Author Topic: Just got new keycaps for my KBT Pure  (Read 3474 times)
Offline Tylerbrainerd
« on: Thu, 02 May 2013, 18:40:04 »
http://imgur.com/a/z7QfD
These are really great. If you're thinking of ordering from WASD Keyboards, do it!
Offline BlueBär
Re: Just got new keycaps for my KBT Pure
« Reply #1 on: Fri, 03 May 2013, 00:28:48 »
I don't know if it's because of dye on the grey or what, but it's a bit thin looking.
WASD has only the option of laser etched or engraved legends so technically there is no dye, and laser etched is not really made for bigger areas. Why is your keyboard screaming at you? ;D
Just kidding, very nice!
« Reply #2 on: Fri, 03 May 2013, 02:22:36 »
Oops yeah, not actually dye. And I realized it wouldn't be perfect but I was hoping a bit better. Otherwise totally happy with it
Offline Grim Fandango
« Reply #3 on: Fri, 03 May 2013, 02:54:13 »
Looks good :)
The look of the grey on white is starting to grow on me. Have a set of PBT with that color scheme coming in the mail.
« Reply #4 on: Fri, 03 May 2013, 04:16:49 »
I was a little unsure but im really happy with how it turned out.technically its white, light and dark grey
Offline ikoma
« Reply #5 on: Fri, 03 May 2013, 16:47:43 »
Love the grey font
QFR x2 | HHKB Pro2 | IBM Model M2 x2 | IBM Model M | Razer Blackwidow | NeXT Keyboard (Alps)
Offline Joxx
« Reply #6 on: Fri, 03 May 2013, 16:57:00 »
Looks great but I am not a big fan of the letters being centered
Ducky 9087 MX Brown | Blackwidow  MX Blue  | CM TK MX Red | Looking for a QFR MX Blue!
« Reply #7 on: Fri, 03 May 2013, 17:01:57 »
Love the grey font
Me too, really liking it. Looks better in real life.
« Reply #8 on: Fri, 03 May 2013, 17:02:25 »
definitely a personal preference. My last caps were upper left, and I like both, but I really wanted a sort of clean centered look across
Offline mark_thaddeus
« Reply #9 on: Sat, 04 May 2013, 21:20:00 »
Thanks for the post OP, you just made me decide to order through WASD keboards!
« Reply #10 on: Sat, 04 May 2013, 21:21:28 »
Nice! You should tell them so they'll decide I deserve free stuff :D
ha.
glad I could help you make up your mind. make sure all your key sizes are compatible.
« Reply #11 on: Sat, 04 May 2013, 21:28:40 »
Yup, my keyboard uses standard cherry MX profile key caps so it should be fine. I've also checked out WASDs info section on their key profiles and it's exactly the same as my current key caps.
