Author Topic: ok folks, 3 IBM clickys. do they work with ps2?  (Read 2046 times)
Offline berserkfan
Offline jabar
Re: ok folks, 3 IBM clickys. do they work with ps2?
« Reply #1 on: Sat, 18 May 2013, 09:50:23 »
looks like terminal keyboards, so no, not PS/2. will need to be converted.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
« Reply #2 on: Sat, 18 May 2013, 12:24:39 »
Short answer = no.
A Teensy and Soarer's Converter ($20 + an hour at the soldering table) will make these usable on a modern computer via USB.
- D Trump 2026-09-28
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #3 on: Sat, 18 May 2013, 14:42:01 »
Yeah, these are all terminal version, no PS/2 versions there.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline Ninjerk
« Reply #4 on: Sat, 18 May 2013, 14:45:04 »
Terminal Keyboards are easy to get a hold of for me, and no they will not work with PS/2, Don't even waste a cent.
Offline Leslieann
« Reply #5 on: Sat, 18 May 2013, 16:43:34 »
Even if you get a PS2 version, it may or may not work on your motherboard as newer boards don't always provide enough power.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Ninjerk
« Reply #6 on: Sun, 19 May 2013, 13:49:53 »
Now that issue I haven't run into at all. IBM Model Ms with PS2 connections drain a little over 110mAhs, and with the ziotek ps/2 to USB converters, the power draw is fine for USB ports which give up to 500mAhs
Offline Leslieann
« Reply #7 on: Sun, 19 May 2013, 15:38:06 »
The OP asked about it working on PS2, not USB.
The problem is that many modern PS2 ports no longer support 110mA, and neither do the usb to ps2 adapters. This is why you have to use special Ps2 to USB adapters.
From Clickykeyboards.com
"Online reports indicate that these vintage IBM keyboards pull up to 100x more current compared to modern keyboards (112 mA vs 1.2 mA)."
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
