Author Topic: Prototyping: Custom extended numpad (31 key)  (Read 652912 times)
Offline Pacifist
  • on hiatus
Re: Prototyping: Custom extended numpad (31 key)
« Reply #150 on: Sun, 10 November 2013, 17:35:48 »
Personally I'm going to move the numlock key to the top left corner, because I don't want to accidentally press it in game
« Reply #151 on: Sun, 10 November 2013, 17:53:59 »
Ain't nothing wrong with that.  If you want I can give you a custom binary that moves the NumLock LED up there.
Offline Pacifist
  • on hiatus
« Reply #152 on: Sun, 10 November 2013, 18:02:55 »
Won't need that. It'll be off the entire time(numlock on my 75% makes right side of board a numpad) and I'll make them be the keys I need them to be
« Reply #153 on: Mon, 11 November 2013, 08:39:26 »
Came in.  Except for the missing silkscreen on the back, they look pretty good.
Can't believe its missing the back printing, though.  Going to be a pain in the butt to assemble.
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #154 on: Mon, 11 November 2013, 08:44:16 »
That looks awesome! Is there anyway I could acquire a PCB?
HHKB Pro 2   SmallFry Keyboard
« Reply #155 on: Mon, 11 November 2013, 08:45:05 »
Yes, I'm pretty sure I will have extra.  I'll add you to the list.
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #156 on: Mon, 11 November 2013, 08:47:18 »
The missing silkscreen, a mistake on your end or theirs?
  • HHKB Pro
« Reply #157 on: Mon, 11 November 2013, 08:47:45 »
Thank you! I don't need components or switches and I'll just mill myself a case. So just the PCB.
« Reply #158 on: Mon, 11 November 2013, 08:51:46 »
Not quite sure.  I can't go back and look at the layer setup.  I know I uploaded it, though.  I'm still going to complain.
« Reply #159 on: Mon, 11 November 2013, 08:53:03 »
Oops?
Your design is super clean. I'm impressed. :D
« Reply #160 on: Mon, 11 November 2013, 08:55:20 »
That was my first thought JDCarpe, but I checked the order...
43480-0
« Reply #161 on: Mon, 11 November 2013, 08:56:46 »
I would contact their customer service. They probably just messed it up, then. I bet they will make you replacements.
Offline MOZ
  • Busy making stuff
« Reply #162 on: Mon, 11 November 2013, 08:59:32 »
Yeah, contact their CC, might delay things if they ask for the original set back.
« Reply #163 on: Mon, 11 November 2013, 09:02:21 »
It's a prototype, I'm going to solder one of 'em up to make sure the thing works before I contact them.  No point in reprinting a bad design  ;D
Offline inteli722
« Reply #164 on: Mon, 11 November 2013, 15:35:35 »
Who needs silkscreening? :D
Waiting for: Phantom Plate
« Reply #165 on: Mon, 11 November 2013, 19:05:49 »
Worst fear confirmed.  The board contains a design defect.  I left the crystal ungrounded.  $150 down the drain :facepalm:
« Reply #166 on: Mon, 11 November 2013, 19:08:58 »
Been there, done that. If you want to absorb some of that cost with corrected PCBs, I'm willing to pay more.
Offline MOZ
  • Busy making stuff
« Reply #167 on: Mon, 11 November 2013, 19:15:23 »
Oh shaite! We could quick-fix it? Expose ground-plane near by and use a small jumper?
« Reply #168 on: Mon, 11 November 2013, 19:22:48 »
Luckily the filled planes are GND.  I just went downstairs and scraped off the mask and tried to short the pads to the plane with a solder blob.  I think it worked, but it's ugly as hell.  I'm going to keep building this first board to see if I can get it working.  *sigh*
Offline regack
« Reply #169 on: Mon, 11 November 2013, 19:23:08 »
Looks like it might be possible to carefully scrape off the mask and bridge over with some solder... assuming this is the crystal here, but it looks like the right footprint.
43576-0
-- oops, nevermind, metalliqaz beat me to it :D
Offline Pacifist
  • on hiatus
« Reply #170 on: Mon, 11 November 2013, 19:25:07 »
I am so confused as a person who has never done anything close to this kind of work
Offline MOZ
  • Busy making stuff
« Reply #171 on: Mon, 11 November 2013, 19:29:16 »
It should work as long as the filled plane is grounded, don't worry :)
As for aesthetics, although important, this is a prototype, so don't stress yourself.
« Reply #172 on: Mon, 11 November 2013, 20:03:01 »
Don't worry I got this.  I'm just a perfectionist so this upsets me.
I just programmed it, let's see how the software works...
Offline Pacifist
  • on hiatus
« Reply #173 on: Mon, 11 November 2013, 20:10:47 »
How major is it?
« Reply #174 on: Mon, 11 November 2013, 20:14:50 »
Seems to be working, although clearly I have a bug in my software somewhere.  Alright well ultimately not so bad.  I guess now I wait until my plate comes in, then I can test the backlighting and debug the software.
« Reply #175 on: Thu, 14 November 2013, 15:33:18 »
7bit's R5 presents an opportunity... The ergodox kit has a bunch of the vertical keys.  2x HONEY/NUMPAD (21*2=$42) and 1x HONEY/ERGOBASE ($29) would be able to completely cover two qazpads for $36 each.  Of course, all kinds of other kits would be desirable to fill out the top row with meaningful legends, and that gets expensive quick.  Could take some from a HONEY/STANDARD if you were going to get that anyway, I guess.  HONEY/MOD100, HONEY/MODEXTRA100, HONEY/CURSORBASE, and HONEY/CURSOR/R3 would be useful also.
I'm ordering some R5.  If anyone wants to split an ERGOBASE with me, let me know now and I will add it to my order and send it out with the PCB.
Offline Pacifist
  • on hiatus
« Reply #176 on: Thu, 14 November 2013, 15:37:45 »
What do they look like? Right now I'm buying a toxic set which has two extra x2 pieces
« Reply #177 on: Thu, 14 November 2013, 15:54:27 »
They are SA profile, Gray blank.  Actually now I'm starting to have doubts.  They are just so expensive!  I ordered some DSA and DCS blanks from SP that should be enough.  Oh well.
Offline Pacifist
  • on hiatus
« Reply #178 on: Thu, 14 November 2013, 16:43:23 »
Link?
« Reply #179 on: Thu, 14 November 2013, 16:52:44 »
Link?
You don't know about Round 5???
http://deskthority.net/wiki/Round_5
Offline Pacifist
  • on hiatus
« Reply #180 on: Thu, 14 November 2013, 16:59:34 »
Link?
I've only gone on dt two times. Once to make an account, and twice to try to figure out how to change my password. Its too confusing for my simpleminded brain
« Reply #181 on: Thu, 14 November 2013, 23:01:07 »
Found another error  :'(
It appears I managed to confuse myself by looking at the bottom layer (which is flipped).  Sooo.... now my transistors are installed upside-down with more solder blobs, lol
TIL always do an extra review.
  • HHKB Pro
« Reply #182 on: Thu, 14 November 2013, 23:13:01 »
Oh no! I hope you can still get working. Might not be pretty but it's only the prototype. :)
« Reply #183 on: Thu, 14 November 2013, 23:15:15 »
Yeah it's together just not pretty.  At least the software works, though.
Offline Pacifist
  • on hiatus
« Reply #184 on: Thu, 14 November 2013, 23:27:51 »
Are the PCB's that are being sent out for everybody else going to be fixed?
« Reply #185 on: Thu, 14 November 2013, 23:29:53 »
Using unconventional soldering techniques I can get it to work.  I have emailed the company that made them about the missing silkscreen.  Haven't heard back yet.  I will try to get them to re-run with the v1.2 design.
« Reply #186 on: Fri, 15 November 2013, 23:48:22 »
Quick and dirty backlighting modes with no caps and the pad outside of a case.
Offline Pacifist
  • on hiatus
« Reply #187 on: Sat, 16 November 2013, 00:01:57 »
Looks good!
Do you have extra clears I can buy from you instead of buying a big pack from mk.com? Also do you have any extra stabs I can buy?
Can't wait to be able to make something with my own hands.
« Reply #188 on: Sat, 16 November 2013, 00:04:13 »
Sorry I don't have any extra switches and I'm running really low on stabilizers :(
Offline Pacifist
  • on hiatus
« Reply #189 on: Sat, 16 November 2013, 00:06:37 »
That's fine. I plan to sell the extras on classifieds anyways. I'll just buy some costar stabs from wasd
« Reply #190 on: Sat, 16 November 2013, 00:54:40 »
I'm not very happy with how the "Case" came out.  Just didn't work out the way I pictured it.
However, the layout is working just perfectly.  The thumb switches are in the perfect spot and I think it strikes the perfect balance between plenty of switches and compact size.
44397-0
Offline AKmalamute
  • HHKB Scrub
« Reply #191 on: Sat, 16 November 2013, 01:17:36 »
It might not look very Apple-esque but it does look a bit like a bathroom scale, so you did okay. Piqued my interest.
As to interests ... since dedicated arrow keys are so incredibly uncommon on 60% boards ... WHAT THE **** IS THAT YELLOW AND PURPLE THING?!?!
...and can I have the parts to make one of those?
...For science, of course...
HHKB-lite2, Dvorak user
« Reply #192 on: Sat, 16 November 2013, 08:24:58 »
That is an Epsilon.  It's a 75%. They are all gone.
Offline Pacifist
  • on hiatus
« Reply #193 on: Sat, 16 November 2013, 13:56:14 »
How is that a 60%? It has a num row and a function row. Its a 75%. And all 75%'s have arrow keys
« Reply #194 on: Sat, 16 November 2013, 14:23:22 »
It's hard to tell from a partial photo.
« Reply #195 on: Wed, 27 November 2013, 14:34:17 »
Get your paypal ready guys.  Now that I have some holiday time off, I'm building these up.  You will be getting PMs from me soon.
Offline Pacifist
  • on hiatus
« Reply #196 on: Wed, 27 November 2013, 14:34:53 »
Who's making the case?
also pm me last, still need to sell some iron masks then I'll have sufficient funds
« Last Edit: Wed, 27 November 2013, 14:37:04 by Pacifist »
« Reply #197 on: Wed, 27 November 2013, 14:38:07 »
If noone steps up to build a case, I will design one.
Offline inteli722
« Reply #198 on: Wed, 27 November 2013, 14:42:02 »
Offline Pacifist
  • on hiatus
« Reply #199 on: Wed, 27 November 2013, 14:48:20 »
How much will the pcb+controller soldered on cost?
And you still have my keycaps on hand right  :p
