Author Topic: NEW! Alps-based TKL Keyboard Project  (Read 159933 times)
Offline skrsh3r
Re: NEW! Alps-based TKL Keyboard Project
« Reply #250 on: Tue, 18 February 2014, 16:40:24 »
« Last Edit: Tue, 18 February 2014, 16:55:57 by skrsh3r »
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
Offline skrsh3r
« Reply #252 on: Wed, 19 February 2014, 15:49:38 »
here you go.
http://www.mediafire.com/download/wvt62f5cza4c9qg/ALPSTKL.7z
thank you man!
It's close to be finished only holes are needed as you said, btw i rotated caps lock switches to see how does that look and it comes out better then in those files i uploaded, just rotate cherries back to normal position and alps by 180 degrees after that all its left to route teensy and add ground planes and its basically done.
Offline skrsh3r
« Reply #253 on: Wed, 19 February 2014, 15:55:16 »
And i forgot  :-[ you can remove switch 161 and 167 they are not needed.
Offline jacobolus
« Reply #254 on: Wed, 19 February 2014, 19:21:39 »
Do note that some Alps switches feel slightly different when rotated 180 degrees. It’s a pretty minor difference though, so it probably doesn’t matter too much.
Offline BlueBär
« Reply #255 on: Wed, 19 February 2014, 19:23:20 »
Whoa so I checked this thread every once in a while and suddenly this! Awesome work, skrsh3r!
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
« Reply #256 on: Fri, 20 June 2014, 00:36:05 »
Sorry to zombie this, but I just found this thread after a period of GH inaction.  Is this project still ongoing?
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
Offline alfa147x
« Reply #257 on: Thu, 17 July 2014, 12:39:29 »
I'm interested in this too. Would love to test it out
« Reply #258 on: Thu, 17 July 2014, 12:41:02 »
AFAIK, the project is still waiting on keycaps and stabilizers. Matias is supposed to release them SoonTM
Offline hellojimbo
« Reply #259 on: Sun, 30 August 2015, 21:20:33 »
Doubtful that this project has any steam left, but if it does, I'm very interested.
If not, I'm looking at building a TKL with Blue Alps and I'm trying to source a PCB. Can anyone advise on the PCB?
Offline StormyMonday
« Reply #260 on: Tue, 01 September 2015, 15:07:36 »
In addition to handwiring, individual switch PCBs (A.K.A. The Enabler) may be an option for you:
http://geekhack.org/index.php?topic=55744.0
These folks have stocked the PCBs in the past, but they are currently sold out:
http://techkeys.us/collections/accessories/products/the-enabler
Or, you can order a batch of PCBs from these folks (you'd probably need to organize a GB, for this option to make sense):
http://www.oshpark.com/shared_projects/eRLs2jhf
You could say that I've also been giving this some thought.  ;D
Offline kj3906
« Reply #261 on: Sun, 25 October 2015, 07:42:52 »
Any update?
« Reply #262 on: Tue, 24 November 2015, 15:48:19 »
This has been on my back burner for far too long.
I am resurrecting this project!
I don't know how or when, but this is going to be a reality. I need a Kingsaver-like Alps custom in my life.
Offline FrostyToast
  • Litshoard
« Reply #263 on: Tue, 24 November 2015, 15:51:46 »
I can't say that I would be down for this, but I will watch this project.
My only concern is that the plate seems to only support one layout; is there any possibility of supporting other layouts?
ANSI125 isn't exactly optimal for ALPS lovers since vintage sets cannot be used.
Quote from: elton5354
« Reply #264 on: Tue, 24 November 2015, 15:57:09 »
I'm certainly open to adding layout possibilities to the PCB, and having several plates to choose from. I just need to know which additional layouts people want. Most people probably have AEKII, AT101, AT101W. The good thing is that now we have keycaps from Tai Hao and even a full set from SP (Alpine Winter), so standard ANSI 125 is actually possible.
Offline FrostyToast
  • Litshoard
« Reply #265 on: Tue, 24 November 2015, 16:00:36 »
I think that either AEKII or ANSI150 are the next most popular; likely the latter.
Though, I must reiterate that I will likely not purchase this keyboard unless something else really intrigues me.
« Reply #266 on: Tue, 24 November 2015, 16:04:57 »
Your suggestions are still valid, and welcomed.
The reason for this keyboard's (eventual) existence is that I want another nice custom, and I'm basically over MX. A few years ago, I thought up this project because Alps were starting to get some hype here and I knew they would eventually be popular (again). But now I just want it for myself. I want a nice, programmable TKL with Alps switches, in a solid aluminum housing. If I want one, others may want one, too.
Offline njbair
    • nickbair.net
« Reply #267 on: Tue, 24 November 2015, 18:20:56 »
So basically just a straight-up standard ANSI TKL in an aluminum case, with no gaudy lights or logo engravings? This seems like it's been missing from the custom scene for a long time...not just for Alps, but for MX as well. I think the choice for standard ANSI layout makes the most sense.
Would this case have an incline, or at least mounts for those TEX feet to raise up the back?
My boards:
« Reply #268 on: Tue, 24 November 2015, 18:38:57 »
Yes, that's correct for the most part. It might have the CarpeKeyboards 'CK' logo engraved on it, but that would be about it. I hope to design the case with an incline, of about 7-8 degrees max, so that no feet will be required. I am still debating on whether to offer MX compatibility in the same PCB or not, and go strictly Alps.
Offline bocahgundul
  • a seal
« Reply #269 on: Tue, 24 November 2015, 18:49:55 »
Is this still happening bro? Would love getting this instead of searching for kingsaver
« Reply #270 on: Tue, 24 November 2015, 18:55:24 »
That's the goal...to help people who are searching for Kingsavers find their new keyboard. :)
Offline bocahgundul
  • a seal
« Reply #271 on: Tue, 24 November 2015, 19:00:03 »
Mate you helped me. 100% interested
Offline engicoder
« Reply #272 on: Tue, 24 November 2015, 19:07:50 »
Let see...
  • Alps
  • Tenkeyless
  • Solid case
  • No stupid light show
I'm in!!
My only wishlist item is a winkeyless case/plate option
« Last Edit: Tue, 24 November 2015, 19:09:29 by engicoder »
« Reply #273 on: Tue, 24 November 2015, 19:48:06 »
Let see...
  • Alps
  • Tenkeyless
  • Solid case
I'm in!!
Yes, I will have a winkeyless bottom row option for sure.
Offline njbair
    • nickbair.net
« Reply #274 on: Tue, 24 November 2015, 20:24:11 »
IMHO, logos and engravings on the bottom of a board are fine, but I would love to own a custom TKL with no branding on the top side. Even the the front edge is fine, like how Filco does it. But keep the top clean and simple. Also, a 7 or 8 degree incline sounds right on.
Finally, Alps-only, please. Leave MX out of it. Supporting both will just add to the cost. There are already plenty of MX custom TKLs out there, and plenty more to come. Besides, a sleek, US-built aluminum custom TKL might be exactly what Alps needs right now.
My boards:
« Reply #275 on: Tue, 24 November 2015, 20:44:23 »
I'm already imagining what this will look like with an Alpine Winter SA TKL set, or maybe 1976 Alps Remix...
Offline njbair
    • nickbair.net
« Reply #276 on: Tue, 24 November 2015, 20:58:34 »
We just have to convince Signature Plastics to give us SA with Alps mounts.
My boards:
« Reply #277 on: Tue, 24 November 2015, 21:00:13 »
I have faith it can be done :)
Offline XMIT
  • formerly jsoltren
« Reply #278 on: Tue, 24 November 2015, 21:05:55 »
I'm hoping for Vortex PBT double shots in Alps mount, or really any PBT caps in Alps mount.
« Reply #279 on: Tue, 24 November 2015, 21:19:23 »
Works for me, or even the Tai Hao double shots in ABS. I'm just happy we have a few options for Alps keycaps now, other than scavenging from vintage keyboards.
Offline njbair
    • nickbair.net
« Reply #280 on: Tue, 24 November 2015, 21:22:14 »
If PBT I would prefer dyesubs to doubleshot...those Vortex doubleshots are super uneven.
My boards:
Offline kinglukas38
  • Do you even tactile?
« Reply #281 on: Tue, 24 November 2015, 23:14:22 »
is there no possibility for lighting at all? kinda want a tkl alps with case lighting
I've never done it before, but I'm pretty sure I'm good at it
Offline Weltschmerz
« Reply #282 on: Wed, 25 November 2015, 04:42:27 »
I recall seeing some prototypes for an alps to mx adapter, making it so that you could use standard mx keysets. Would it be even remotely possible for this to be an option? The majority of alps keycaps (and selection) is pretty lackluster, even though there are more and more options all the time. I'm assuming since this would be using a costar style stab, it wouldn't?
Offline XMIT
  • formerly jsoltren
« Reply #283 on: Wed, 25 November 2015, 06:06:01 »
Doubleshot is the way to go for white-on-black regardless. The Vortex doubleshots have the most contrast-y legends I've ever seen. They're great in low light conditions. Sure, the Vortex quality isn't perfect, but they do seem to get progressively better. Getting perfect PBT caps is a tough process problem to solve and takes time!
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #284 on: Wed, 25 November 2015, 11:33:29 »
I'd be down if it were similar to the Kingsaver. Case lighting would also be cool but it's not something I would need.
Offline sean
  • Mechanical newb
« Reply #285 on: Wed, 25 November 2015, 16:59:01 »
I hereby pledge my support
Offline njbair
    • nickbair.net
« Reply #286 on: Wed, 25 November 2015, 22:34:08 »
There are a few projects like that, but AFAIK none of them are ready for prime time yet. You also end up with some very tall keycaps because of the adapter's added height. Any such project will have to address the stabilizer issue as well.
At any rate, this TKL won't care what caps you use.
My boards:
Offline zombimuncha
« Reply #287 on: Wed, 25 November 2015, 23:00:53 »
Interested to see how this progresses, although I doubt I could get wifely approval for it.
Offline njbair
    • nickbair.net
« Reply #288 on: Thu, 26 November 2015, 14:53:05 »
Better start saving your pocket change now.
My boards:
Offline Jokrik
« Reply #289 on: Thu, 26 November 2015, 15:15:30 »
Will be looking forward for this, I'm turning to the alps side
Offline qwack
« Reply #290 on: Mon, 11 January 2016, 15:37:17 »
Any news on this project?
Pure Pro w/MX Red - [review]
« Reply #291 on: Mon, 11 January 2016, 18:49:48 »
JD, any chance this might work in a Kingsaver case?
The ones I made on Shapeways work fine.  I may try and get a mold milled so I can cast them, but it would be easier to get an injection mold run if the interest arises.  I'm also still trying to run down some molds used to make some used in an old TTL device.
Offline Eugene45
« Reply #292 on: Thu, 28 January 2016, 07:28:43 »
Hello Jdcarpe any news of the follow of the project ? And by any chance a TKL Alps Iso board ?
lmao, cut the French some slack, they gave you a big statue
« Reply #293 on: Thu, 28 January 2016, 10:32:21 »
At this time, all my efforts are focused on getting the JD45 to market, as well as making the JD40 available again. The JD45 group buy should start very soon, and JD40s should show up in several places, as well.
I do plan to continue this project, but it may not be a traditional TKL. I have in mind a more interesting design with a similar form factor, and I might just take the project in that direction. :)
Offline Eugene45
« Reply #294 on: Thu, 28 January 2016, 14:37:28 »
Hello, great to hear some news
So no TKL, but something like the Whitefox layout ?
Fingers crossed for the JD 40/45. Hope you have great success with it.
Have a nice day.
Offline Venatorious
  • Gotta Start Somewhere
« Reply #295 on: Thu, 18 February 2016, 18:18:47 »
I really want this to happen. I sure as hell don't have the money for a kingsaver and I am not a huge fan of 60% boards.
Will there be spots for LED's?
Offline Weltschmerz
« Reply #296 on: Wed, 24 February 2016, 06:32:06 »
In what way would it not be a traditional TKL? Except the fact that is alps, of course  ;D
Offline bocahgundul
  • a seal
« Reply #297 on: Wed, 24 February 2016, 06:40:43 »
We can hope for this project after the jd45 group buy is done
