Author Topic: Wedding band fund.....sale (Ti glasses and spacebar added)  (Read 11635 times)
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« on: Sat, 27 April 2013, 16:18:39 »
Preface: My wedding is May 18th and I need to earn some money ASAP to fund my wedding band. I'm trying to get a band specially crafted, and the order needs to be placed Monday April 29th to get delivery on or before May 17th. The ring I am trying to buy is MARK I Palladium Mens Wedding Band. Everything past what I need for the ring is going to pay the DJ and my fiancee's wedding band (we decided to buy our own bands instead of each others, but I'll help her if I can afford it).
  • I would like to try and keep shipping to the US only, but if you are willing to pay the extra cost I have no problem shipping internationally
  • If you want images at certain angles or anything just ask
  • Payment via PayPal 2.9%+30¢ (or 3.9%+30¢ international)
  • Heat dating back to 2004: Danucf 55-0-0
  • Shipping for large or multiple items will be in flat rate boxes, otherwise small bubble mailers
  • Prices are shipped unless international
Items For sale:
Fully assembled ErgoDox $255 SOLD (negotiable and depends on options)
  • MX Clears
  • You pick LED color (Pink, Green, Red)
  • You pick sticker color(Metallic Teal, Black, Matte Green, Shiny Green, Yellow, Pink/Blue mix, Shiny Pink)
  • Lubed: options available (Victorinox on springs, Finish Line Dry teflon, Tri-Flow P.T.F.E, Krytox GPL-103, Tribolube 71 which is my favorite, Super Lube, Tribolube/GPL-103 mix)
  • ErgoDox PBT Black DSA Keycaps (4 deep dish for F, J, etc will be included)
Custom Phantom ANSI-150 $200+ (negotiable  and depends on options)
  • QFR black case, can be custom painted (Plasti-dip in White, Black, or Gunmetal grey, Then Artistic Aerosols in Yellow bird, SAS Blue, Orange Hazard, Flat Black, Mint Green, Flat White, Dark Red, and Grape)
  • Painting will consist of multiple coats of paint and then sanding until it looks amazing, clear coat optional
  • MX Blues or Vintage Blacks (Blacks are already victorinox springs with Tribolube 71 stems and Orange stickers)
  • Cherry Plate mount stabilizers unless you want Costar stabilizers with no 7x spacebar wire, or only Cherry stabilizer for the spacebar
Customized KBT Pure $125 SOLD (negotiable)
  • Ergo MX Clears (62g Korean springs with 65g on spacebar, Victorinox lube springs, Krytox GPL-103 on internal slider)
  • Teal metallic stickers
  • Green LEDs around 3.2-3.6V (normal keyboard LED voltage)
  • Cyan around 4.2-4.6V (If you can figure out how to give them more voltage, was a project I'm going to have to pass on for now)
  • Regular plastic case
  • No keycaps
LEDs are actually green unless you can modify the board to apply more voltage
6.2x size Titanium spacebar $110 (negotiable)
  • Sandblasted (The best appearance)
  • OEM Profile (Good for Filco, if you don't like SP DCS profile, Stock Pure caps, QFR, etc)
  • 3 stems
Oakley T-wire Titanium Sunglasses $100 (negotiable)
  • Polarized
Ducky Artisan Skull key "The Ancient" $75 SOLD (negotiable)
  • Made by Kayvee
  • Pinkish/Purpleish eye gems
MKC RGB Double Shot Kit $70 (negotiable)
  • Black legends
  • Green Shift keys: One 1.25x iso, two 1.75x, one 2.25x, two 2.75x
  • Red Control keys: two 1.5x, two 1.25x
  • Blue Alt keys: two 1.5x, two 1.25x
  • Red Escape keys: two
  • Yellow R4 1x diamonds: Two dark yellow, Two light yellow
Custom painted MX 1800 case $50 SOLD
  • Color options (Plasti-dip in White, Black, or Gunmetal grey, Then Artistic Aerosols in Yellow bird, SAS Blue, Orange Hazard, Flat Black, Mint Green, Flat White, Dark Red, and Grape)
  • Bottom label: G80-1800HAU / 12
Color example from another case. The Hazard orange and SAS blue look fantastic
Korean Dye Subbed PBT 6 key set $25 (negotiable)
  • Consists of the following: 2.25x enter, 1.5x R4 modifier, 1.25x R4 modifier, two 1x R4 key, 1x R1 key
NIQMODs Pure Pearl Blue $15 SOLD (negotiable)
  • Only 8 of this cap was made
NIQMODs Pure Pearl White $15 SOLD (negotiable)
Hiero Double Shot key $10 SOLD (negotiable)
  • Signature Plastics made
QWERKeys Lambda $8 (negotiable)
  • K series
100 3mm LEDs (Two left) $6 (negotiable)
  • Green around @ 3.2-3.6V (normal keyboard LED voltage)
  • Cyan around @ 4.2-4.6V
Keyboard Assembly and other Service $Varies depending on project details (negotiable) all return shipping will be additional
  • Anything involved with soldering will be with my soldering tip collection, Hakko FX 888, soldering marker, fine tipped soldering tweezers, two methods of desoldering (desoldering iron, and solder sucker pump)
  • My soldering experience consists of the following: Customizing two KBT Pures with complete stem/LED swaps, Rebuilding/Modding a Leopold FC700R to ergo clears, rebuilding a Filco TKL into a WFD custom plate, rebuilding an CM QFR into a custom plate, repairing/replacing bad switches on various boards
  • ErgoDox assembly - $45
  • Phantom assembly - $35
  • Phantom assembly with Spring or Stem swap - $40
  • Phantom assembly with lubed switches - $65
  • Phantom assembly with lubed switches and stickers - $70
  • GH60 assembly SMD presoldered - $25
  • GH60 assembly SMD presoldered with Spring or Stem swap - $30
  • GH60 assembly SMD presoldered with lubed switches - $45
  • GH60 assembly SMD presoldered lubed switches and stickers - $50
  • GH60 assembly DIY - NO (I can do it, but the decision to order this way to have someone else assemble was a bad choice, not really saving any money)
  • Board dependent Spring or Stem swap  - Varies
  • Lubing/Sticker switches - Varies depending on quantity, and Lube requested
  • Painting color options (Plasti-dip in White, Black, or Gunmetal grey, Then Artistic Aerosols in Yellow bird, SAS Blue, Orange Hazard, Flat Black, Mint Green, Flat White, Dark Red, and Grape)
  • Other services (just ask what I can do, I can probably figure it out)
Possibly more items later, just needed to get something out there fast.
« Last Edit: Thu, 01 August 2013, 14:09:28 by danielucf »
Offline pasph
  • Trade Count: (0)
Re: Wedding band fund.....sale (Taking pictures later)
« Reply #1 on: Sat, 27 April 2013, 16:35:28 »
GLWS & GLWW!
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #2 on: Sat, 27 April 2013, 16:38:39 »
Where can I see the colors you listed? May be interested in the painted 1800.
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #3 on: Sat, 27 April 2013, 16:46:56 »
I will do some color samples on the bottom of my MY1800 and get pictures up tonight or tomorrow morning.
Offline remedyhalopc
  • Trade Count: (0)
« Reply #4 on: Sat, 27 April 2013, 18:14:44 »
does the Pure have a plate, or have you ordered one through the GH60 group buy?
I'm super interested in the Pure!If you could PM me some pictures, I'll let you know by the end of the night if I"m going to buy it.
  • Trade Count: (1)
« Reply #5 on: Sat, 27 April 2013, 18:42:58 »
That ring is bad-ass.
My fat heavy gold ring has served me well for 20 years, and even though it is 18K it has not proven soft enough to get damaged (although I take it off whenever I am doing something like using tools (silly, huh? worrying about a metal ring sustaining damage in the environment wherein I am about to insert my actual flesh?)).
Make sure you don't get fat later in life. While a gold ring can be "sized" (ie stretched) that bad boy would probably break the stretcher.
Good luck! May the marriage last as long as the ring.
- Plato
Offline Michael
  • Formerly Bro Caps
  • Trade Count: (0)
« Reply #6 on: Sat, 27 April 2013, 18:45:58 »
Congratulations on your Wedding, Daniel. And best of luck to you both!
  • Trade Count: (1)
« Reply #7 on: Sat, 27 April 2013, 18:46:35 »
Congrats yooo
Offline calavera
  • Trade Count: (0)
« Reply #8 on: Sat, 27 April 2013, 18:49:12 »
Congrats on your wedding! Also PM'd about the ergodox.
Offline Moomoo
  • Trade Count: (0)
« Reply #9 on: Sat, 27 April 2013, 19:12:25 »
Congrats on the wedding, PM'ed about "The Ancient"
Offline spidum
  • Trade Count: (0)
« Reply #10 on: Sat, 27 April 2013, 20:02:17 »
Grats on wedding! Im PMing you about the pure!
Offline zoolzoo
  • Trade Count: (0)
« Reply #11 on: Sat, 27 April 2013, 21:24:26 »
pming
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #12 on: Sun, 28 April 2013, 00:25:16 »
Just got home after a long night of my fiancees belly dance event and drinking beer. I'll get pictures and reply to PMs tomorrow. Three people were interested in the Pure so I'll go in order of PMs. If others want to order a PBT non-backlit pure and have it sent to me I can mod it.
Offline WhiteFireDragon
  • Trade Count: (0)
    • youtube
« Reply #13 on: Sun, 28 April 2013, 16:03:28 »
Congrats on the wedding! All this stuff will barely put a dent in the wedding costs.
Offline SNF
  • Trade Count: (0)
« Reply #14 on: Sun, 28 April 2013, 16:27:24 »
congrats on wedding, GLWS, poker should sell fast  :cool:
Offline spidum
  • Trade Count: (0)
« Reply #15 on: Sun, 28 April 2013, 17:33:01 »
I still havent heard back from you about the pure. Did you get my message?
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
Re: Wedding band fund.....sale (Pictures added)
« Reply #16 on: Sun, 28 April 2013, 19:41:31 »
I think I've replied now, just blasted through a ton of PMs.
Also thanks for the congratulations from everyone, and pictures added.
Offline eRadicatedZomBiE
  • Trade Count: (0)
  • It's OK, I'm A Doctor.
« Reply #17 on: Sun, 28 April 2013, 20:11:25 »
Gah! I want an ErgoDox so bad  :'( but I don't have the money.
How do you feel about Layaway? :p
GLWS! Good luck with the wedding!
I may pick up the LEDS/ HL key still thinking it over.
CM QFR | WASD V1 | Flico MJ2 LE Blue | Ducky 78 | Ducky DK9008G2 Pro LE  |Phantom |
Ergodox
My WTB Thread
Offline zenuty
  • Trade Count: (0)
« Reply #18 on: Sun, 28 April 2013, 20:24:34 »
Skull looks verry high Quailty +_+
GLWS
LINE ID : zenuty
Skype ID : zenuty
www.facebook.com/zenuty
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #19 on: Sun, 28 April 2013, 22:50:48 »
Where is everyone? Had a ton of interest on Saturday and looked like I was going to hit my goal, but no one replied and am still at nothing sold  :confused:
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #20 on: Sun, 28 April 2013, 22:54:23 »
Ha, I've been staring at the picture of the paint samples, wondering whether I should choose orange or blue... PM incoming.
  • Trade Count: (0)
« Reply #21 on: Sun, 28 April 2013, 23:05:19 »
Ooh what a pile of stuff.   Ergodox....
Offline ApocalypseMaow
  • Kitteh Overlord
  • Trade Count: (0)
  • Say WHAAT...
« Reply #22 on: Sun, 28 April 2013, 23:45:30 »
YGPM.
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #23 on: Sun, 28 April 2013, 23:59:22 »
That is just one quick spurt to get the color down. After several coats, sanding, and probably some clear coats (if requested) they will look even better. This paint is supposed to be pretty high quality so I'm not even certain if it needs clear coat.
  • Trade Count: (0)
« Reply #24 on: Mon, 29 April 2013, 00:16:25 »
Pure is mine!  :cool:
Offline Moomoo
  • Trade Count: (0)
« Reply #25 on: Mon, 29 April 2013, 02:14:31 »
Thanks for replying about "The Ancient", I was wondering if you wanted to sell those keycaps on the KBT Pure :D?
  • Trade Count: (0)
« Reply #26 on: Mon, 29 April 2013, 02:26:00 »
Love the Hiero cap, but I have a hard time justifying $10 for a cap.  Good luck with the sales and congrats on the soon to happen wedding.
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #27 on: Mon, 29 April 2013, 07:39:42 »
I did it, ordered the ring even though I have not sold enough stuff yet  :eek: . Hoping a little time and I'll be fine. Super excited though!
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
Re: Wedding band fund.....sale (Ti glasses and spacebar added)
« Reply #28 on: Mon, 29 April 2013, 22:45:03 »
Added a couple titanium goodies.
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #29 on: Tue, 30 April 2013, 22:08:00 »
Bump
Offline rarar
  • Trade Count: (0)
  • moist booty seepage
« Reply #30 on: Tue, 30 April 2013, 22:59:08 »
How do lubed reds feel? Is it a noticeable difference?
(Not threadcrapping just asking because I might send my leopold to get lubed up :)   )
Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰_Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰ ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็_ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็
  • Trade Count: (0)
« Reply #31 on: Tue, 30 April 2013, 23:32:23 »
lubing linears and clears makes entire worlds of difference.
Offline rarar
  • Trade Count: (0)
« Reply #32 on: Tue, 30 April 2013, 23:33:22 »
excellent
Offline VesperSAINT
  • vpsert
  • Trade Count: (0)
  • #CustomKorean
« Reply #33 on: Wed, 01 May 2013, 03:52:39 »
mfw when danielUCF is subconsciously a UF fan. Troll bump. Congratulations on your wedding, good sir!
« Last Edit: Wed, 01 May 2013, 03:58:43 by VesperSAINT »
Offline TheQsanity
  • Trade Count: (0)
  • SmallFry Lovin'
« Reply #34 on: Wed, 01 May 2013, 03:56:20 »
GLWS!
SmallFry! <3
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #35 on: Wed, 01 May 2013, 06:25:58 »
They feel great. I've got some lubed vintage blacks that feel amazing, and am just wrapping up a QFR mod to 65g reds that also feel great. Both are with victorinox on the spring, and Tribolube 71 on the stems.
My best man is a big UF fan :p
Offline VesperSAINT
  • vpsert
  • Trade Count: (0)
  • #CustomKorean
« Reply #36 on: Wed, 01 May 2013, 06:29:04 »
Awwww yeeeeah. GO GATORS! :P
Hmm, might have to consider opening up my reds and lubing them up
Offline biochem
  • Trade Count: (0)
« Reply #37 on: Wed, 01 May 2013, 20:51:46 »
Still waiting on those belly dance pictures. ;D
Filco MJ2 tenkeyless (blues)
Heatware
Offline VesperSAINT
  • vpsert
  • Trade Count: (0)
  • #CustomKorean
« Reply #38 on: Wed, 01 May 2013, 21:31:30 »
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #39 on: Sun, 05 May 2013, 13:06:32 »
Bump
If anyone is interested in an MX Mini with aluminum top/bottom with acrylic in the middle let me know.
« Last Edit: Sun, 05 May 2013, 13:09:50 by danielucf »
Offline j2c8w6f8
  • Trade Count: (0)
« Reply #40 on: Sun, 05 May 2013, 13:48:28 »
Is this from MKC?
Offline j2c8w6f8
  • Trade Count: (0)
« Reply #41 on: Sun, 05 May 2013, 14:08:18 »
Is this from MKC?
got the answer.  :D
Offline Leslieann
  • Trade Count: (0)
« Reply #42 on: Sun, 05 May 2013, 17:13:19 »
Image for the Oakleys is not working.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #43 on: Mon, 06 May 2013, 17:51:06 »
Tons of things are packed and I'm going to the post office tomorrow. Still time for last minute orders.
Offline danielucf
  • Horrible Mailman
  • Trade Count: (0)
  • Hmmmm beer.
« Reply #44 on: Tue, 07 May 2013, 12:24:59 »
ErgoDox sold.
Offline dko2o
  • Trade Count: (0)
« Reply #45 on: Sat, 11 May 2013, 17:28:52 »
Are you interested in splitting the rgb kit? Only need the 1.25
Offline asdfjkl36
  • blue shirt guy
  • Trade Count: (1)
« Reply #46 on: Fri, 21 June 2013, 04:32:30 »
PMed.
Also, if anyone could let me know where i could buy some pink LEDs to use for a keyboard, that would be great. I've come across the issue of having the "flange" not let the LED sit all the way down.
