Author Topic: CM QFR keys suddenly not working  (Read 2327 times)
Offline dreamingftw
« on: Mon, 13 May 2013, 16:45:09 »
Hey guys, need a little help or suggestions. I had this QFR for about a year now and everything has been fine. I have kept it in great shape and have used it occasionally. When I plugged it in earlier to to use, the keys, QWERUIOP stopped working. All of the other keys register just fine. Now I am wondering if my keyboard just died on me :/ Thanks.
Offline dreamingftw
Re: CM QFR keys suddenly not working
« Reply #1 on: Mon, 13 May 2013, 16:46:16 »
I forgot to mention that I have tried plugging it into another computer and it has the same issues. Thanks.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #2 on: Mon, 13 May 2013, 17:02:49 »
How many times have you plugged and unplugged the mini usb connec? Is it loose in there?
Offline dreamingftw
« Reply #3 on: Mon, 13 May 2013, 17:28:44 »
I have tried it a few times but it's still the same issue. Thanks.
Offline WhiteFireDragon
    • youtube
« Reply #4 on: Mon, 13 May 2013, 18:32:38 »
There is a broken trace somewhere the controller leg and the beginning of the row. If you have a DMM, you can check for continuity. When you find the broken area, just bridge it with a small wire. Maybe completely replace the controller to see if that helps first.
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #5 on: Mon, 13 May 2013, 21:00:37 »
Loosen up the casing. This has caused the exact same problem for several people.
Having a bad day?
Offline dreamingftw
« Reply #6 on: Tue, 14 May 2013, 02:06:41 »
I'll try loosening up the case first. Thanks guys!
Offline dreamingftw
« Reply #7 on: Tue, 14 May 2013, 11:13:23 »
Thanks Kangaroo, removing the case did it!
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #8 on: Tue, 14 May 2013, 12:23:12 »
Glad I could help!
Kangaroo~
Having a bad day?
Offline Dany
« Reply #9 on: Tue, 14 May 2013, 12:49:28 »
I'm trying without case because I have a similar issue. Block scorr randomly turn on and then the keyboard write something like "quiopè+"
CM QuickFire Rapid with Black - 40A-R O-ring
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #10 on: Tue, 14 May 2013, 13:04:59 »
Yes, this is the same issue it looks like. Use the screw on the back to remove the case.
Having a bad day?
Offline Dany
« Reply #11 on: Tue, 14 May 2013, 16:01:30 »
There is any way to resolve this problem without remove the case? :)
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #12 on: Wed, 15 May 2013, 01:43:03 »
Honestly, in most cases all you have to do is loosen it.
Having a bad day?
