Author Topic: Guide to the A87 PCB  (Read 5810 times)
Offline The_Beast
  • I like wood ಠ_๏
« on: Sun, 12 May 2013, 13:38:18 »
Anyone have build instructions on the soldering and the programing of this PCB (not on Korean if possible)?
Thanks :D
Offline gliy
Re: Guide to the A87 PCB
« Reply #1 on: Sun, 12 May 2013, 15:04:51 »
I would ask GON : ysymidi@gmail.com
He speaks English well and I believe sells the A.87
Offline The_Beast
  • I like wood ಠ_๏
« Reply #2 on: Sun, 12 May 2013, 15:07:58 »
I just bought one, I'm looking for a guide to build it and the software/firmware required to run it
Offline gliy
« Reply #3 on: Sun, 12 May 2013, 15:10:26 »
I know, what I meant is I know he sells the board, so I would recommend contacting him and asking if he has any video about building it.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #4 on: Sun, 12 May 2013, 15:11:43 »
Cool, I will do.
Thanks :D
Offline WhiteFireDragon
    • youtube
« Reply #5 on: Sun, 12 May 2013, 15:12:13 »
Do you have the white PCB or black PCB from LZ?
Diodes should be same as phantom or ergo-dox. All the other SMD components should be same as GH60.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #6 on: Sun, 12 May 2013, 15:14:13 »
White PCB. I bought it from MMB
    • youtube
« Reply #7 on: Sun, 12 May 2013, 15:20:56 »
Ok let me clarify: diodes can be the through-hole type, similar to phantom, or you can use SMD diodes, same size as all other korean keyboards. The PCB is labeled so you should know where all the other SMD components go.
I can edit and upload a video on this one in a few weeks. Programming should be the same way as GH60 or phantom since it also uses the Atmega controller. I'm not sure if there are any dedicated software for it.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Sun, 12 May 2013, 15:24:28 »
Cool, thanks for the help :D
Offline Kayliss
« Reply #9 on: Sun, 12 May 2013, 15:48:13 »
If you don't mind using google translate there is some info on KBDmania http://www.kbdmania.net/xe/data
Offline SmallFry
« Reply #10 on: Sun, 12 May 2013, 16:36:32 »
Found this one, containing the matrix, parts list and other tid bits
http://www.kbdmania.net/xe/data/5953500
