Author Topic: IBM 60%? what on earth is it  (Read 5778 times)
Offline RougeR
« on: Thu, 02 May 2013, 09:18:27 »
found it posted online with no info
doesnt look like a mod or photoshop
what is it, looks buckling spring, what model?
Buckling spring warrior!
Offline esoomenona
  • Gnillort?
Re: IBM 60%? what on earth is it
« Reply #1 on: Thu, 02 May 2013, 09:21:46 »
Why, that looks to be an M-75.
My guess is someone cut and modded a Model M down to that size. Did a really good job if so. Can't see any lines or anything.
« Reply #2 on: Thu, 02 May 2013, 09:27:52 »
Is that the legendary Kishsaver?
« Reply #3 on: Thu, 02 May 2013, 09:31:30 »
No, Kishsaver doesn't have a F-row.
Offline RougeR
« Reply #4 on: Thu, 02 May 2013, 09:32:18 »
I cant see ANY, im dubious that it is a cut down...possibly with the aid of photoshop
i should add this was posted in a thread on /g/ about keyboards which 404ed with no info given
inb4 4chan
nope its not
this is kishsaver (bottom one)
Offline hasu
  • @tmk
« Reply #5 on: Thu, 02 May 2013, 09:48:31 »
I remember clickclack also had a beautiful 60% buckling spring.
Offline RougeR
« Reply #6 on: Thu, 02 May 2013, 09:48:53 »
place of origin.country of origin normally comes first in languages, in this case im pretty sure its german.
so the owner of this keyboard is likely German.
Offline RougeR
« Reply #7 on: Thu, 02 May 2013, 09:51:15 »
Offline esoomenona
  • Gnillort?
« Reply #8 on: Thu, 02 May 2013, 09:51:49 »
Or you know, the person bought a German pen? There's a Thermos in the top corner that has English writing on it. What now?
Offline RougeR
« Reply #9 on: Thu, 02 May 2013, 09:55:31 »
i think all thermos have the same generic text.
Offline esoomenona
  • Gnillort?
« Reply #10 on: Thu, 02 May 2013, 09:57:15 »
And maybe those German pens all have the same generic German text. It's almost pointless to try to determine the country of origin based on those two things.
Offline RougeR
« Reply #11 on: Thu, 02 May 2013, 09:58:08 »
i know i know, i was partly joking.  dfj has a pen like it and hes canada. but we have decided that we think the caps have to be from unicomp
Offline esoomenona
  • Gnillort?
« Reply #12 on: Thu, 02 May 2013, 09:58:20 »
What we should be focusing on is what is that black piece sticking out the right side of the board?
« Reply #13 on: Thu, 02 May 2013, 09:58:46 »
I determine it's photoshopped, due to the Bamboo stylus. :)
I think that's supposed to be "shadow" but the light sources and angles don't match up perfectly, to my eye.
Offline RougeR
« Reply #14 on: Thu, 02 May 2013, 09:59:32 »
that black line thing, you can barely see it.
any ideas?
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #15 on: Thu, 02 May 2013, 10:01:02 »
Offline esoomenona
  • Gnillort?
« Reply #16 on: Thu, 02 May 2013, 10:01:30 »
I think it's the foam lining inside or maybe the rubber contact thing (I forget what that's called).
Offline RougeR
« Reply #17 on: Thu, 02 May 2013, 10:04:05 »
this
Offline esoomenona
  • Gnillort?
« Reply #18 on: Thu, 02 May 2013, 10:06:37 »
Yes, that is what I was talking about. I know people cut the cases down, they generally fold the foam and membrane (that's the word I was looking for) under. Maybe it didn't all fit and is sticking out a bit? Maybe they actually cut it off and left it sticking out a bit? But it's definitely not a shadow. And it's not photoshopped. I can tell from seeing a lot of shops in my time.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #19 on: Thu, 02 May 2013, 16:19:59 »
I believe the pictured board is a user-customized board.
The board ClickClack posted a couple years ago, I do not believe was end-user customized...I think it was a custom application but not a one-off, that just isn't very common. I do have a photo of it somewhere. IIRC he found it on a banner/sign printing machine.
kishy.ca
