Author Topic: IBM KB-6323 on eBay for £5  (Read 9670 times)
Offline alka5eltzer
« on: Wed, 15 May 2013, 07:52:49 »
Hi Guys,
This seems like a good sturdy Keyboard for a fiver... is it?   :cool:
Metal Base... non-clicky as far as I know?
http://goo.gl/pa1GM
Offline 1391406
Re: IBM KB-6323 on eBay for £5
« Reply #1 on: Wed, 15 May 2013, 08:41:13 »
It's basically just a cheap, non-clicky IBM keyboard.
« Reply #2 on: Wed, 15 May 2013, 08:44:38 »
If that is the equivalent of a KB8923, then it is one of the best rubber domes from the early 1990s-early-2000s
They turn up regularly in second-hand stores around here, in need of a good cleaning.
- D Trump 2026-09-28
Offline 1391406
« Reply #3 on: Wed, 15 May 2013, 08:56:53 »
According to clickykeyboards, it's just a cheap rubberdome.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #4 on: Wed, 15 May 2013, 15:03:01 »
KB-6323 is a Chicony 6323. So yes, it's one of the good rubber dome boards.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline FoxWolf1
  • 154
« Reply #5 on: Wed, 15 May 2013, 15:25:46 »
As the others have said, it's domes, but not bad at all by dome standards-- quite heavy (for domes), and held together entirely by screws (not clips), so it's practical to disassemble for cleaning. Of course, it's still domes, so you get the typical dome issue of feeling like you're walking through mud when gaming on it, and extra fatigue when typing.
« Reply #6 on: Wed, 15 May 2013, 15:52:31 »
Also, if it is assembled like the KB8923, after you remove all the screws on the back, there are 3 or 4 more hidden under the keys that have to be removed from the front.
Offline alka5eltzer
« Reply #7 on: Thu, 16 May 2013, 18:23:11 »
Thanks for your replies all :-)
I've ordered one for my office (they're paying) ...  Not bad... Brand new for just under £10 ($12.50).
I'll upload some pics when I get it :-)
