piece of philadelphia cream cheese and splattered it with some blueberry and strawberry sauce  ;)
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
  • HHKB Pro
« Reply #24 on: Mon, 06 May 2013, 19:45:26 »
It is a Dimension BST. The layers are too small to measure as the printer is very precise.
 :)) Yeah I was not very happy about the paint. In fact I repainted them and sanded some more but they still don't look great. The actually keycap though is very nice. I am impressed with the quality of the 3D printer.
