Author Topic: [ebay] SGI Silicon Graphics gray granite keyboard?  (Read 3068 times)
Offline calavera
« on: Sat, 15 June 2013, 17:04:40 »
Stumbled on these on ebay:
http://www.ebay.com/itm/140973128752
Anyone know what switches they use? I might try one if it's mechanical.
Re: [ebay] SGI Silicon Graphics gray granite keyboard?
« Reply #1 on: Sat, 15 June 2013, 17:06:13 »
http://deskthority.net/wiki/NMB_RT6856T
Looks to be the rubber dome variety.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #2 on: Sat, 15 June 2013, 18:00:20 »
Definitely rubber dome. You have to be careful with the SGI boards too, if you're planning to use it with a PC. Only the 950900 (granite) and 9500829 (beige) are PS/2 compatible.
http://deskthority.net/wiki/SGI_Granite
Also, if you do manage to score one of the PS/2 versions, it probably won't work with the typically recommended "cube" USB adapter (which works fine on a Model M). Instead, there is a Belkin adapter that works great.
http://www.amazon.com/Belkin-USB-PS-2-Adapter/dp/B000ELSXFY
I'm using it right now with my new 950900 to type this.  ;D
I like these damped ALPS sliders, but it feels kind of weird. I need to give my fingers some time to re-adjust to ALPS typing. The key travel is noticeably shorter than the Cherry switches and buckling springs.
