Author Topic: Is this possible?  (Read 3177 times)
Offline Silit
Is this possible?
« on: Sun, 19 May 2013, 19:27:25 »
Can I rig a topre board to have an MX red spacebar?
Offline esoomenona
  • Gnillort?
Re: Is this possible?
« Reply #1 on: Sun, 19 May 2013, 19:56:06 »
You probably could, with much modification. If you could rig one button up to be a separate and solitary input device, then have the firmware register it as [Space], then it could work.
« Reply #2 on: Sun, 19 May 2013, 19:58:15 »
Could you not just rig it up as part of the matrix? Sure, you'd have to make a makeshift mount and use wires.. but would it not be possible? http://imgur.com/a/eI8Il#0
« Last Edit: Sun, 19 May 2013, 20:00:21 by Photekq »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #3 on: Sun, 19 May 2013, 19:59:28 »
Why?
« Reply #4 on: Sun, 19 May 2013, 20:05:09 »
No, Topre keyboards have capacitative sensing, not made to detect mechanical key switches.
Support for multiple keyboard devices is in all major OS:es anyway.
If you want the space bar switch to be (more) linear, replace the cylindrical spring under the keycap with a heavier one and the rubber cup with one from a 30g key (if it can't be removed altogether). That would be much simpler, and the mod would be reversible.
« Last Edit: Sun, 19 May 2013, 20:09:53 by Findecanor »
Offline daerid
    • Rossipedia
« Reply #5 on: Mon, 20 May 2013, 00:34:46 »
The PCB for a Topre board is a completely different animal than one made for MX switches. For one, there's no holes for pins. And that's just the tip of the iceberg.
Offline Silit
« Reply #6 on: Mon, 20 May 2013, 06:34:04 »
Why?
When I rocket jump I don't like my space bar so stiff :D
Offline Rule16
  • R.I.P. SmallFry
« Reply #7 on: Mon, 20 May 2013, 07:37:45 »
Why?
Just use mouse wheel down for that.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline mich
« Reply #8 on: Mon, 20 May 2013, 13:24:29 »
Everything's possible :)
1. Destroy PCB traces leading to the spacebar
2. Drill holes for a cherry switch
3. Mount the switch
4. Add PCB from some resistive keyboard and connect it to the switch
5. Stick a USB hub somewhere inside
Alternatively, a somehow cleaner (but harder) way is to build a controller capable of sensing both capacitive and resistive switches. AFAIK somebody at GH built a controller for capacitive IBM Model F keyboards; something like this could possibly be tweaked to work with Topres and extended with resistive scanning support.
« Last Edit: Mon, 20 May 2013, 13:34:54 by mich »
Offline Silit
« Reply #9 on: Mon, 20 May 2013, 20:11:24 »
Why?
whaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaat dawg u crazy
Offline Rule16
  • R.I.P. SmallFry
« Reply #10 on: Mon, 20 May 2013, 20:16:55 »
Why?
Nah dawg trust me u lyke bettr if u try cuz lyke u can bhop wit it and shhhh. Ya herd?
Dvorak Only Zone
« Reply #11 on: Tue, 21 May 2013, 05:39:37 »
Have you tried just removing the cylindrical spring under the keycap?
Offline Silit
« Reply #12 on: Tue, 21 May 2013, 07:44:46 »
Why?
cant bhop in tf2 dawgggggggg but I did just pick up QL and CPMA so...
Offline daerid
    • Rossipedia
« Reply #13 on: Tue, 21 May 2013, 11:31:43 »
What the hell just happened to this thread?
Offline mich
« Reply #14 on: Wed, 22 May 2013, 04:05:35 »
Appears that mechanical keyboards finally became mainstream.
Offline Silit
« Reply #15 on: Wed, 22 May 2013, 06:27:34 »
I don't know what in this thread would indicate that. I also don't know why that would be a bad thing.
@Findecanor,
I definitely like the space bar better with no spring. Thanks, g.
Offline Rule16
  • R.I.P. SmallFry
« Reply #16 on: Sun, 26 May 2013, 23:14:50 »
Ye men leik evry1 who real got realforce now, sted of beats.
Dvorak Only Zone
Offline elttaboi
« Reply #17 on: Mon, 27 May 2013, 01:44:27 »
beets? they're pretty good
