Author Topic: Spare cases and parts for Model M projects  (Read 3989 times)
« on: Sun, 02 June 2013, 12:31:21 »
I have a variety of spare cases and parts from Model Ms laying around that I need to clear out.
Many of these were bought mostly for the purpose of harvesting keycaps. I have at least a couple each standard Ms and M-122s.
If you are undertaking a project that involves cutting or otherwise wrecking a Model M, you may want a spare case, metal back plate, barrel plate, etc to experiment on or to keep in reserve.
This is an interest check that has not yet risen to a classified ad. The shipping will probably be more than the item.
Do any of you have an interest in this?
PS - I might also consider selling the barrel plate drilled and cleaned, with bolts installed, so that you can do a bolt mod with a lot less work.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline The_Beast
  • I like wood ಠ_๏
Re: Spare cases and parts for Model M projects
« Reply #1 on: Sun, 02 June 2013, 12:38:07 »
Do you have any keyboards or M cases with the manufacture date of 8/15/1991 or 8/26/1992? I'd love to buy one!
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #2 on: Sun, 02 June 2013, 14:07:24 »
You wouldn't happen to have a spare SSK case would you?
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #3 on: Sun, 02 June 2013, 14:10:00 »
I need an old type LED board and cable. They are found on old 131 and 1401 keyboards. Do you have a spare?
That's the connector type it needs, I could take a pic of the LED board that's in my 131 if you need a better visual later.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline Mandolin
  • Crystal Connoisseur
« Reply #4 on: Sun, 02 June 2013, 14:18:50 »
Could you please post all your PCB's from a top view? I want to find another with an square crystal clock of four pins, they normally have a canned 2 pin rounded block, maybe in the early models. Haven't seen one appart from one of my kbds and one prototype.
« Last Edit: Sun, 02 June 2013, 15:36:49 by Mandolin »
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
Offline The_Ed
« Reply #5 on: Sun, 02 June 2013, 14:23:16 »
The connector is what's important on my controller PCB. I need an old type LED board and cable which have that connector so they can attach to my controller PCB.
R.I.P.ster
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #6 on: Sun, 02 June 2013, 14:28:20 »
If you have any keys left with strange symbols, words or whatever on it, I'm interested :)
« Reply #7 on: Sun, 02 June 2013, 15:52:38 »
I have 3 beige Model M-122 cases dated:
07-16-91
10DEC91
13-FEB-95 (Lexmark)
and 2 beige standard cases dated:
08-22-91
13-FEB-96 (Greenock with "Bad" written in marker on the label)
and a "faux-camo" (perfect working order and bolt-modded) that my son and I painted dated:
10-11-91
plus an M2 that will not boot and is missing the numpad "0" key dated:
19NOV92
I am expecting 2 more M-122s in the mail in the next few days:
04-30-90
29-NOV-94 (Lexmark)
Don't get excited about controllers. The reason that these are on the junk pile in the first place is because they were DOA, and the controller is just about the only thing to go bad.
The M-122s are probably all OK, electronics and all, I pretty much only bought them to harvest key caps. Most of them are little used and would provide a mountain of clean fresh springs.
« Last Edit: Sun, 02 June 2013, 16:11:51 by fohat.digs »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Sun, 02 June 2013, 18:09:33 »
07-16-91
10DEC91
13-FEB-95 (Lexmark)
08-22-91
10-11-91
19NOV92
04-30-90
29-NOV-94 (Lexmark)
Dang, thanks for looking!
« Reply #9 on: Sun, 02 June 2013, 18:15:13 »
With 9 dates listed, there is a 1:40 chance that I will hit somebody's birthday.
Whether they want ancient IBM hardware is another question .....
Offline Mandolin
« Reply #10 on: Sun, 02 June 2013, 20:23:40 »
I know, but sometimes you just gotta change a couple capacitors and you're done if there's no corrosion. Sometimes you get lucky.
Sorry, didn't read through you go only >'91
« Last Edit: Sun, 02 June 2013, 21:40:12 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
« Reply #11 on: Sun, 02 June 2013, 21:09:17 »
You see that there is nothing listed earlier than 1991
Offline The_Ed
« Reply #12 on: Sun, 02 June 2013, 21:25:12 »
Nothing earlier than '90 means I am likely out of luck on the LED board... :'(
R.I.P.ster
