Author Topic: The Living Soldering Thread  (Read 2451663 times)
Offline actionbastard
Re: The Living Soldering Thread
« Reply #750 on: Mon, 29 July 2013, 23:34:23 »
also keep in mind that there's more than one way to heat things. there is contact and there is LAMINAR FLOW OF VERY HOT FLUIDS. basically, take a huge effing hot air gun and heat those oxidated suckers up, then take something really abrasive and abrade the **** out of it while it's hot.
Sand blaster?  ^-^
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #751 on: Mon, 29 July 2013, 23:42:16 »
keep in mind you need to leave the PCB and components intact...
« Reply #752 on: Tue, 30 July 2013, 07:23:07 »
I'm not sure if that's directed at me, but if it is I won't have to worry - there is no PCB.  I'm just soldering to a bunch of contacts lined up in a row.
A sand-blaster might actually work...   :))
Offline mkawa
« Reply #753 on: Tue, 30 July 2013, 10:44:21 »
DO IT AND TAKE PICS!!
« Reply #754 on: Tue, 30 July 2013, 10:50:20 »
Haha, if only I had a sand blaster...
In other news, I have some DeoxIT (link) that is good for cleaning oxidation of contacts.  Unless you'd advise against trying that, I think I'll give that a go and see if it helps clean the contacts.
The reason I'm trying things other than the suggestions is because Radioshack (my only local supplier) seems to be incapable of carrying the flux pens in store - only online - and I want to get working on it tonight.  I will still check to see if they have any in-store by chance, but it seems unlikely.
Offline mkawa
« Reply #755 on: Tue, 30 July 2013, 14:25:16 »
deoxit is great for cleaning oxidization at the micron level. go to the hardware store, get some steel wool or some 100 grit sandpaper and go to work
Offline domoaligato
« Reply #756 on: Tue, 30 July 2013, 14:37:16 »
Thought I'd share this while I'm here. 1lb spool of 63/37 Kester 44 only $21.80 and shipping isn't outrageous like the other site. http://www.all-spec.com/products/KW4410.html
here is the .20 version also
http://www.all-spec.com/products/Soldering_and_Rework%7CSolder_and_Soldering_Chemicals%7CSOL-0C/KW4400.html
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #757 on: Tue, 30 July 2013, 14:40:47 »
They are a legit site too, so I'm going to order through them from now on.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline mkawa
« Reply #758 on: Tue, 30 July 2013, 20:23:31 »
i will be completely amazed if you manage to get through more than a single lb of solder in your lifetime.
« Reply #759 on: Tue, 30 July 2013, 20:24:38 »
I want to buy a lb and melt the whole thing down in an oven into a giant solder ball.  Does that count as "using" it?
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #760 on: Tue, 30 July 2013, 21:45:05 »
Hell, I use solder errday and I'm not sure I'll need much more than an LB.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #761 on: Wed, 31 July 2013, 08:43:55 »
I got some 0.031" I meant if I wanted to snag some 0.020" as well :) And I used almost a lb of solder alone when I wired my car with 1/0 for my audio setup. 1/0 ring terminals require a **** ton of solder... and a friggin propane torch to solder with haha.
TOO BAD FOR YOU
Offline The_Beast
  • I like wood ಠ_๏
« Reply #762 on: Wed, 31 July 2013, 08:48:25 »
That's why I ordered 4oz of .020" instead of getting a pound. It was around the same price per oz as a 1 pound roll of it and since I knew I wasn't going to be soldering a ton, it just made more sense to do that.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #763 on: Wed, 31 July 2013, 08:52:24 »
In retrospect I should've probably saved the money and went with that. No way I'm gonna use all of that. Plus I'll be away at school. Guess I'm bringing my iron with me :D
TOO BAD FOR YOU
Offline The_Beast
  • I like wood ಠ_๏
« Reply #764 on: Wed, 31 July 2013, 08:55:28 »
You can always sell some here. I'm sure there are people who don't want a pound and you want to get rid of some......
« Reply #765 on: Wed, 31 July 2013, 10:06:14 »
Where does one buy this small amount from?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #766 on: Wed, 31 July 2013, 10:11:20 »
Found a solder similar to the Kester 44. There is much less of but at a similar price per ounce since I doubt anyone is really going to need 1lbs of solder for keyboards. And it's .020" thick so it should be thin enough in diameter for SMD work
http://www.mouser.com/Search/ProductDetail.aspx?R=SMDSW.020_4ozvirtualkey63560000virtualkey910-SMDSW.0204OZ
Offline mkawa
« Reply #767 on: Wed, 31 July 2013, 10:17:51 »
that solder has no-clean flux. what we like about kester 44 is the fact that it has a very active (ie, very corroside) RA rosin flux. chip quik might still make a good RA rosin core solder though. i'm pretty MG chem still does, and their rosin is top notch.
edit: note that the major difference between no-clean and rosin flux is that no-clean is _not_ very active. hence, you don't have to clean it off the board after you solder. this is quite if you're processing 1 MILLION PCBs per minute, but if you're soldering like one a week you want the rosin.
« Reply #768 on: Wed, 31 July 2013, 10:27:51 »
If I wanted to get solder in small amounts would any of the following be worthwhile? I know were beating a dead horse...but I'm trying to absorb all the knowledge slowly ;)
Kester 63/37 .031 Solder,Rosin Core #44, 20 ft, NOS
http://www.ebay.com/itm/111098191441?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Kester 44 Rosin Core Solder 63/37 .020" Dispense-Pak
http://www.ebay.com/itm/261152828428?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
or perhaps these
 MG Chemicals 4880 Series, Sn63/Pb37 Rosin Core Leaded Solder, 0.032" Diameter, 0.6 oz Pocket Pack
http://www.amazon.com/gp/product/B00425DZGK
 Kester Pocket Pack Solder 60/40 0.031 0.50 oz. Tube
http://www.amazon.com/gp/product/B00068IJNQ
« Reply #769 on: Wed, 31 July 2013, 10:30:54 »
I dunno, I'm the kind of guy that would rather just spend the extra 10-15 bucks so I don't ever have to order any more in the foreseeable future.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #770 on: Wed, 31 July 2013, 10:32:27 »
or perhaps these
That second link isn't a bad deal. If you want some good solder in a compact size I'd do it. I love those little tube packs for soldering. Though, ~$8 for 3/4 Oz is mad expensive. You can get a pound, which is almost 20x more for about 3x that price.
TOO BAD FOR YOU
Offline The_Beast
  • I like wood ಠ_๏
« Reply #771 on: Wed, 31 July 2013, 10:42:54 »
or perhaps these
Considering that you can get 4 oz for around $12 in my link, it is mad expensive
« Reply #772 on: Wed, 31 July 2013, 10:45:34 »
or perhaps these
Ignoring price what about the actual solder :P
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #773 on: Wed, 31 July 2013, 10:46:09 »
or perhaps these
And then you can get 16oz for $22 in my link. This is just a vicious cycle. Soon someone will find a 10lb spool for $200.
As for Ray, the solder is Kester 44, it's the same as we've been posting so I presume it'll be just fine :)
TOO BAD FOR YOU
Offline esoomenona
  • Gnillort?
« Reply #774 on: Wed, 31 July 2013, 10:48:32 »
or perhaps these
ALL ABOARD THE QUOTE TRAIN!!
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #775 on: Wed, 31 July 2013, 10:50:12 »
or perhaps these
Choo Choo!
TOO BAD FOR YOU
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #776 on: Wed, 31 July 2013, 11:00:32 »
Get 1lb and be done for life.
I had no option here in India, as only one shop in 800 shops in our electronics market had 63/37 solder, that too non-Kester-44. Minimum amount was 1lb for $9
Offline MJ45
  • HHKB Pro
« Reply #777 on: Wed, 31 July 2013, 13:10:42 »
[/quote
With those pocket packs like M&G chemicals 0.6oz  63/37 .032  I was able to solder my Phantom and a couple of usb connectors. I would rather buy the small ones so its fresh, they are only a couple bucks a pack
« Last Edit: Wed, 31 July 2013, 20:27:33 by MJ45 »
Offline mkawa
« Reply #778 on: Wed, 31 July 2013, 14:23:49 »
or perhaps these
my god. i've actually used every single one of those (although not in those sizes). i've never liked 60/40, but it has its uses in certain applications. the basic idea is that they are all high quality solders. MG chem, alpha metals, chemtronics, and kester all make FANTASTIC products. i may hate no-clean for hobbyist use, but even their no clean is extremely good given the constraints (all of them). choose based on flux type, solder diameter, price, alloy and quantity. you will be hard pressed to find a quantifiable difference between any of those manufacturers' comparable products in hobbyist use.
Offline Xenderwind
« Reply #779 on: Wed, 31 July 2013, 14:38:05 »
so I may have broken my soldering iron after a total of 5 minutes.  I took it out and wanted to just use the hakko tip I bought and apparently it didnt fit over the heating element?(not sure if thats what it is) and the white part cracked/broke.  Oh and it still doesnt fit with part of it cracked off since the cover part wont screw on afterwards.
I haven't tested it yet, but any idea how bad this is?  Wasn't sure if this meant it was unsafe to use or wont heat the tip properly now.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #780 on: Wed, 31 July 2013, 14:44:19 »
What kinda iron was it again? And that looks pretty serious bud. :(
TOO BAD FOR YOU
Offline Xenderwind
« Reply #781 on: Wed, 31 July 2013, 14:45:56 »
the yihau 936
« Reply #782 on: Wed, 31 July 2013, 14:51:13 »
I bet that HobbyKing would replace it for you under warranty if you contact them.
« Reply #783 on: Wed, 31 July 2013, 14:52:41 »
or perhaps these
So for a noob soldering on keyboards would any of those 4 listed be a 'better' choice?
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #784 on: Wed, 31 July 2013, 14:53:47 »
or perhaps these
Any of the 63/37's would be the same.
TOO BAD FOR YOU
« Reply #785 on: Wed, 31 July 2013, 14:54:40 »
[/quote]
I use that. We used that at my internship.
Offline Xenderwind
« Reply #786 on: Wed, 31 July 2013, 15:53:11 »
*sigh* I tested it and I think the crack ****ed with the sensor, so it looks like I'm ordering a soldering iron from amazon and wont get it till friday.  I have class all day tomorrow anyway :\ but still.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #787 on: Wed, 31 July 2013, 15:56:17 »
Yeah, that ceramic part is fairly integral, too.  Gotta make sure your tips are the right ones for your device, bruh.
Offline Xenderwind
« Reply #788 on: Wed, 31 July 2013, 16:00:16 »
Eh, could have sworn I saw people saying the hakko tips work fine and this hakko tip was for the800 and 900 series.
« Last Edit: Wed, 31 July 2013, 16:02:24 by Xenderwind »
« Reply #789 on: Wed, 31 July 2013, 16:19:29 »
Tips for the 888 are different from tips for the 936. The ones for the Yihua should be like this: 900M-T-2.4D.
Offline Xenderwind
« Reply #790 on: Wed, 31 July 2013, 16:22:29 »
http://www.amazon.com/gp/product/B004ORB8J2/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
 says backwards compatible with 900m which google shows https://www.hakko.com/english/tip_selection/series_900m.html
which lists the 936, but o well.  It's too late now.
Offline RabRhee
« Reply #791 on: Wed, 31 July 2013, 18:07:01 »
Sucks about the element, I found a post that says the Hakko or Yihua 936 used the same tip, but its quite possible either it was erroneous or Yihua changed the design since then. :/ There are replacement elements around if that is what broke, but that may be chasing more stress rather than going for a new iron, especially if other things are different sizes / ratings between the two.
http://www.amazon.com/Amico-Replacement-Heating-Element-Soldering/dp/B00CQMHNC8/ref=sr_1_1?s=hi&ie=UTF8&qid=1375311670&sr=1-1&keywords=936+heating+element
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline Xenderwind
« Reply #792 on: Wed, 31 July 2013, 18:28:29 »
Yeah I think I would still need to desolder the old element+solder a new one, not to mention wait 3-4 weeks for it to come in.  So I just bit the bullet and bought a new soldering iron so I can go ahead and do my soldering this weekend.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #793 on: Wed, 31 July 2013, 18:33:14 »
I'm assuming you mean the plug in part and not the whole station, right?
If I'm remembering jdcarpe right, you should have been able to get a true hakko wand at that point, which means no question that hakko 900 tips fit.
Offline Xenderwind
« Reply #794 on: Wed, 31 July 2013, 18:41:09 »
I was just going to buy an aoyue station from amazon and get it here by friday.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #795 on: Wed, 31 July 2013, 18:45:16 »
Oh wow, the wands are a lot more expensive than I realized XD  Carry on
Offline Xenderwind
« Reply #796 on: Wed, 31 July 2013, 18:49:22 »
Yeah I think they were between $10-20 and would take until at the very least monday (ebay) to get here.  I'd rather just get a new station and have it here friday.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #797 on: Wed, 31 July 2013, 18:50:22 »
I was looking up the hakko ones through amazon, they're closer to $100
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #798 on: Thu, 01 August 2013, 08:49:58 »
Not to mention the Hakko pens have the opposite plug as the Yihua pens. Yihua uses a female connector on the pen, male on the station. Hakko uses male on the pen and female on the station. They aren't cross compatible :/
TOO BAD FOR YOU
Offline Tarzan
  • formerly known as Greystoke
« Reply #799 on: Thu, 01 August 2013, 08:59:29 »
FWIW, the Aoyue soldering station I got from Amazon shipped with a spare element (but only one tip...).  I didn't know what it was, but from reading this thread, I'm glad I've got one on hand.
http://www.amazon.com/gp/product/B000I30QBW/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
