Author Topic: [WTB] Tipro MID Master Controller  (Read 1833 times)
Offline funkymeeba
  • CRUMPULAR
  • Trade Count: (0)
  • WEST SHINJUKU PLANTING TUNE
« on: Sat, 11 May 2013, 02:42:14 »
So, I must have bad luck or something. I have two Tipro modules that have faulty master controllers. One isn't detected by ChangeMe at all, the other cannot be used to program the keyboards. I'm looking for spare Tipro MID master controllers if anyone has them.
Seriously, if you have a Tipro keyboard module that is from 2002 or before, let me know. I'm looking for this particular piece (these are two different revisions, black is newer):
No joke, guys, I'd really like to get one of my matrix boards running, but my controllers are shot. If you've got an old Tipro MID module and are using it for showcasing some keycaps, let me know. The controller is easy to remove from that plastic plate, so no need to worry about the board's aesthetics.
I'm offering $5 (and I'll cover shipping, of course) for these. I am expecting most that are presently floating around to be flaky at best (note that I have now stumbled across two bad ones).
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
Re: [WTB] Tipro MID Master Controller
« Reply #1 on: Sat, 11 May 2013, 02:44:45 »
What are you using to program these? XP, Windows 7.....
Offline funkymeeba
  • CRUMPULAR
  • Trade Count: (0)
« Reply #2 on: Sat, 11 May 2013, 02:48:13 »
XP 32-bit at present. Win7 32-bit had the same failure with the newer controller (write failure that even Tipro support was not able to help with), and the older controller isn't detected at all by ChangeMe. Same PS/2 cable for both, and this same rule applies if I swap the controllers between the two keyboard modules.
Offline The_Beast
  • Trade Count: (0)
  • I like wood ಠ_๏
« Reply #3 on: Sat, 11 May 2013, 02:49:00 »
I have a controller like this, if I doesn't suit my needs, I'll toss you a PM
Offline funkymeeba
  • CRUMPULAR
  • Trade Count: (0)
« Reply #4 on: Mon, 13 May 2013, 01:43:10 »
Bumping this for good measure.
