Author Topic: [SHIPPED] Tai Hao 110 Coloured DS Set GB  (Read 629881 times)
Offline KeyPop
  • www.KeyPop.net [키팝.net]
    • KeyPop.net
Re: [CLOSED - Moving to Production] Tai Hao 110 Coloured DS Set GB - $9/set
« Reply #1550 on: Tue, 20 August 2013, 03:06:33 »
There seems to be much discussion on our part regarding the space bars.
Our current plans are to incorporate polycarbonate spacebars for each color(with the exception of black, having a normal black space bar or a clear polycarbonate space bar)
So red sets will have red polycarbonate space bars and yellow will have yellow polycarbonate space bars.
We will be hosting a group buy soon for the space bars once the bumble bee set group buy has met it's deadline (Aug 24th) for those who are interested.
We will also be providing standard white space bars for those who prefer not to have a polycarbonate version.
We will not be pursuing other solid colored space bars for now.
Hope this helps clear any confusion!
Thank you for presenting your plans concerning the spacebars!
I am not really sure though whether I'd like to have a single polycarbonate key on my board. Might look a bit off. Maybe it should come with a matching polycarbonate ESC key to have something else in the same style on the board.
I assume those will be made by SP and not match the Tai Hao profile right?
The Esc is a good idea and we may include that option in the groupbuy.
Yes, SP will be manufacturing them thus they will not match the Tai Hao profile but the difference should be minimal/negligible.
Offline LechnerDE
« Reply #1551 on: Tue, 20 August 2013, 03:23:15 »
Thanks for your response!
Looking forward to the spacebar GB :)
Offline gigibecali
« Reply #1552 on: Tue, 20 August 2013, 03:24:39 »
Isn't SP lower profile usually?
These should be OEM from what I can see.
IBM M - UK  |  QFR reds  |  QFR blacks  |  HPE 87 browns  |  HPE 87 blues
Offline LechnerDE
« Reply #1553 on: Tue, 20 August 2013, 03:31:32 »
Yes, SP is lower profile and Tai Hao is OEM. The difference concerning the spacebar will be minimal though.
« Reply #1554 on: Tue, 20 August 2013, 04:43:05 »
Or, but this might be pushing friendship a bit far, instead of an Esc key, a GEEKHACK key? :D
Offline Mad_Doktor
« Reply #1555 on: Tue, 20 August 2013, 08:38:46 »
+1
but wouldn't be too heartbroken if it didn't happen.
CM QFR - Cherry Blue | CM Storm Trigger - Cherry Brown | Keycool 84 - Cherry Black | Corsair K95 - Cherry Red | IBM Model M '93
Offline elton5354
« Reply #1556 on: Wed, 21 August 2013, 10:31:52 »
Just received the set. The red looks really good. I'd say it's really close match with the klaxon set.
For the space bar, they only had 5x on hand at that time.
The few keys on the bottom are from klaxon.
Offline elton5354
« Reply #1557 on: Wed, 21 August 2013, 10:32:30 »
Compared to SP's cap on the right
« Last Edit: Wed, 21 August 2013, 10:38:34 by elton5354 »
« Reply #1558 on: Wed, 21 August 2013, 10:33:57 »
Elton, flip some of the caps over and take a picture of that?
Offline last_sd
« Reply #1559 on: Wed, 21 August 2013, 10:39:56 »
Nice!
As mentioned let me know if you got extra that you are willing to sell locally(Toronto) :)
Home: CM QFR MX BLUE      Work: Razor Arctosa      Tried: Das MX BLUE
Offline elton5354
« Reply #1560 on: Wed, 21 August 2013, 10:42:03 »
Nice!
How many sets are you looking for?
Check the post above yours ;)
« Last Edit: Wed, 21 August 2013, 17:14:21 by elton5354 »
Offline Techno Trousers
  • ʘ_ಠ
« Reply #1561 on: Wed, 21 August 2013, 10:42:41 »
Looking good! Can't wait to see the rest.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #1562 on: Wed, 21 August 2013, 10:55:49 »
that looks dope! i wonder why they made a mold for all of the keys in standard size except the spacebar lol
how does that happen
Offline Halvar
« Reply #1563 on: Wed, 21 August 2013, 10:58:18 »
Wow, can't wait ...  Legends on the bottom row also look much better than on the earlier picture. :thumb:
Offline elton5354
« Reply #1564 on: Wed, 21 August 2013, 11:02:33 »
On my 10key pad
« Reply #1565 on: Wed, 21 August 2013, 11:03:58 »
Hm? I just wanted to see the underside of the caps.
Offline LechnerDE
« Reply #1566 on: Wed, 21 August 2013, 11:07:08 »
Those keys look better than expected!
@ CPTBadAss
I think Elton wanted to quote this ;)
Nice!
Offline Flamingchook
  • There are no dumb questions, only forbidden ones.
« Reply #1567 on: Wed, 21 August 2013, 11:14:27 »
These look fantastic! Can't wait to get my hands on them :D
MX: Filco Majestouch Metalic Blue 104-key w/ MX Brown, JD40 w/ MX Green, ErgoDox w/ MX Blue, GHPad w/ MX Blue. Topre: Realforce 87U 45g. BS: IBM Model M 52G9700 29-OCT-93
Soon™: GH60 w/ 62g MX Clear, [CTRL]ALT 60 w/ MX Green
Offline last_sd
« Reply #1568 on: Wed, 21 August 2013, 12:58:59 »
I am assuming this was meant for me.
Not sure yet but at least 2 different color.
This will give some in-expansive option to change color of my QFR
Offline SeriouSSpotS
  • 60% is love, 60% is life
« Reply #1569 on: Wed, 21 August 2013, 13:38:48 »
On my 10key pad
Those look pretty good, quite pleased that I ordered a set of red now :p
Offline le_doosh
« Reply #1570 on: Wed, 21 August 2013, 14:04:35 »
Those do look good. I'm curious to see what other colors look like.
I also with I had one of those GH key mat things.
Offline last_sd
« Reply #1571 on: Wed, 21 August 2013, 14:07:14 »
I don't think it would be hard.
If someone could upload the image (full size), you can print and laminate it.
EDIT: found the thread!
http://geekhack.org/index.php?topic=36712.0
« Last Edit: Wed, 21 August 2013, 14:10:01 by last_sd »
Offline gigibecali
« Reply #1572 on: Wed, 21 August 2013, 14:42:27 »
Is that SP cap translucent cardboard or plastic? :D
Offline le_doosh
« Reply #1573 on: Wed, 21 August 2013, 16:00:41 »
Thank you so much!
« Reply #1574 on: Wed, 21 August 2013, 17:37:13 »
These look more than reasonable - especially for the price.
Thanks elton!
Offline madderoftime
« Reply #1575 on: Wed, 21 August 2013, 23:29:27 »
They look pretty nice! Getting excited to see these in something other than jpg like in person.  ;D
GH60 Nevermore
Offline hbdongdg
« Reply #1576 on: Thu, 22 August 2013, 06:24:37 »
nice ~~~~ ;D
« Reply #1577 on: Thu, 22 August 2013, 06:28:09 »
Whoah, these... actually look good.
Offline Jokrik
« Reply #1578 on: Thu, 22 August 2013, 11:09:03 »
Caps looking good!
Ordered each color except blue since i dont like blue
But...
Offline last_sd
« Reply #1579 on: Thu, 22 August 2013, 11:25:00 »
Caps looking good!
But...
Three solutions
1. Buy more keyboards :D
2. Make your keyboard rainbow color!
3. Donate some to me :D
« Reply #1580 on: Thu, 22 August 2013, 11:56:40 »
Caps looking good!
But...
Three solutions
4. Donate the rest of the rainbow ones so someone else can "taste the rainbow"  :))
GH60 Nevermore
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #1581 on: Thu, 22 August 2013, 23:39:11 »
Damn them sample,s cursing my friend for backing out at the last minute. :(
Offline mark_thaddeus
« Reply #1582 on: Thu, 22 August 2013, 23:53:57 »
Caps looking good!
But...
Three solutions
I took advice number 1 and I'm trying to decide if I get the keyboard from corsair or the shine 3. . . or both. . . lol!
« Reply #1583 on: Fri, 23 August 2013, 01:03:43 »
Caps looking good!
But...
Three solutions
These keycaps will not be very backlight friendly for the Shine 3, but you might as well get both - you probably will eventually anyway.
Offline Jokrik
« Reply #1584 on: Fri, 23 August 2013, 01:10:49 »
I'm eyeing a 60% keyboard for this set, but again i've spent so much recently on these crazy hobby
somebody help !
Offline jil_jil32
  • Tokyo Press <3
« Reply #1585 on: Fri, 23 August 2013, 04:49:31 »
Cant' wait for the sets here :3 The red one looks very good!
« Reply #1586 on: Fri, 23 August 2013, 05:22:44 »
somebody help !
A lot of people here need a 12 step recovery program... including yours truly!  :p
Offline elton5354
« Reply #1587 on: Fri, 23 August 2013, 11:06:26 »
A finished whole set.
What do you guys think?
Offline last_sd
« Reply #1588 on: Fri, 23 August 2013, 11:16:35 »
Looks nice! Although not really fan of black in general (QFR stock caps are black)
Those who plan to use these caps for QFR, what's the plan for LED light keys? Simply cover them up or some how make a cut?
  • ʘ_ಠ
« Reply #1589 on: Fri, 23 August 2013, 11:29:10 »
Black's looking good too! I'm curious to see how the legend contrast is on the yellow.
  • ʘ_ಠ
« Reply #1590 on: Fri, 23 August 2013, 11:32:43 »
I'll probably either drill a small hole in the side, or just not worry about it. Caps lock is the only state key that really matters on a TKL, and it's quite obvious what the state is as soon as you start typing anything.
Edit: there is the Win lockout key too, which could be important for gaming. I never use it myself, but if I did I'd probably see if the light is visible without a window, and if not drill it.
« Last Edit: Fri, 23 August 2013, 11:35:07 by Techno Trousers »
Offline last_sd
« Reply #1591 on: Fri, 23 August 2013, 11:41:25 »
Yeah I use win lock key more often than caps lock.
Drilling is one solution I guess.
« Reply #1592 on: Fri, 23 August 2013, 11:44:47 »
They look pretty good
Offline elton5354
« Reply #1593 on: Fri, 23 August 2013, 14:02:18 »
On my keyboard. Mixed some Klaxons in it.
With LEDs
« Last Edit: Fri, 23 August 2013, 14:10:34 by elton5354 »
Offline jameslr
« Reply #1594 on: Fri, 23 August 2013, 15:19:18 »
These are looking really nice! Glad I got a few sets.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline MOZ
  • Busy making stuff
« Reply #1595 on: Fri, 23 August 2013, 15:24:48 »
Stop it. Please. I can't watch.
BTW, the red looks real good, in you rpictures above elton, are the Alt and Ctrl klaxxons?
Offline elton5354
« Reply #1596 on: Fri, 23 August 2013, 15:32:20 »
Yeah, plus space bar and caps lock.
Offline esoomenona
  • Gnillort?
« Reply #1597 on: Fri, 23 August 2013, 15:40:28 »
WTF! An extra $1, plus $12 to ship! Why are you ripping these people off? Is this a commie site?
Offline MOZ
  • Busy making stuff
« Reply #1598 on: Fri, 23 August 2013, 15:45:46 »
They match perfectly.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #1599 on: Fri, 23 August 2013, 16:22:55 »
You're so funny moose. Have you gone off your meds again?
