Author Topic: Have you tried this grease?  (Read 3287 times)
Offline Mugen
  • O-Rings are the murderers of keyboard souls
« on: Mon, 29 April 2013, 21:52:57 »
Offline WhiteFireDragon
    • youtube
Re: Have you tried this grease?
« Reply #1 on: Mon, 29 April 2013, 21:59:31 »
Good for stabilizers in moderate amounts. But using them to on switches will mess them up for sure.
Offline keymaster
  • Topre Revolution Theorist
« Reply #2 on: Mon, 29 April 2013, 22:51:41 »
This. I've used it to get rid of a squeaky backspace.
Offline Mugen
« Reply #3 on: Mon, 29 April 2013, 23:00:21 »
Thanks, what would you recommend for switch lubing then?
I've read this thread (http://geekhack.org/index.php?topic=34332.0)  and there seem to be several valid options, wondering what you guys would recommend,
Thanks.
« Reply #4 on: Mon, 29 April 2013, 23:11:30 »
We always recommend a 1:1 mixture of DuPont Krytox GPL 103 and 205. If you can find it. :)
Offline Mugen
« Reply #5 on: Tue, 30 April 2013, 00:05:34 »
Yeah i tried to find the 103 but it was freaking impossible (i found one somewhere but it was a huge container). what would you recommend if not this super mix?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #6 on: Tue, 30 April 2013, 00:06:26 »
I like super lube.
Offline Mugen
« Reply #7 on: Tue, 30 April 2013, 00:16:15 »
Offline iri
« Reply #8 on: Tue, 30 April 2013, 06:36:30 »
...and afford it.
-Ray Bradbury
Offline Larken
« Reply #9 on: Tue, 30 April 2013, 06:50:22 »
I can vouch for super lube as a cheap alternative. Though I did order some krytox to eventually compare against.
| Ergodox #1 | Ergodox #2 |
Offline Grim Fandango
« Reply #10 on: Tue, 30 April 2013, 08:04:16 »
Hmmm, when feeling and listening to my stabilizers, I think I could use this at least on my home keyboard.
Not sure if I should though. Everything considered I like how they feel. I am worried about creating some sort of inconsistency between the feel of the stabilizers and the rest of the keyboard.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #11 on: Tue, 30 April 2013, 10:31:25 »
I've been using Tribolube 71 on stems/stabilizers which is almost the same as GPL-205 by my guess but around half the price, and victorinox on springs. I love it on reds and blacks so far, and will try it on clears soon.
Offline keymaster
« Reply #12 on: Wed, 05 June 2013, 09:37:33 »
Instead of creating a new thread, I'm just going to bump this one.
It seems that Elite Keyboards has a new product for lubricating switches/stems: MechLube 2. It's only $6 and I'm curious to know if it will be a cheap and simple alternative to the Krytox 205/103 mixture usually recommended. Maybe someone can do a side by side comparison? :)
« Reply #13 on: Mon, 09 September 2013, 20:52:34 »
I would also like to know if anyone has tried Mechlube-2.  I want a low viscosity lube for my ergo clears.  Not sure if i should go for this or that silicon lube with teflon.
Offline InAComaDial999
« Reply #14 on: Tue, 10 September 2013, 13:34:32 »
It would be nice if they actually said what the lube is made of - silicon, teflon, etc?
Personally I like Finish Line Extreme Fluoro, which is 100% Teflon grease.  I've used it on a couple of squeaky stabilizers, both Cherry and Costar type, and it works great every time.  You wouldn't want to use that on switches, though; too viscous.
WASD V2 w/Browns | Ducky 9008G2 Pro PBT w/Clears | Filco Majestouch 2 w/Blues | Filco Ninja TKL w/Reds
Offline larrymoencurly
« Reply #15 on: Sun, 15 September 2013, 14:48:26 »
There's a type of synthetic grease sold for garage door opener gears that's very thin but doesn't seem to run off, Tribolube 39.
