Author Topic: Just bought my first buckling spring. Did i over pay? (IBM Model M2)  (Read 1883 times)
Offline BADBADNOTGOOD
$60 shipping was $9... probably overpaid right? I wasnt able to find prices for the M2 so it was a shot in the dark...
But its quite clean for used and get this... working capacitors (awsome)... and its model #1395300 which wikipedia says is buckling spring. Non removable keycaps ( the one piece not two) and non removable ps/2 wire
Either way im still excited to own a buckling spring keyboard now
Will take some high res pics when it arives in the mail. Listing pics were very grainy.
Offline daerid
    • Rossipedia
Re: Just bought my first buckling spring. Did i over pay? (IBM Model M2)
« Reply #1 on: Sat, 27 April 2013, 16:33:21 »
Authentic Model M for $60 seems like a good idea.
« Reply #2 on: Sat, 27 April 2013, 17:16:36 »
The M2s are less desirable because of higher failure rates, but a good one would be nice and worth more.
They are fairly rare. The footprint is a big plus, I would be curious about the feel compared to a standard M, long-term.
- D Trump 2026-09-28
« Reply #3 on: Sat, 27 April 2013, 19:25:36 »
I have never been able to try out a regular model m but when it arrives in the mail I will be sure to describe the keyboard the best i can
Thanks for the replies
« Reply #4 on: Sat, 27 April 2013, 19:42:16 »
I paid less for either of my two M2s, so I think that you overpaid a little. That was two-three years ago, though.
The keycaps are one-piece, but removable. It is a flat keyboard with all keycaps the same size, so you can reorder the keycaps to e.g. Dvorak layout if you want to.
Be very careful when you insert a key, though. Make sure that the spring is pointing straight up so that it does not get bent.
I find the feel to be not as solid as a Model M because of the lighter construction and the flat keys. I also find it to be a bit more loud.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #5 on: Sat, 27 April 2013, 20:14:46 »
Depends on the condition of the board, frankly. There is no "overpaid" or "underpaid" without actually looking at the board. That said, $60 is eminently reasonable for an M2 in fair to good cosmetic with no functional problems. (Bear in mind, prices are also on the rise for all buckling spring boards. M2 included.)
If the capacitors are leaky, my general recommendation is to repair ASAP, as the chemicals can damage the PCB and potentially the matrix over time. Otherwise, there's not many real problems with the M2.
There's nothing actually wrong with the M2 either. People don't like it - but that's strictly personal preference. I'm not a huge fan, but it's still a solid keyboard.
So depending on condition, I'd say you probably got either a fair price or a very good deal.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
