Author Topic: Signatures  (Read 29599 times)
Offline i3oilermaker
  • techkeys.us
    • TechKeys
Signatures
« on: Mon, 29 April 2013, 14:33:24 »
The TOS says "signatures are limited to 777 x 70 pixels (1,000 characters max)"
Clearly this is not enforced....I was thinking what if we could enforce it in the template so that you can jam all you want into your allotted space but the site will only display the first 70 pixels of it.
Re: Signatures
« Reply #1 on: Mon, 29 April 2013, 14:34:59 »
How come the vertical height is so restricted anyway? Most forums allow users to use images/text that's around 250-350px high.
Offline keymaster
  • Topre Revolution Theorist
Re: Signatures
« Reply #2 on: Mon, 29 April 2013, 14:35:52 »
It's not a big issue, but there definitely needs to be some kind of enforcement.
Offline SmallFry
Re: Signatures
« Reply #3 on: Mon, 29 April 2013, 14:36:02 »
Images are limited to that area, however you can cram a lot into 1000 characters, especially when using goo.gl or bit.ly etc.
  • techkeys.us
    • TechKeys
Re: Signatures
« Reply #4 on: Mon, 29 April 2013, 14:40:08 »
Its not a big issue, but without picking on anyone, it can sometimes be hard to tell where the post ends and the signature picks up.  There is a profile for all your personal info...the signature should just be some brief info and maybe some quick callouts.
Offline esoomenona
  • Gnillort?
Re: Signatures
« Reply #5 on: Mon, 29 April 2013, 14:41:55 »
What does your profile show? From what I can see, the only thing there that isn't in everyone of a person's posts is the dates registered, last active, and local time.
Offline CommunistWitchDr
  • >implying keyboards
Re: Signatures
« Reply #6 on: Mon, 29 April 2013, 14:42:37 »
The vertical limit makes sense, but horizontal really shouldn't matter as long as its under the lowest common resolution.
  • techkeys.us
    • TechKeys
Re: Signatures
« Reply #7 on: Mon, 29 April 2013, 14:43:31 »
Agreed
Signatures
« Reply #8 on: Mon, 29 April 2013, 14:43:56 »
The one image in my signature only displays at 35pix tall, but it's not even the biggest part of my signature.
I know mine is big.
Offline Soarer
Re: Signatures
« Reply #9 on: Mon, 29 April 2013, 14:47:27 »
Sigs... meh  :p
  • techkeys.us
    • TechKeys
Re: Signatures
« Reply #10 on: Mon, 29 April 2013, 14:47:28 »
I'm reading about 220px high.... ಠ_ಠ
Offline rknize
    • metaruss
Re: Signatures
« Reply #11 on: Mon, 29 April 2013, 20:50:43 »
So in terms of pixels (not characters), what do folks think is a reasonable height limit?
Russ
Offline keymaster
Re: Signatures
« Reply #12 on: Mon, 29 April 2013, 21:08:16 »
100px height
Width shouldn't matter much. I don't think it annoys anyone.
Offline rknize
    • metaruss
Re: Signatures
« Reply #13 on: Mon, 29 April 2013, 21:39:50 »
Done.  Let's see how long it takes for the clacks to hit the fan....
Russ
Offline The_Beast
  • I like wood ಠ_๏
Re: Signatures
« Reply #14 on: Mon, 29 April 2013, 21:44:31 »
I know mine is big.
Someone sure is self confident!
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
Re: Signatures
« Reply #15 on: Mon, 29 April 2013, 22:10:31 »
Now if only Avatars could be 184x184... There's so much wasted space between the Avatar and post right now...
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline sth
  • 2 girls 1 cuprubber
Re: Signatures
« Reply #16 on: Mon, 29 April 2013, 22:18:16 »
only exception to the rule should be esoomenona
Re: Signatures
« Reply #17 on: Mon, 29 April 2013, 22:53:57 »
Wasted space?  All that space is there for people whose usernames are too long and (still) overwrite the post title ;)
Re: Signatures
« Reply #18 on: Mon, 29 April 2013, 22:57:46 »
rowdy is only 5 letters... :P
Offline rknize
    • metaruss
Re: Signatures
« Reply #19 on: Mon, 29 April 2013, 23:08:37 »
Oh yeah...I forgot about that.  Let me see if I can fix that for realz.
Russ
Re: Signatures
« Reply #20 on: Mon, 29 April 2013, 23:09:21 »
What you trying to fix, something that's not broken?
Re: Signatures
« Reply #21 on: Mon, 29 April 2013, 23:26:49 »
  • techkeys.us
    • TechKeys
Re: Signatures
« Reply #22 on: Mon, 29 April 2013, 23:29:08 »
Not broken? Your post is 45 pixels message, and 245 pixels sig.
Re: Signatures
« Reply #23 on: Mon, 29 April 2013, 23:30:06 »
Just turn off sigs?
I mean viewing others' sigs, like Soarer showed.
« Last Edit: Mon, 29 April 2013, 23:31:52 by jdcarpe »
  • techkeys.us
    • TechKeys
Re: Signatures
« Reply #24 on: Mon, 29 April 2013, 23:31:29 »
I like sigs...they add some character, but like I think your listing of keyboards and projects is sufficient...the quote and image are a bit overkill in my opinion.
Re: Signatures
« Reply #25 on: Mon, 29 April 2013, 23:37:26 »
Oh, so you don't want to see my military ribbons? That's okay. I served in the military so you can live in a country where you have the freedom to state your opinion. I respect that you have your opinion, I just don't share it. :)
Offline keymaster
Re: Signatures
« Reply #26 on: Mon, 29 April 2013, 23:40:22 »
Images from sigs cab be removed altogether, but idk if it's necessary. the board would look much cleaner. Avatars could remain as they are.
Offline sth
Re: Signatures
« Reply #27 on: Mon, 29 April 2013, 23:49:16 »
hhnnnnnrnrrrghhhh must resist urge to derail topic
  • techkeys.us
    • TechKeys
Re: Signatures
« Reply #28 on: Mon, 29 April 2013, 23:53:29 »
I didn't mean it that way...those are badass and I would love to hear an explanation for each of them.
I actually like your sig a lot more right now.
Offline rknize
    • metaruss
Re: Signatures
« Reply #29 on: Mon, 29 April 2013, 23:58:28 »
I'm getting a bit OT, but I fixed the overlap issue and also tightened up the left column.  LMK if you think it's too much.
Russ
Offline rknize
    • metaruss
Re: Signatures
« Reply #30 on: Tue, 30 April 2013, 00:05:10 »
I raised the character limit for sigs to 5000 chars.  So you can do whatever fancy markup that you want, but everyone gets 100 pixels and that is all.  Use it wisely.  :)
Russ
Re: Signatures
« Reply #31 on: Tue, 30 April 2013, 00:06:54 »
So you just get to decide this and we have no input?
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Signatures
« Reply #32 on: Tue, 30 April 2013, 00:12:50 »
think not what you can do for your pixels, but think what your pixels can do for YOU
also personally i hate signatures (except for anonymoose's, which is hilarious). if it were up to me (like it was before) you'd get like 100 characters period.
Offline mkawa
Re: Signatures
« Reply #33 on: Tue, 30 April 2013, 00:15:26 »
oh, and everyone's signature would be a fiat 500, except for anonymoose's, which would be a fiat 500 attacking him in his sleep
Offline mkawa
Re: Signatures
« Reply #34 on: Tue, 30 April 2013, 00:20:09 »
also everyone's fiat will be driven by freddy mercury
I DON'T THINK YOU UNDERSTAND, HIS STACHE WILL BE STEERING
Offline rknize
    • metaruss
Re: Signatures
« Reply #35 on: Tue, 30 April 2013, 00:21:17 »
No, I'm not necessarily saying that.  We are taking this for a spin to see what kind of feedback we get.
Sigs are nice but they can be distracting when they are larger than your typical post.  They are repeated over and over again.  What would be a reasonable limit in your eyes?  1000 characters wasn't enough, so we went to 1500...but that probably won't be enough either.  The main purpose of the limit is to curtail the use of screen-hogging sigs.  So I modified the template to put the limit on the final render size, not the content that feeds it.
« Last Edit: Tue, 30 April 2013, 00:23:58 by rknize »
Russ
Re: Signatures
« Reply #36 on: Tue, 30 April 2013, 00:22:35 »
I can still see overlap in the post I linked above with Nostalgia theme.
Offline mkawa
Re: Signatures
« Reply #37 on: Tue, 30 April 2013, 00:24:15 »
part of experiencing nostalgia properly is recalling the grand times when the forum didn't work
Re: Signatures
« Reply #38 on: Tue, 30 April 2013, 00:25:32 »
It only happens rarely, I can ignore it as I have been doing.
Offline rknize
    • metaruss
Re: Signatures
« Reply #39 on: Tue, 30 April 2013, 00:26:00 »
First, be sure to do a full reload (ctrl+shift+r).  Second, what browser are you using?  The CSS property I'm using is pretty well-supported.
Russ
Offline Sai
Re: Signatures
« Reply #40 on: Tue, 30 April 2013, 00:30:05 »
i am seeing the same thing as well.
using chrome with default theme.
Offline sth
Re: Signatures
« Reply #41 on: Tue, 30 April 2013, 00:31:01 »
ok but i think :llama: would do that nicely too
Offline rknize
    • metaruss
Re: Signatures
« Reply #42 on: Tue, 30 April 2013, 00:35:27 »
This is what is should look like:
Russ
Re: Signatures
« Reply #43 on: Tue, 30 April 2013, 00:36:00 »
Fixed now, thanks :)
I am using Chrome under Windows 7, and tried reloading the page a couple of times previously with no luck.  Doing Shift-F5 seems to have worked.
FWIW Safari and Firefox under Windows 7 also display wrapped text properly.
Offline Sai
Re: Signatures
« Reply #44 on: Tue, 30 April 2013, 00:37:18 »
yep it looks fine for me as well.
Offline rknize
    • metaruss
Re: Signatures
« Reply #45 on: Tue, 30 April 2013, 01:28:32 »
I modified the bbc parser to support the "align" property in the "img" tag.  Hopefully that will help the process of folks making their sigs more space efficient.
Russ
Offline esoomenona
  • Gnillort?
Re: Signatures
« Reply #46 on: Tue, 30 April 2013, 05:56:22 »
Maybe instead of killing off people's creativity or their small portion of this site to express something, a checkbox could be added to block a person's signature individually? You're getting tired of looking at mine? Click my profile and turn it off.
Re: Signatures
« Reply #47 on: Tue, 30 April 2013, 05:59:50 »
The moose with the big signature :))
Offline esoomenona
  • Gnillort?
Re: Signatures
« Reply #48 on: Tue, 30 April 2013, 06:02:43 »
Also, if we're going to cut people's signatures off, we need some scrolling action...
Offline esoomenona
  • Gnillort?
Re: Signatures
« Reply #49 on: Tue, 30 April 2013, 06:14:01 »
Also, we should reintroduce polls, then have a vote on how people feel about signatures.
