Author Topic: Keyboard Rebinding Software  (Read 1804 times)
Offline raKeto
« on: Sun, 09 June 2013, 23:16:32 »
I was wondering if there is any good Software Alternative to a custom ATmega32u4 controller (http://geekhack.org/index.php?topic=35065.0). Is there a way to remap the Windowsbutton, into a Fn key? Mainly for Multimedia Controlls on the F Keys.
Offline The_Beast
  • I like wood ಠ_๏
Re: Keyboard Rebinding Software
« Reply #1 on: Sun, 09 June 2013, 23:19:35 »
I use Autohotkey the most for keyboard remapping. I'm pretty sure that it supports media keys and layers
Offline Flaubertt
« Reply #2 on: Sun, 09 June 2013, 23:47:48 »
I use Autohotkey for my custom layout. Particularly, I LOVE adding extra modifiers, to add extra layers so that I don't have to move my hands as much, but rather have everything (or as much as possible) within finger reach at the press of a particular modifier.
HOWEVER, I have NOT been able to remap the Fn key for my BlackWidow, or even use it as a modifier, because for some reason Autohotkey doesn't detect it (as far as Autohotkey is concerned, when you press it it sends no input). Apparently, (for some?) keyboards it operates at a level too for autohotkey to work with. I'm also interested in a workaround for this!
Offline swordmasterhowe
« Reply #3 on: Mon, 10 June 2013, 03:02:52 »
Hmm, it seems like there's a page that's dedicated to this, also using autohotkey:
http://www.daonlyfreez.net/tutorials/3p/Veil/fnkey.htm
Don't know if that works for BlackWidow though.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #4 on: Mon, 10 June 2013, 03:17:00 »
What extra modifiers do you use to make it easier for your hands? An example? I'm just curious.
Offline laffindude
« Reply #5 on: Mon, 10 June 2013, 03:20:51 »
FN key doesn't send out a scancode, so upstream computer won't be able to detect if you've pressed it.
