Author Topic: Vintage Blacks vs Standard Blacks?  (Read 2098 times)
Offline y0fate
  • The Holy CBass.
« on: Thu, 13 June 2013, 04:47:26 »
I'm just wondering if there is any NOTICEABLE difference (IE. not 60g vs 62g springs), are they rare or sought after?
"No"- Greed
Offline Jocelyn
  • 조셀린
Re: Vintage Blacks vs Standard Blacks?
« Reply #1 on: Thu, 13 June 2013, 04:48:20 »
I can't answer this for you, but you may post this kind of thread in keyboards section if you'd prefer. Up to you :)
This is also a good thread to post things like this in - http://geekhack.org/index.php?topic=40501.0 but it is ultimately up to you.
« Reply #2 on: Thu, 13 June 2013, 04:50:04 »
They're not that rare. You can find them in lots and lots of old Cherry boards which sell for cheap. You will just need to desolder them.
They are supposedly smoother although I have never tried them so I cannot comment.
Also, as Jocelyn suggested you should post this kind of thing in the simple questions simple answers thread. People can reference you to links that should answer your questions.
Offline y0fate
  • The Holy CBass.
« Reply #3 on: Thu, 13 June 2013, 04:53:52 »
Didn't search for hard for a suitable thread/forum, my mistake!
"No"- Greed
Offline Jocelyn
  • 조셀린
« Reply #5 on: Thu, 13 June 2013, 05:13:15 »
No it's okay. It's hard to search geekhack imo and I recommend you google site:geekhack.org instead. No worries on not searching, I was letting you know it is okay to post in keyboard section even if you start new thread. No need to off topic.
That way more people will see your thread :)
Offline y0fate
  • The Holy CBass.
« Reply #6 on: Thu, 13 June 2013, 05:18:12 »
http://geekhack.org/index.php?topic=36485.0
http://geekhack.org/index.php?topic=38921.0
Then if you were to just lube regular blacks wouldn't it be almost identical to Vintage Blacks?
"No"- Greed
